482W101-26-CA-003
482W101-26-CA-003
    CICOIL
    26 矩形电缆组件 插口至插口 3.00'(914.40mm)
482W101-26-CA-003 数据手册
Ultra Flexible Micro IDC Ribbon Cable ■■ Light, flexible design routes easily in tight spaces Pitch works with any Micro IDC connector ■■ Standard sizes available with up to 64 conductors ■■ Rated for Temperatures from -65°C to +260°C ■■ .025˝ Cicoil’s .025˝ Micro IDC Cable is excellent for tight spacing applications that require dependable signal density. The Ultra Flexible cable performs exceptionally well in harsh environments, including high/low temperatures, and under exposure to moisture and most chemicals. UL REACH COMPLIANT FAA FLAME TESTED Dimensions Amp Rating1 0.2 Dimensions Volts DC No. of Conductors Width Span Height Part Number 3K 10 14 16 20 26 28 30 34 40 44 50 60 64 0.250˝ 0.350˝ 0.400˝ 0.500˝ 0.650˝ 0.700˝ 0.750˝ 0.850˝ 1.000˝ 1.100˝ 1.250˝ 1.500˝ 1.600˝ 0.225˝ 0.325˝ 0.375˝ 0.475˝ 0.625˝ 0.675˝ 0.725˝ 0.825˝ 0.975˝ 1.075˝ 1.225˝ 1.475˝ 1.575˝ 0.026˝ 0.026˝ 0.026˝ 0.026˝ 0.026˝ 0.026˝ 0.026˝ 0.026˝ 0.026˝ 0.026˝ 0.026˝ 0.026˝ 0.026˝ 482W101-10 482W101-14 482W101-16 482W101-20 482W101-26 482W101-28 482W101-30 482W101-34 482W101-40 482W101-44 482W101-50 482W101-60 482W101-64 Note 1. Amp rating is the maximum value for each conductor at room temperature of 70°F (21°C). Amp rating decreases as temperature increases. WIDTH SPAN HEIGHT Cable Assemblies Please contact Cicoil for other connectors and length options. Cable Length (feet) Part Number Addition 3 6 12 -CA003 -CA006 -CA012 Notes 1. Append onto base cable Part Number for complete assembly. Example: 482W101-10-CA003 2. Connector ratings may differ from cable ratings; refer to manufacturer specifications. Assembly Dimensions J1 J1 A A CABLE LENGTH B B Connectors • Signal (J1): CnC Tech or equivalent (XX = Position Quantity) .025˝ Pitch: P/N 3230-XX-0103-00 Cable Specifications Mechanical Conductors: Ultra flexible, finely stranded, bare copper Minimum Bend Radius: - 6x cable height for intermediate flex - 10x cable height for continuous flex Outer Jacket Durometer Rating: 65 (Shore A) All engineering values are nominal and subject to change. Environmental Temperature Rating: -65°C to +260°C Moisture Rating: Submersible, Salt Water Resistant Clean Room Rating: Class 1, Zero Particulates Extreme Environments: Sunlight, UV Light, Alcohol, Chemical and Oil Resistant Electrical Operating Voltage: 300 Outer Jacket Dielectric Strength: 450 volts/mil (17.7 kv/mm) See Electrical Rating Chart on Page 47 Flexible Flat Cables & Cable Assemblies Micro Ribbon / p1of1 / 26-MAR-18 Options Page Additional Conductors Low Friction Options StripMount™ Integrated Mounting Strip Integrated Tubing SuperTuff™ Jacket Colored Jacketing Strip and Tin Cable Ends FlexRail™ Self-Supporting Cable Complete Assembly 661-295-1295 n Cicoil.com 26 28 28 29 29 29 29 30 31 23 Unshielded 30 AWG .025˝ COMPLIANT Applications Aerospace, Robotics, Medical, Semiconductor, Surgical Systems, Printer Head, Satellites, Board-to-Board Cable Gauge Pitch RoHS MEETS 94V-0
482W101-26-CA-003
物料型号:文档中列出了不同规格的电缆型号,例如482W101-10、482W101-14等,这些型号根据导体数量和尺寸有所不同。
器件简介:ECICOIL的.025英寸Micro IDC电缆适用于需要高信号密度的紧密空间应用。这种超柔性电缆在恶劣环境下表现优异,包括高/低温、潮湿以及大多数化学物质的暴露。
引脚分配:文档中没有明确提供引脚分配的详细信息,但提到了电缆的导体数量,从10到64不等。
参数特性:电缆的额定温度范围为-65°C至+260°C。还提供了不同规格电缆的尺寸,包括宽度、跨度和高度。
功能详解:电缆设计轻巧灵活,易于在狭小空间布线,并且具有出色的耐化学和耐温性能。
应用信息:适用于航空、机器人、医疗、半导体、手术系统、打印机头、卫星和板对板等多种应用场景。
封装信息:文档提供了不同规格电缆的尺寸和型号,以及未屏蔽电缆的组装选项和连接器长度选项。
482W101-26-CA-003 价格&库存
很抱歉,暂时无法提供与“482W101-26-CA-003”相匹配的价格&库存,您可以联系我们找货
482W101-26-CA-003
  • 46+155.1075546+19.40703
