MS402-A15-CW
MS402-A15-CW
    VCC
    LED LAMP T-3 1/4 SCREW 15V MINI
MS402-A15-CW 数据手册
T-31/4 MINIATURE LAMP WITH LENS Data Display Products ® High Intensity, Wide Angle - For Medium to Large Lens Applications - Fresnel Lens; Bayonet or Screw Base 1 TO ORDER, FOLLOW THE EXAMPLE: Model[1] MB402 MS402 Select one BOLD component from each SHADED column in the tables below. Bayonet Flange Screw LED Voltage Lens Bi-Polar 3 1Model 2 4 5 MB402 -R 12 -CR -BP ➜Part Number MB402-R12-CR-BP 2 LED Color -R -O -A -G -B -W -L RED ORG AMB GRN BLU CWHT WWHT λpk Iv[2] V/C (nm) (mcd) Table[3] 634 609 592 520 465 2800 (*4) 2000 (*4) 2800 (*4) 2400 (*2) 700 (*2) 2500 (*2) 1800 (*2) I I I II II II II 3 Voltage/Current Design Max Vf/If Vf/If V/C Table I 5V/75mA 5.5V/85mA 6V/40mA 7V/60mA 12V/30mA 14V/40mA 15V/30mA 16.5V/35mA 24V/30mA 26V/35mA 28V/25mA 30V/28mA 48V/20mA 52V/22mA 60V/16mA 65V/18mA 120VAC/9.5mA 130VAC/10.5mA Voltage[4] 5 6 12 15 24 28 48 60 120 4 Lens -CR Red -CA Amber -CG Green -CB Blue -CW Water Clear Voltage/Current Design Max Vf/If Vf/If V/C Table II 5V/26mA 5.5V/35mA 6V/28mA 7V/39mA 12V/15mA 14V/22mA 15V/15mA 16.5V/19mA 24V/15mA 26V/18mA 28V/15mA 30V/18mA 48V/9mA 50V/9.5mA 60V/6.5mA 65V/7.2mA 120VAC/5mA 130VAC/5.5mA MB402 [3] See Voltage/Current table for design specifications. [3] See Voltage/Current table for design specifications. [1] MB402 and MS402 are center anode. Insert C after Model for center cathode (e.g. MB402C). [2] Iv = typical luminous intensity @ If = 20mA (Ta=25°C). Luminous intensity is measured without the lens. (*2) = 2 LEDs per package. [3] See Voltage/Current table for design specifications. [4] Ta = 25°C. Voltages 6 through 60 are VDC. For AC operation, insert AC after the Voltage (e.g. 24AC), not required for 120V. Contact factory for VAC design currents. For 120VDC insert DC after Voltage (e.g. 120DC). 5 Bi-Polar -BP Optional MS402 All dimensions are in inches (mm) Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25) Specifications are subject to change without notice. 445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639 ww w.datadisplay.com © 2005 Data Display Products 73
MS402-A15-CW
1. 物料型号:MB402 Bayonet 和 MS402 Flange Screw,以及中心阴极选项(如MB402C)。 2. 器件简介:高亮度、宽角度的小型灯,适用于中到大型透镜应用。 3. 引脚分配:文档中提到了两种引脚配置,MB402和MS402,都具有中心阳极或中心阴极选项。 4. 参数特性:包括LED颜色、发光强度(Apk)、工作电压/电流(V/C Table),以及设计和最大电压/电流值。 5. 功能详解:提供了不同颜色LED的发光强度和电压/电流表,以及不同电压下的电压/电流设计规格。 6. 应用信息:适用于需要高亮度和宽角度照明的应用场合。 7. 封装信息:提供了封装尺寸和公差信息,以及制造商的联系信息。
MS402-A15-CW 价格&库存
很抱歉,暂时无法提供与“MS402-A15-CW”相匹配的价格&库存,您可以联系我们找货
