VBL3D0200C
VBL3D0200C
    VCC
    光导管 单路 透明 刚性 板式安装,压接式
VBL3D0200C 数据手册
VBL Series Ø 0.118″ (3mm) PCB Mounted Light Pipe for Surface Mount LED VBL Series features vertical press-fit board mount LED light pipes available in a range of different lengths with either a flat or a domed top. Applications • Audio/Video • Industrial Robots • Darkroom Equipment • Agriculture • Entertainment • Medical • IoT • Data Center Solutions • Transportation Power Systems Key Features • • • • • • • • • • • Rigid board mount light pipe for surface mount LEDs 3mm round lens with either a domed or flat face The VBL light pipes are mounted onto the PCB using push-fit lugs in close proximity to the LED Features a press-fit installation into the PCB board which simplifies installation and enables faster assembly Protects LED from ESD Optical grade PMMA for maximum light transmission Frosted surface diffuses light and provides uniform brightness and a soft glow Operating temp: Max 194F(90˚C) Standard lengths from 0.20″ to 1.000″ For custom length contact VCC RoHS and REACH Compliant vcclite.com | 1.800.522.5546 VBL Series | 09/22 Rev 3 | Page 1 of 4 Ordering Data Series Diameter Shape Overall Length Color VBL 3 D 0200 C 3 3mm D Dome 0200 .2″ (5.1mm) F Flat 0250 .25″ (6.4mm) 0300 .3″ (7.6mm) 0350 .35″ (8.9mm) 0400 .4″ (10.2mm) 0450 .45″ (11.4mm) 0500 .5″ (12.7mm) 0550 .55″ (13.9mm) 0600 .6″ (15.2mm) 0700 .7″ (17.8mm) 0800 .8″ (20.3mm) 0900 .9″ (22.8mm) 1000 1.0″ (25.4mm) C Clear *Custom lengths available upon request Example: VBL3D0900C VBL Series, PCB mount, .9″ (22.8mm) Overall Length, Dome Shape, Clear vcclite.com | 1.800.522.5546 VBL Series | 09/22 Rev 3 | Page 2 of 4 Product Dimensions VBL Series RED LINES ARE REPRESENTED FLAT SERIES Overall Length (OL) .2″ (5.1mm) .25″ (6.4mm) .3″ (7.6mm) .35″ (8.9mm) .4″ (10.2mm) .45″ (11.4mm) .5″ (12.7mm) .55″ (13.9mm) .6″ (15.2mm) .7″ (17.8mm) .8″ (20.3mm) .9″ (22.8mm) 1.0″ (25.4mm) Mounting Hole Pattern Notes: 1. All dimensions are in inches [millimeters] 2. The specifications, characteristics and technical data described in the datasheet are subject to change without prior notice. vcclite.com | 1.800.522.5546 VBL Series | 09/22 Rev 3 | Page 3 of 4 Product Specifications Materials PMMA, Optically clear Body Temperature Specifications Operating Temperature Max 194F(90˚C) Installation Specifications Diameter Ø 0.117″ ± 0.002 Standard Lengths .2″ to 1.0″ (5.1mm to 25.4mm) Compliances and Approvals vcclite.com | 1.800.522.5546 VBL Series | 09/22 Rev 3 | Page 4 of 4
VBL3D0200C 价格&库存
很抱歉,暂时无法提供与“VBL3D0200C”相匹配的价格&库存,您可以联系我们找货
