1IC03622051706
1IC03622051706
    CHOGORI(乔合里)
    缆线组件 1.64'(500.00mm)
1IC03622051706 数据手册
4 6P 3 2 4 BLK 5P 6 5 4 3 6 2 1 1 Pin VIOLET GREEN BLACK BLUE YELLOW RED Color 5 4 3 2 1 Pin BLACK WHITE BROWN ORANGE RED Color 4 3 2 1 Pin WHITE BROWN ORANGE RED Color 5 5 3 2 3 2 GEN 1 4P BLK 3P 2 BLK 2 1 Connector P/N 40002153 -01-001 40003153 -01-001 40004153 -01-001 40005153 -01-001 40006153 -01-001 Position NO Cable 2 900-00201-00112 NOUL 2C*26AWG TPU OD3.1 3 900-00301-00093 NOUL 3C*26AWG TPU OD3.1 4 900-00401-00146 NOUL 4C*0.14mm² TPU OD3.7 5 900-00501-00056 NOUL 5C*0.14mm² TPU OD3.7 6 900-00601-00062 NOUL 6C*26AWG TPU OD4.1 Ø9.0REF Product P/N 1IC03622051706 1IC03622051707 1IC03622051708 1IC03622051709 1IC03622051710 CABLE 1: 35.0REF REV. ECN NO. C1 DATE NA SIGN DESCRIPTION XU 2022/08/15 First Version *500±30 5.5REF ①② ③ Connector P/N See CABLE 1 4 1 Specification: 1.Operating temperature:-25℃~+80℃. 2.Current Rating: 2A 3.Voltage Rating:48VAC ,60VDC. 4.Insulation resistance:10MΩ at 300VDC. 5.Mating cycles:200cycles. 6.Waterproof:IP66(Mated). 7.RoHS compliant. 3 1 3 BLUE 2 YELLOW 1 RED Pin Color 2P BLK 2 YELLOW 1 RED Pin Color 900-00***-00*** A/R M Cable 2C~6C Range Maxφ4.5 0.14mm2~0.2mm2 Other Requirements Can Be Customized 2 504-00011-00 A/R M HEAT SHRINK TUBE OD1.5 1 4000*153-01-001 No. Material No. 1 PC Micro Series * Pin Male Connector Material Description Q'ty Unit Material List TITLE UNIT:mm 3 Micro series molding socket male connector SCALE SHEET N/A 1 of 1 REV. SIZE C1 A4 ITEM NO. DWG NO. Chogori Technology Co., Ltd 1IC036220517** 1IC036220517** CUSTOMER NO. REV. DRAWN BY DATE XU CHECKED BY DATE Kevin APPROVED BY DATE 2022/08/15 2022/08/15
1IC03622051706 价格&库存
很抱歉,暂时无法提供与“1IC03622051706”相匹配的价格&库存,您可以联系我们找货
