133-3711-321
133-3711-321
    CINCH
    插件
    MCX 连接器 插孔,母形插口 50 欧姆 通孔,直角 焊接
133-3711-321 数据手册
.374 REV ECO DATE 1 INITIAL RELEASE  02JUL2020 .010 .138 .005 .213 .015 .118 .010 .020 .005 .155 .015 .038 SCALE 4:1 NOTES: UNLESS OTHERWISE SPECIFIED.    1.  MATERIAL & FINISH:     1.1  BODY: (133-3711-321) GOLD PLATED BRASS     1.2  INSULATORS: PTFE (TEFLON)     1.3  CENTER CONTACT: GOLD PLATED BERYLLIUM COPPER    2.  ELECTRICAL SPECIFICATIONS:     2.1  IMPEDANCE: 50 OHMS     2.2  FREQUENCY RANGE: 0 - 6 GHz     2.3  WORKING VOLTAGE: 335 VRMS MAX AT SEA LEVEL     2.4  DIELECTRIC WITHSTANDING VOLTAGE: 1000 VRMS MIN AT SEA LEVEL     2.5  INSULATION RESISTANCE: 10000 MEGOHM MIN     2.6  CONTACT RESISTANCE:               CENTER CONTACT - INITIAL 5 MILLIOHM MAX, AFTER                                 ENVIRONMENTAL 8 MILLIOHM MAX               OUTER CONDUCTOR - GOLD AND SILVER PLATED INITIAL 1 MILLIOHM MAX,                                  ENVIRONMENTAL 1.5 MILLIOHM MAX                                 NICKEL PLATED INITIAL 2.5 MILLIOHM MAX, AFTER                                 ENVIRONMENTAL 3.5 MILLIOHM MAX     2.7  CORONA LEVEL: 250 VOLTS MIN AT 70,000 FEET     2.8  RF HIGH POTENTIAL WITHSTANDING  VOLTAGE: 600 VRMS AT 4 AND 7 MHz    3.  MECHANICAL SPECIFICATIONS:     3.1  ENGAGE/DISENGAGE FORCE: 5.6 LBS MAX ENGAGEMENT                                1.0 LBS MIN DISENGAGEMENT                                8.0 LBS MAX DISENGAGEMEN     3.2  DURABILITY: 500 CYCLES MIN    4. ENVIRONMENTAL:     4.1  (MEETS OR EXCEEDS THE APPLICABLE PARAGRAPH OF MIL-PRF-39012)     4.2  THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION F     4.3  OPERATING TEMPERATURE: -65 DEG C TO 165 DEG C     4.4  CORROSION: MIL-STD-202, METHOD 101, CONDITION B     4.5  SHOCK:MIL-STD-202, METHOD 213, CONDITION B     4.6  VIBRATION: MILSTD-202, METHOD 204CONDITION B     4.7  MOISTURE RESISTANCE:MIL STD-202, METHOD 106 4X  .104 .005 4X  .001 o.036 .200 .003 .003 .100 .003 .236 .005 .100 .003 4X  n.067 .003 .068 AFTER .003  (SOLDER PAD) MOUNTING HOLE LAYOUT Model No: This PROPRIETARY Document is property of Cinch Connectivity Solutions.It is confidential in nature, non-transferable, and issued with the clear understanding that it is not  traced or copied without permission and is returnable upon demand.   INTERPRET DRAWING IN ACCORDANCE WITH ASME Y14.5-2009. Cage Code (EU)/2015/863 COMPLIANT UNLESS OTHERWISE SPECIFIED UNITS: INCH .XX    .XXX   .XXXX  ANGLE  JOHNSON 133-3711-321/330  RoHS # # # #  .01  .003  .0010  2 ¥   Title: JACK ASSEMBLY  RA SURFACE MOUNT MCX 3RD ANGLE PROJECTION Drawing No. Drawn by: Date: 7/2/2020 REV. 133-3711-321/330 Roman.Yao Size B DO NOT SCALE DRAWING Workmanship Std:  NONE 1 Sheet 1  OF  1
133-3711-321 价格&库存
很抱歉,暂时无法提供与“133-3711-321”相匹配的价格&库存,您可以联系我们找货
