DCDM25CS
DCDM25CS
    CINCH
    适配器连接器 D-Sub,25 母型引脚 至 D-Sub,25 公型引脚 自由悬挂
DCDM25CS 数据手册
Connector Savers Micro-D, 0.050” Pitch, Connector Saver Cinch DURA-CON Micro-D connector savers reduce damage to installedconnectors during routine systems tests. The connector savers eliminate numerous mating and unmating cycles experienced by connectors on test harnesses. Locking hardware must be ordered seperately. Contact reliability is assured with the Twist Pin design that provides 7 points of contact when mated. Features • Designed to significantly reduce damage to already mounted Dura-Con connectors during routine system tests. • Eliminates numerous mating & unmating cycles experienced by connectors on test harnesses. • Plug connector on one end, socket connector on the other. • Available in all-plastic (polyester) or in metal shell with diallyl phthalate or polyester insulators (both UL94V-0 rated). • Locking hardware must be ordered separately. Materials Insulator UL94V-0 glass-filled polyester or diallyl phthalate Contacts Copper alloy Contact Plating 0.000050 in gold Shell (Metal Only) Aluminum alloy Shell Plating Yellow chromate over cadmium Environmental Operating Temperature -55°C to +135°C Electrical Current Rating 3 Amps maximum Withstanding Voltage 600 VAC RMS @ sea level Contact Resistance 8 milliohms maximum Mechanical Individual Contact Insertion force, 6 oz. (170.40 g) maximum; Withdrawal force 0.5 oz. (14.20 g) minimum belfuse.com/cinch SPECIFICATIONS Dura-Con, micro-d connnector savers No of Positions Glass-Filled Polyester Catalog No Mates to 9 DCDM9CS DCCM9P*, DCCM9S*, DCDM9P*, DCDM9S*, M83513/01-A*, M83513/02-A*, M83513/03-A*, M83513/04-A*, M83513/10-A*, M83513/13-A*, M83513/16-A*, M83513/19-A*, M83513/22-A*, M83513/25-A* 15 DCDM15CS DCCM15P*, DCCM15S*, DCDM15P*, DCDM15S*, M83513/01-B*, M83513/02-B*, M83513/03-B*, M83513/04-B*, M83513/10-B*, M83513/13-B*, M83513/16-B*, M83513/19-B*, M83513/22-B*, M83513/25-B* 21 DCDM21CS DCCM21P*, DCCM21S*, DCDM21P*, DCDM21S*, M83513/01-C*, M83513/02-C*, M83513/03-C*, M83513/04-C*, M83513/10-C*, M83513/13-C*, M83513/16-C*, M83513/19-C*, M83513/22-C*, M83513/25-C* 25 DCDM25CS DCCM25P*, DCCM25S*, DCDM25P*, DCDM25S*, M83513/01-D*, M83513/02-D*, M83513/03-D*, M83513/04-D*, M83513/10-D*, M83513/13-D*, M83513/16-D*, M83513/19-D*, M83513/22-D*, M83513/25-D* 31 DCDM31CS DCCM31P*, DCCM31S*, DCDM31P*, DCDM31S*, M83513/01-E*, M83513/02-E*, M83513/03-E*, M83513/04-E*, M83513/10-E*, M83513/13-E*, M83513/16-E*, M83513/19-E*, M83513/22-E*, M83513/25-E* 37 DCDM37CS DCCM37P*, DCCM37S*, DCDM37P*, DCDM37S*, M83513/01-F*, M83513/02-F*, M83513/03-F*, M83513/04-F*, M83513/10-F*, M83513/13-F*, M83513/16-F*, M83513/19-F*, M83513/22-F*, M83513/25-F* 51 DCDM51CS DCCM51P*, DCCM51S*, DCDM51P*, DCDM51S*, M83513/01-G*, M83513/02-G*, M83513/03-G*, M83513/04-G*, M83513/11-G*, M83513/14-G*, M83513/17-G*, M83513/20-G*, M83513/23-G*, M83513/26-G* 100 DCDM100CS DCCM100P*, DCCM100S*, DCDM100P*, DCDM100S*, M83513/01-H*, M83513/02-H*, M83513/03-H*, M83513/04-H*, M83513/12-H*, M83513/15-H*, M83513/18-H*, M83513/21-H*, M83513/24-H*, M83513/27-H* Asia Pacific +86 21 5442 7668 ccs.asia.sales@as.cinch.com Europe, Middle East & Africa +44 (0) 1245 342060 CinchConnectivity@eu.cinch.com North America +1 507.833.8822 inquiry@us.cinch.com belfuse.com/cinch ©2020 Cinch Connectivity Solutions ds-ccs-duracon-connector-saver-05112020
DCDM25CS 价格&库存
很抱歉,暂时无法提供与“DCDM25CS”相匹配的价格&库存,您可以联系我们找货
DCDM25CS
  • 1+1486.361411+191.62066
  • 10+1263.5118010+162.89105
  • 25+1184.5010125+152.70503
  • 50+1128.0480950+145.42716
库存:98
DCDM25CS
    库存:60
