MS400-NKR15H
MS400-NKR15H
    VCC
    LED LAMP T-3 1/4 SCREW 15V MINI
MS400-NKR15H 数据手册
T-31/4 MINIATURE LAMP Data Display Products ® Single-Chip - For Small Lens Applications - For Detailed LED Data, See Discrete Section, MODEL 200 1 TO ORDER, FOLLOW THE EXAMPLE: Model[1] MB400 MBL400 MF400 MFL400 MS400 MSL400 Select one BOLD component from each SHADED column in the tables below. Bayonet Bayonet Flange Flange Screw Screw LED 1Model 2 -NWG 3Voltage MS400 24H ➜Part Number MS400-NWG24H HIGH INTENSITY-WATERCLEAR ENCAPSULATION 2 LED -NWR -NWO -NWA -NWG -NWB -NWW -NWL -NKR -NKO -NKA -NKG -NKB -NKW -NKL λpk Iv[2] Viewing V/C Color (nm) (mcd) Angle Table[3] RED ORG AMB GRN BLU CWHT WWHT RED ORG AMB GRN BLU CWHT WWHT 634 605 592 520 465 2800 2000 2800 2400 700 2500 1800 3600 8000 3600 10000 3000 9200 9200 30 30 30 45 45 50 50 15 15 15 15 15 20 15 I I I II II II II I I I II II II II 634 605 592 520 465 WIDE ANGLE/FLAT-TOPPED-WATERCOLOR ENCAPSULATION LED -NFR -NFA -NFG -NFB -NFW λpk Iv[2] Viewing V/C Color (nm) (mcd) Angle Table[3] RED AMB GRN BLU WHT 634 592 520 465 75 75 75 75 75 I I II II II 780 600 780 168 280 [1] All Models are center anode. Insert C after Model for center cathode (e.g. MBL400C). [2] Iv = typical luminous intensity @ If = 20mA (Ta=25°C). [3] See Voltage/Current table for design specifications. 3 Voltage/Current Design Max Vf/If Vf/If V/C Table I 5V/22mA 5.5V/28mA 7V/27mA 6V/21mA 12V/20mA 14V/25mA 15V/24mA 16.5V/28mA 26V/20mA 24V/17mA 28V/16.5mA 30V/18mA 48V/15mA 50V/16mA 60V/9mA 65V/10mA 120VAC/3.5mA 130VAC/4mA Voltage[4] 2 5H 6H 12H 15H 24H 28H 48H 60H 120 Voltage/Current Design Max Vf/If Vf/If V/C Table II 5V/15mA 5.5V/23mA 6V/15mA 7V/25mA 12V/15mA 14V/20mA 15V/15mA 16.5V/18mA 24V/15mA 26V/18mA 28V/15mA 30V/17mA 48V/9.5mA 50V/10mA 60V/9mA 65V/10mA 120VAC/3.5mA 130VAC/4mA [4] Ta = 25°C. Voltage "2" indicates external resistor required. Voltages 5H through 60H are VDC. For AC operation, insert D after Voltage (e.g. 24HD). D indicates built-in rectifier: not required for 5H or 120VAC. For 120VDC, insert DC after Voltage (e.g. 120DC). Continued… 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products 69 T-31/4 MINIATURE LAMP Data Display Products ® Single-Chip - For Small Lens Applications MB400 MBL400 MF400 MFL400 MS400 MSL400 All dimensions are in inches (mm) Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25) Specifications are subject to change without notice. 70 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products Data Display Products ® T-31/4 MINIATURE LAMP Single-Chip - For Small Lens Applications - For Detailed LED Data, See Discrete Section, MODEL 200 Wide Angle LED Lamps MB400, NFX Series (75°) MBL400, NFX Series (75°) MF400, NFX Series (75°) MFL400, NFX Series (75°) MS400, NFX Series (75°) MSL400, NFX Series (75°) All dimensions are in inches (mm) Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25) Specifications are subject to change without notice. 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products 71
MS400-NKR15H
物料型号: - 型号包括MB400, MBL400, MF400, MFL400, MS400, MSL400等,每种型号都有不同的安装方式,如卡口(Bayonet)、法兰(Flange)、螺丝(Screw)。
器件简介: - 这些是高强度、水清封装的LED灯,具有不同的颜色和亮度级别。
引脚分配: - 所有型号的LED灯都是中心阳极,如果需要中心阴极,可以在型号后添加"C"。
参数特性: - 提供了不同颜色LED的发光强度(lv)、波长(Apk)、视场角度以及工作电压/电流表。
功能详解: - 详细列出了不同电压和电流下的LED设计和最大电压/电流规格。
应用信息: - 适用于需要小尺寸光源的应用场合。
封装信息: - 提供了不同封装尺寸的LED,包括MB400系列和NFX系列,以及它们的尺寸和公差。
MS400-NKR15H 价格&库存
很抱歉,暂时无法提供与“MS400-NKR15H”相匹配的价格&库存,您可以联系我们找货
