.155 .015
.236
REV
ECO
DATE
1
INITIAL RELEASE
02JUL2020
.221 .010
.020
4X
o.036
.003
.038
.001
4X .104
NOTES: UNLESS OTHERWISE SPECIFIED.
1. MATERIAL & FINISH:
1.1 BODY: (133-3701-291) GOLD PLATED BRASS
1.2 INSULATORS: PTFE (TEFLON)
1.3 CENTER CONTACT: GOLD PLATED BERYLLIUM COPPER
2. ELECTRICAL SPECIFICATIONS:
2.1 IMPEDANCE: 50 OHMS
2.2 FREQUENCY RANGE: 0 - 6 GHz
2.3 WORKING VOLTAGE: 335 VRMS MAX AT SEA LEVEL
2.4 DIELECTRIC WITHSTANDING VOLTAGE: 1000 VRMS MIN AT SEA LEVEL
2.5 INSULATION RESISTANCE: 10000 MEGOHM MIN
2.6 CONTACT RESISTANCE:
CENTER CONTACT - INITIAL 5 MILLIOHM MAX, AFTER
ENVIRONMENTAL 8 MILLIOHM MAX
OUTER CONDUCTOR - GOLD AND SILVER PLATED INITIAL 1 MILLIOHM MAX,
ENVIRONMENTAL 1.5 MILLIOHM MAX
NICKEL PLATED INITIAL 2.5 MILLIOHM MAX, AFTER
ENVIRONMENTAL 3.5 MILLIOHM MAX
2.7 CORONA LEVEL: 250 VOLTS MIN AT 70,000 FEET
2.8 RF HIGH POTENTIAL WITHSTANDING VOLTAGE: 600 VRMS AT 4 AND 7 MHz
3. MECHANICAL SPECIFICATIONS:
3.1 ENGAGE/DISENGAGE FORCE: 5.6 LBS MAX ENGAGEMENT
1.0 LBS MIN DISENGAGEMENT
8.0 LBS MAX DISENGAGEMEN
3.2 CONTACT RETENTION FORCE: 2.3 LBS MIN
3.3 DURABILITY: 500 CYCLES MIN
4. ENVIRONMENTAL:
4.1 (MEETS OR EXCEEDS THE APPLICABLE PARAGRAPH OF MIL-PRF-39012)
4.2 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION F
4.3 OPERATING TEMPERATURE: -65 DEG C TO 165 DEG C
4.4 CORROSION: MIL-STD-202, METHOD 101, CONDITION B
4.5 SHOCK:MIL-STD-202, METHOD 213, CONDITION B
4.6 VIBRATION: MILSTD-202, METHOD 204CONDITION B
4.7 MOISTURE RESISTANCE:MIL STD-202, METHOD 106
.200
.003
.100 .003
4X
n.067
.003
.100 .003
AFTER
.068
.003 (SOLDER PAD)
SCALE 4:1
MOUNTING HOLE LAYOUT
Model No:
This PROPRIETARY Document is
property of Cinch Connectivity
Solutions.It is confidential
in nature, non-transferable,
and issued with the clear
understanding that it is not
traced or copied without
permission and is returnable
upon demand.
INTERPRET DRAWING IN
ACCORDANCE WITH
ASME Y14.5-2009.
Cage Code
(EU)/2015/863
COMPLIANT
UNITS: INCH
.XX
.XXX
.XXXX
ANGLE
JOHNSON
133-3701-291/299
RoHS
.01
.003
.0010
2 ¥
Title:
JACK ASSEMBLY
STRAIGHT SURFACE MOUNT MCX
3RD ANGLE PROJECTION
Drawing No.
Drawn by:
Date:
7/2/2020
REV.
133-3701-291/299
Roman.Yao
Size
B
DO NOT SCALE
DRAWING
Workmanship Std:
NONE
1
Sheet
1 OF 1
很抱歉,暂时无法提供与“133-3701-291”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+68.316081+8.83851
