PART NUMBER
ITEM
BODY
134-1019-461
BERYLLIUM COPPER
GOLD PL .00005 MIN OVER
NICKEL PL .00005 MIN OVER
COPPER PL .00005 MIN
1
ITEM 2
CONTACT
ITEM 3
INSULATOR
4
ITEM
ANTI-ROCK RING
BERYLLIUM COPPER
TEFLON
BERYLLIUM COPPER
GOLD PL .00003 MIN OVER
.529
REV
ECO
DATE
1
2
3
INITIAL RELEASE
EC-1906003
EC-1908012
26FEB2019
04JUN2019
29AUG2019
.020
4
1
2
HEX .218 REF
3
NOTES:
1. ELECTRICAL SPECIFICATIONS:
1.1 IMPEDANCE: 50 OHMS
1.2 FREQUENCY RANGE: 0-26.5 GHz
1.3 VSWR: 1.20 MAX. 0-20 GHz
1.25 MAX. 20-26.5 GHz
1.4 WORKING VOLTAGE: 335 VRMS MAX AT SEA LEVEL
1.5 DIELECTRIC WITHSTANDING VOLTAGE: 1000 VRMS MIN AT SEA LEVEL
1.6 INSULATION RESISTANCE: 10000 MEGOHM MIN
1.7 CONTACT RESISTANCE:
1.7.1 CENTER CONTACT - INTIAL 5 MILLIOHM MAX, AFTER
ENVIRONMENTAL 8 MILLIOHM MAX
1.7.2 OUTER CONDUCTOR - GOLD PLATED INITIAL 1 MILLIOHM MAX, AFTER
ENVIRONMENTAL 1.5 MILLIOHM MAX
1.8 CORONA LEVEL: 250 VOLTS MINIMUM AT 70,000 FEET
INSERTION LOSS: .1 dB MAX AT 1GHz
RF LEAKAGE: -50 dB AT 2.5 GHz
RF HIGH POTENTIAL WITHSTANDING VOLTAGE: 700 VRMS AT 4 AND 7 MHz
2. MECHANICAL SPECIFICATIONS:
2.1 ENGAGE/DISENGAGE FORCE (SMP): 3.4 LBS MAX ENGAGEMENT
5 LBS TYPICAL DISENGAGEMENT
2.2 ENGAGE/DISENGAGE TORQUE (SMA): 2 IN LBS MAX
2.3 MATING TORQUE (SMA): 7-10 IN LBS MAX
2.4 CONTACT RETENTION FORCE: 6 LBS MIN
2.5 DURABILITY: 500 CYCLES MIN
3. ENVIRONMENTAL:
(MEETS OR EXCEEDS THE APPLICABLE PARAGRAPH OF MIL-PRF-39012)
3.1 THERMAL SHOCK: MIL-STD-202, METHOD 107, CONDITION B
3.2 OPERATING TEMPERATURE: -65 ¥ C TO 165 ¥ C
3.3 CORROSION: MIL-STD-202, METHOD 101, CONDITION B
3.4 SHOCK: MIL-STD-202, METHOD 213, CONDITION B
3.5 VIBRATION: MIL-STD-202, METHOD 204, CONDITION B
3.6 MOISTURE: MIL-STD-202, METHOD 106
SCALE 4:1
Model No:
This PROPRIETARY Document is
property of Cinch Connectivity
Solutions.It is confidential
in nature, non-transferable,
and issued with the clear
understanding that it is not
traced or copied without
permission and is returnable
upon demand.
INTERPRET DRAWING IN
ACCORDANCE WITH
ASME Y14.5-2009.
JOHNSON
134-1019-461/470
RoHS2
Cage Code
2011/65/EU
UNLESS OTHERWISE SPECIFIED
UNITS: INCH
Title:
ASSEMBLY, ADAPTER BETWEEN SERIES
SMA JACK TO SMP JACK
3RD ANGLE PROJECTION
Drawing No.
Drawn by:
.XX # .02
.XXX # .010 Date:
ANGLES # 2 ¥
2/26/2019
REV.
134-1019-461/470
Roman. Yao
Size
B
DO NOT SCALE
DRAWING
Workmanship Std:
NONE
3
Sheet
1 OF 1
很抱歉,暂时无法提供与“134-1019-461”相匹配的价格&库存,您可以联系我们找货
