T-31/4 MINIATURE LAMP WITH LENS
Data Display Products
High Intensity, Wide Angle - For Medium to Large Lens Applications
- Fresnel Lens; Bayonet or Screw Base
1
TO ORDER, FOLLOW THE EXAMPLE:
Model[1]
MB402
MS402
Select one BOLD component from each SHADED column in the tables below.
Bayonet
Flange
Screw
LED
Voltage
Lens
Bi-Polar
3
1Model
2
4
5
MB402
-R
12
-CR
-BP
➜Part Number MB402-R12-CR-BP
2 LED
Color
-R
-O
-A
-G
-B
-W
-L
RED
ORG
AMB
GRN
BLU
CWHT
WWHT
λpk
Iv[2]
V/C
(nm)
(mcd)
Table[3]
634
609
592
520
465
2800 (*4)
2000 (*4)
2800 (*4)
2400 (*2)
700 (*2)
2500 (*2)
1800 (*2)
I
I
I
II
II
II
II
3
Voltage/Current
Design
Max
Vf/If
Vf/If
V/C Table I
5V/75mA
5.5V/85mA
6V/40mA
7V/60mA
12V/30mA
14V/40mA
15V/30mA
16.5V/35mA
24V/30mA
26V/35mA
28V/25mA
30V/28mA
48V/20mA
52V/22mA
60V/16mA
65V/18mA
120VAC/9.5mA 130VAC/10.5mA
Voltage[4]
5
6
12
15
24
28
48
60
120
4
Lens
-CR
Red
-CA
Amber
-CG
Green
-CB
Blue
-CW
Water
Clear
Voltage/Current
Design
Max
Vf/If
Vf/If
V/C Table II
5V/26mA
5.5V/35mA
6V/28mA
7V/39mA
12V/15mA
14V/22mA
15V/15mA
16.5V/19mA
24V/15mA
26V/18mA
28V/15mA
30V/18mA
48V/9mA
50V/9.5mA
60V/6.5mA
65V/7.2mA
120VAC/5mA
130VAC/5.5mA
MB402
[3] See Voltage/Current table for design specifications.
[1] MB402 and MS402 are center anode. Insert C after Model for center cathode (e.g. MB402C).
[2] Iv = typical luminous intensity @ If = 20mA (Ta=25°C). Luminous intensity is measured without
the lens. (*2) = 2 LEDs per package.
[4] Ta = 25°C. Voltages 6 through 60 are VDC. For AC operation, insert AC after the Voltage (e.g. 24AC),
not required for 120V. Contact factory for VAC design currents. For 120VDC insert DC after Voltage
(e.g. 120DC).
5
Bi-Polar
-BP
Optional
MS402
All dimensions are in inches (mm)
Tolerances: .xx"(.x) ±.025"(.63) / .xxx"(.xx)±.010"(.25)
Specifications are subject to change without notice.
445 S. Douglas Street, El Segundo, CA 90245-4630 • (800) 421-6815 • (310) 640-0442 • FAX (310) 640-7639
ww w.datadisplay.com
© 2005 Data Display Products
73
很抱歉,暂时无法提供与“MS402-A120AC-CW-BP”相匹配的价格&库存,您可以联系我们找货
