DCDC100GP6K5-36.0ANLG
    CINCH
    MICRO-D CBL 100POS PLUG-PLUG 36"
DCDC100GP6K5-36.0ANLG 数据手册
Shielded Cable Assemblies EMI Pigtails MIL-STD-83513 Cable Assemblies Cinch DURA-CON D-shaped micro miniature rectangular connectors are designed for applications that require a rugged, high performance, densely compacted interconnect. DURA-CON is the ideal connector for applications where weight and space must be kept to a minimum while maintaining maximum reliability. Reliability is assured with the unique twist pin providing 7 points of contact when mated. Qualified (QPL) to MIL-DTL-83513, micro-D DURA-CON are one of the most widely used 0.05in (1.27mm) pitch connectors. Typical applications for these connectors are miniaturized military and aerospace electronics and data processing equipment, where shorter signal paths are needed Features • MIL-DTL-83513 • 78 ohm twinax cable • 50 and 75 ohm triax cable • 50 and 75 ohm triax cable Materials Connector Shell ASTM Alloy< SAE-AMS-QQ-A-250. Cadmium per SAE-AMS-QQ-P-416. Electroless Nickel per SAE-AMS-C-26074. Gold per MIL-G-45204 Contact (Male Pins) Copper Alloy. Gold per MIL-DTL-45204, Type 1 Contact (Female Sockets) Copper Alloy. Gold per MIL-DTL-45204, Type 1 Insulator PBT< per MIL-M-24519 or >DAP< PER ASTM-D5948 Hardware 303SS< Passivate Dip per SAE-AMS-QQ-P-35 Interfacial Gasket FVMQ< per MIL-R-25988 or >PMQ< PER ZZ-R-765 Dustcap LDPE< or anti-static >HDPE< Wire See sales code nomenclature Electrical Current Rating 3 AMP MAX Temperature Rating -55 °C TO +135 °C Insulation Resistance 5000 mΩ min DWV at Seal Level 600 Vac DWV 70,000 feet Altitude 150 Vac Contact Resistance 8 mΩ max belfuse.com/cinch COLOUR COLOUR COLOUR COLOUR COLOUR CHD APP'D CHD APP'D CH 4:1 4:1 CH 4:1 4:1 AP AP COLOUR 2 DEC. 22 DEC. PL. 0.1 0.1 DEC. DEC. PL.PL. PL. DRN 0.1 0.1MATLM.BARRACLOUGH 0.5 RAW 10 DEC.2PL. 0.2 DRN DRN M.BARRACLOUGH DATE DATE 25-Feb-16 SCALE SCALE M.BARRACLOUGH M.BARRACLOUGH DATE 25-Feb-16SCALE 11 DEC. 1 DEC. PL. PL. 0.2 0.2 DRN DRN DATE SCALE M.BARRACLOUGH 25-Feb-16 25-Feb-16 DEC. 1 DEC. PL.PL. 0.2 0.2MATL 1 RAW 0ANGULAR DEC. PL. 0.5 MATERIAL MATERIAL SPECIFICATION SPECIFICATION MATERIAL MATERIAL SPECIFICATION FINISHED HARDNESS FINISHSPECIFICATION TREATMENT RAW RAW MATL MATL 00 DEC. 0 DEC. PL. PL. 0.5 0.5 RAW MATL MATL DEC. 0 DEC. PL. PL.1 0.5 0.5 RAW TOOL R MAX. 0.18 ANGULAR FINISHED HARDNESS FINISH TREATMENT ANGULAR ANGULAR 11 11 ANGULAR ANGULAR TOOL R MAX. 0.18 FINISHED FINISHED HARDNESS HARDNESS FINISH FINISH TREATMENT TREATMENT FINISHED FINISHED HARDNESS HARDNESS FINISH FINISH TREATMENT TREATMENT TOOL TOOL R MAX. MAX. 0.18 TOOL TOOL RR R MAX. MAX. 0.18 0.18 0.18 INTEGRAL SHIELD TERMINATION MICROMINIATURE MICROMINIATURE 9-51W CABLE ASSEMBLY MICROMINIATURE MICROMINIATURE DATE SHIELDED SCALE 25-Feb-16 4:1 MATERIAL SPECIFICATION 9-51W 9-51W SHIELDED SHIELDED CABLE CABLE ASSEMBLY INTEGRAL SHIELD TERMINATION 9-51W 9-51W SHIELDED SHIELDED CABLE CABLEASSEMBLY ASSEMBLY ASSEMBLY DATEINTEGRAL 25-Feb-16 SCALE 4:1 INTEGRAL SHIELD SHIELD TERMINATION TERMINATION INTEGRAL INTEGRAL SHIELD SHIELDTERMINATION TERMINATION MATERIAL SPECIFICATION TITLE TITLE GEN. GEN. TOLERANCES TOLERANCES TITLE TITLE M.BARRACLOUGH GEN. TOLERANCES TOLERANCES 0.2 DRN 21 DEC.GEN. PL. 0.1 OVERALL OVERALL LENGTH LENGTH 0.25"0.25" 5. 6. CONTACT PINS): 5. >CuCONTACT ALLOYCu ALLOYCu MIL-DT 6. 7. CONTACT (FEMALE SOCKETS): 6.MIL-M-24519 CONTACT >Cu ALLOYPBT< PER 7. INSULATOR: OR >PBT< >DAP< PERMIL-M-2 ASTM 7. 8. INSULATOR: PER 7. INSULATOR: >PBT< >DAP< PER PER MIL-M-2 ASTM HARDWARE: >PBT< >303SS< PASSIVATE 8.MIL-M-24519 HARDWARE: DIPOR PER >303SS< SAE-AMS-QQ-P PASSIVAT 8. 9. HARDWARE: 8. HARDWARE: DIPMIL-R-25988 PER >303SS< SAE-AMS-QQ-P PASSIVAT INTERFACIAL>303SS< GASKET:PASSIVATE 9. >FVMQ< INTERFACIAL PER GASKET: OR >FVMQ< >PMQ 9. INTERFACIAL GASKET: 9. >FVMQ< INTERFACIAL PER >HDPEFVMQ< >PMQ 10. DUSTCAP: >LDPE< OR 10. ANTI-STATIC DUSTCAP: >LDPE< OROR ANTI-ST 10. OR 10. ANTI-STATIC DUSTCAP: >HDPELDPE< OR ANTI-ST 11. DUSTCAP: WIRE: SEE >LDPE< SALES-CODE 11. NOMENCLATURE. WIRE: SEE SALES-CODE NOME 11. WIRE: SEE SALES-CODE 11. NOMENCLATURE. WIRE: SEE SALES-CODE NOME PERFORMANCE SPECIFICATIONS: PERFORMANCE SPECIFICATIONS: PERFORMANCE SPECIFICATIONS: PERFORMANCE SPECIFICATIONS: MICRO-D CONNECTORS SHALL MICRO-D MEETCONNECTORS GENERAL ENVIRONMENT SHALL MEE SEE PERFORMANCE PERFORMANCE OF MIL-DTL-83513. DETAILOF MIL-DTL-83513. MICRO-D CONNECTORS SHALL MICRO-D MEETCONNECTORS GENERAL ENVIRONMENT SHALL MEE SEE A PERFORMANCE OF MIL-DTL-83513. PERFORMANCE OF MIL-DTL-83513. DETAIL CURRENT RATING: 3 AMP MAX. CURRENT RATING: 3 AMP MAX. A TEMPERATURE RATING: -55TEMPERATURE °C TO +135 °C. RATING: -55 °C TO + CURRENT RATING: 3 AMP MAX. CURRENT RATING: 3 AMP MAX. INSULATION RESISTANCE: 5000 INSULATION M MIN. RESISTANCE: 5000 M TEMPERATURE RATING: TEMPERATURE °C TO RATING: °C TO + DWV AT SEA LEVEL: 600 -55 VAC. DWV AT+135 SEA°C. LEVEL: 600 -55 VAC. INSULATION RESISTANCE: 5000 INSULATION M MIN. RESISTANCE: 5000 M DWV 70,000 FT ALTITUDE: 150 DWV VAC. 70,000 FT ALTITUDE: 150 VAC. DWV AT SEA LEVEL: 6008VAC. DWVMAX. AT SEA LEVEL: 6008VAC. CONTACT RESISTANCE: mCONTACT RESISTANCE: m MAX DWV 70,000 FT ALTITUDE: 150 DWV VAC. 70,000 FT ALTITUDE: 150 VAC. CONTACT 8 mCONTACT MAX. RESISTANCE: 8 m MAX GENERAL RESISTANCE: SPECIFICATIONS: GENERAL SPECIFICATIONS: ISSUE ISSUE ISSUE ISSUE NPNR ECN ISSUE NPNR NPNR NPNR NPNR ECN ECN ECN ECN ISSUE HEAD HEXHEX HEAD HEX HEAD JACKPOST JACKSCREW JACKSCREW (P) JACKSCREW HEX HEAD HEX(NON-REMOVEABLE) HEAD HEX HEAD JACKPOST CIRCLIP CIRCLIP JACKSCREW JACKSCREW JACKSCREW (P) (M) (L) (M) (NON-REMOVEABLE) CIRCLIP CIRCLIP (M) (L) (M) L L L 2:1 M J K L J K H G J J CIRCLIP CIRCLIP (S) (S) JACKSCREW JACKSCREW (S) (S) CIRCLIP CIRCLIP (S) (S) M SCALE 2:1 K SLOT SLOTHEAD HEAD SCALE 2:1 K DATE DATE DATE DATE NPNR DATE ECN APP'D APP'D APP'D APP'D GENERAL SPECIFICATIONS: GENERAL SPECIFICATIONS: 12. ALL OTHER DETAILS AND 12. DIMENSIONS ALL OTHER DETAILS TO BE ASAND PERDIME MILOR CINCH DURA-CON CATALOGUE. OR CINCH DURA-CON CATALOG 12. ALL OTHER DETAILS AND 12. DIMENSIONS ALL OTHER DETAILS TO BE ASAND PERDIME MILOR CINCH DURA-CON CATALOGUE. OR CINCH DURA-CON CATALOG P P P PP P NN N N SCALE SCALE 2:1 2:1 N M M L L LL LL MM M M SCALE SCALE 2:1 2:1 SCALE SCALE 2:1 2:1 KK K K K K J J JJ JJ HH H H H SCALE SCALE 2:1 2:1 MOUNT MOUNT (R) (R) PANEL REAR REAR PANEL (R) (R) MOUNT MOUNT (R) (R) G F SCALE SCALE 2:1 2:1 SCALE SCALE 2:1 2:1 MATERIAL SPECIFICATIONS: MATERIAL SPECIFICATIONS: 4. CONNECTOR SHELL: >ASTM 4. CONNECTOR ALLOY< SAE-AMS-QQ-A-250. SHELL: >ASTM AL CADMIUM PER SAE-AMS-QQ-P-416. CADMIUM PER SAE-AMS-QQ-P-4 4. CONNECTOR SHELL: 4. CONNECTOR ALLOY< SAE-AMS-QQ-A-250. SHELL: AL ELECTROLESS Ni PER>ASTM SAE-AMS-C-26074. ELECTROLESS Ni PER>ASTM SAE-AMS CADMIUM SAE-AMS-QQ-P-416. CADMIUM SAE-AMS-QQ-P-4 GOLD PERPER MIL-G-45204. GOLD PERPER MIL-G-45204. ELECTROLESS Ni PER SAE-AMS-C-26074. ELECTROLESS Ni PER SAE-AMS PER(MALE MIL-G-45204. GOLD PERAu MIL-G-45204. 5. GOLD CONTACT PINS):5. >CuCONTACT ALLOYCu ALL FLOAT FLOAT MOUNT MOUNT SLOT HEAD SLOT HEAD Jackscrew Slot Head SCALE 2:1 SCALE Float Mount REAR REAR PANEL PANEL JACKSCREW JACKSCREW REAR PANEL REAR PANEL JACKSCREW JACKSCREW with Circlip (Rear Panel Mount) SLOT MOUNT MOUNT CIRCLIP CIRCLIP FLOAT FLOAT MOUNT MOUNT SLOT HEAD HEAD H F G E G F D E C D B C A E F D E C D B C A A B (P) (P) CUSTOMER ONLY. 2. CUSTOMER NOT USEDAND DRAWING FORDATE-CODE. CINCH ONLY. MANU NO PART MARK DRAWING CONNECTOR 3. WITH PART CINCH MARK CONNECTOR WITH 3. PART MARK CONNECTOR 3. WITH PARTCINCH MARK AND CONNECTOR DATE-CODE. WITH MATERIAL SPECIFICATIONS: MATERIAL SPECIFICATIONS: HEX HEAD FLOAT MOUNT JACKSCREW FRONT PANEL HEX HEAD FLOAT MOUNT (NON-REMOVEABLE) MOUNT JACKSCREW FRONT PANEL (L) (F) (NON-REMOVEABLE) MOUNT (L) (F) FLOAT FLOATMOUNT MOUNT JACKPOST JACKPOST H HEX HEXHEAD HEAD N HEX HEX HEAD HEX HEXHEAD HEAD HEAD DIMENSIONSDRAWING ARE FOR ONLY. REFERENCE 1. CUSTOMER DIMENSIONS ONLY ARE CINCH FOR ONLY. REFERE CUSTOMER 2. NOT USED DRAWING FOR MANU NO 2. 3. APP'D 4,65±0,025 4,65±0,025 4,65±0,025 4,65±0,025 4,98±0,025 4,98±0,025 FLOAT MOUNT FRONT PANEL FLOAT MOUNT MOUNT FRONT PANEL (F) MOUNT (F) 1. 2. APP'D DATE 15,915,9 (H) (H) 15,915,9 (H) (H) 15,915,9 (H) (H) 4,98±0,025 4,98±0,025 12. 12. ALL OTHER OTHER DETAILS AND DIMENSIONS TO BE AS PER MIL-DTL-83513 GENERAL GENERAL SPECIFICATIONS: 12. 12. ALL ALL ALLSPECIFICATIONS: OTHER OTHERDETAILS DETAILS DETAILSAND AND ANDDIMENSIONS DIMENSIONS DIMENSIONSTO TO TOBE BE BEAS AS ASPER PER PERMIL-DTL-83513 MIL-DTL-83513 MIL-DTL-83513 OR OR CINCH DURA-CON CATALOGUE. OR ORCINCH CINCH CINCHDURA-CON DURA-CON DURA-CONCATALOGUE. CATALOGUE. CATALOGUE. 12. 12. ALLALL OTHER OTHER DETAILS DETAILS ANDAND DIMENSIONS DIMENSIONS TO BE TO AS BE PER AS PER MIL-DTL-83513 MIL-DTL-83513 OR OR CINCH CINCH DURA-CON DURA-CON CATALOGUE. CATALOGUE. (NON-REMOVEABLE) (NON-REMOVEABLE) CIRCLIP MOUNT MOUNT CIRCLIP (L) (L) (F) (F) JACKSCREW (M) (M) FRONT FRONT PANEL PANEL JACKSCREW JACKSCREW JACKSCREW (L) (L) (F) (F) (M) (M) (NON-REMOVEABLE) (NON-REMOVEABLE) MOUNT MOUNT CIRCLIP CIRCLIP (L) (L) (F) (F) (M) (M) A 2,36±0,05 2,36±0,05 2,36±0,05 2,36±0,05 2,36±0,05 2,36±0,05 2,36±0,05 2,36±0,05 MICRO-D MICRO-DCONNECTORS CONNECTORS CONNECTORS SHALL SHALL MEET GENERAL ENVIRONMENTAL/ELECTRICAL PERFORMANCE PERFORMANCE SPECIFICATIONS: SPECIFICATIONS: MICRO-D MICRO-D CONNECTORS SHALL SHALLMEET MEET MEETGENERAL GENERAL GENERALENVIRONMENTAL/ELECTRICAL ENVIRONMENTAL/ELECTRICAL ENVIRONMENTAL/ELECTRICAL PERFORMANCE PERFORMANCE OF MIL-DTL-83513. SEE PERFORMANCE PERFORMANCEOF OF OFMIL-DTL-83513. MIL-DTL-83513. MIL-DTL-83513. DETAIL MICRO-D MICRO-D CONNECTORS CONNECTORS SHALL SHALL MEET MEET GENERAL GENERAL ENVIRONMENTAL/ELECTRICAL ENVIRONMENTAL/ELECTRICAL SEE A DETAIL CURRENT CURRENT RATING: RATING: 3 3 AMP AMP MAX. MAX. PERFORMANCE PERFORMANCE OF MIL-DTL-83513. OF MIL-DTL-83513. CURRENT CURRENTRATING: RATING: 33AMP AMPMAX. MAX. A TEMPERATURE TEMPERATURE RATING: RATING: -55 -55 °C °C TO TO +135 +135 °C. °C. TEMPERATURE TEMPERATURERATING: RATING:-55 -55°C °CTO TO+135 +135°C. °C. INSULATION INSULATION RESISTANCE: RESISTANCE: 5000 5000 M M MIN. MIN. CURRENT CURRENT RATING: RATING: 3 AMP 3 AMP MAX. MAX. INSULATION INSULATIONRESISTANCE: RESISTANCE:5000 5000M M MIN. MIN. DWV DWV AT SEA LEVEL: LEVEL: 600 VAC. TEMPERATURE TEMPERATURE RATING: RATING: -55600 °C -55VAC. TO °C +135 TO +135 °C. °C. DWV DWVAT AT ATSEA SEA SEA LEVEL: LEVEL: 600 600 VAC. VAC. DWV DWV 70,000 70,000 FT FT ALTITUDE: ALTITUDE: 150 150 VAC. VAC. INSULATION INSULATION RESISTANCE: RESISTANCE: 5000 5000 M M MIN. MIN. DWV DWV70,000 70,000FT FTALTITUDE: ALTITUDE:150 150VAC. VAC. CONTACT CONTACT RESISTANCE: RESISTANCE: 8 m MAX. DWV DWV AT SEA AT SEA LEVEL: LEVEL: 600 600 VAC. VAC. CONTACT CONTACT RESISTANCE: RESISTANCE: 88 8m m m MAX. MAX. MAX. DWV DWV 70,000 70,000 FT ALTITUDE: FT ALTITUDE: 150 150 VAC. VAC. GENERAL GENERAL SPECIFICATIONS: SPECIFICATIONS: CONTACT CONTACT RESISTANCE: RESISTANCE: 8 m 8 m MAX. MAX. GENERAL GENERALSPECIFICATIONS: SPECIFICATIONS: FLOAT FLOATMOUNT MOUNT THIS DRAWING IS COPYRIGHT AND IS ISSUED ON CONDITION IT IS NOT COPIED, REPRODUCED OR DISCLOSED TO A THIRD PARTY WITHOUT SOLUTIONS LTD. TITLE THE CONSENT IN WRITING OF Cinch CONNECTIVITY MICROMINIATURE GEN. TOLERANCES ATTENTION IS DRAWN TO THE FACT THE ARTICLE DISCLOSED MAY BE COVERED BY BRITISH OR FOREIGN PATENTS, GRANTED OR PENDING OR REGISTERED DESIGN. THIS THIS DRAWING DRAWING IS COPYRIGHT COPYRIGHT AND AND IS ISSUED ISSUED ON CONDITION CONDITION IT IS NOT NOT COPIED, COPIED, REPRODUCED REPRODUCED OR DISCLOSED DISCLOSED TO A THIRD THIRD PARTY PARTY WITHOUT WITHOUT THE THE CONSENT CONSENT IN IN WRITING WRITING OF Cinch Cinch CONNECTIVITY CONNECTIVITY SOLUTIONS SOLUTIONS LTD. LTD. THIS THIS DRAWING DRAWING ISIS IS COPYRIGHT COPYRIGHT AND AND ISIS IS ISSUED ISSUED ONON ON CONDITION CONDITION ITIT IT ISIS IS NOT NOT COPIED, COPIED, REPRODUCED REPRODUCED OROR OR DISCLOSED DISCLOSED TOTO TO AA A THIRD THIRD PARTY PARTY WITHOUT WITHOUT THE THE CONSENT CONSENT IN9-51W IN WRITING WRITING OFOF OF Cinch Cinch CONNECTIVITY CONNECTIVITY SOLUTIONS SOLUTIONS LTD. LTD. SHIELDED CABLE ASSEMBLY ATTENTION ATTENTION IS IS DRAWN DRAWN TO TO THE THE FACT FACT THE THE ARTICLE ARTICLE DISCLOSED DISCLOSED MAY MAY BE BE COVERED COVERED BY BY BRITISH BRITISH OR OR FOREIGN FOREIGN PATENTS, PATENTS, GRANTED GRANTED OR OR PENDING PENDING OR OR REGISTERED REGISTERED DESIGN. DESIGN. ATTENTION ATTENTION ISIS DRAWN DRAWN TOTO THE THE FACT FACT THE THE ARTICLE ARTICLE DISCLOSED DISCLOSED MAY MAY BEBE COVERED COVERED BYBY BRITISH BRITISH OROR FOREIGN FOREIGN PATENTS, PATENTS, GRANTED OROR PENDING PENDING OROR REGISTERED REGISTERED DESIGN. DESIGN. MICROMINIATURE 2 DEC. PL. GRANTED 0.1 TITLE GEN. TOLERANCES 8. 8. HARDWARE: HARDWARE: >303SS< >303SS< PASSIVATE PASSIVATE DIP PER PER SAE-AMS-QQ-P-35. SAE-AMS-QQ-P-35. 7. 7. INSULATOR: >PBT< >PBT< PERPER MIL-M-24519 MIL-M-24519 ORDIP OR >DAP< >DAP< PER PER ASTM-D5948. ASTM-D5948. 8. 8.INSULATOR: HARDWARE: HARDWARE: >303SS< >303SS< PASSIVATE PASSIVATE DIP DIP PER PER SAE-AMS-QQ-P-35. SAE-AMS-QQ-P-35. 1. PART NUMBER L PART M NUMBE N DCDC-9P 19,89 8,43 PART NUMBER L PART M DCDC-9P NUMBE N 14 DCDC-15P 23,70 DCDC-15P DCDC-9P 19,89 12,24 8,43 DCDC-9P18 14 DCDC-21P 27,51 16,05 DCDC-21P 21 DCDC-15P 23,70 12,24 DCDC-15P 18 DCDC-25P 30,05 18,89 DCDC-25P 24 DCDC-21P 27,51 16,05 DCDC-21P 21 DCDC-31P 33,86 DCDC-31P 28 DCDC-25P 30,05 22,40 18,89 DCDC-25P 24 DCDC-37P 37,67 DCDC-37P 32 DCDC-31P 33,86 26,21 22,40 DCDC-31P 28 DCDC-51P 36,40 DCDC-51P 30 DCDC-37P 37,67 24,94 26,21 DCDC-37P 32 DCDC-100P 54,94 DCDC-100P 45 DCDC-51P 36,40 35,10 24,94 DCDC-51P 30 DCDC-9S 19,89 DCDC-9S 8,53 14 DCDC-100P 54,94 35,10 DCDC-100P 45 DCDC-15S 23,70 DCDC-15S 12,34 DCDC-9S 19,89 DCDC-9S 8,53 18 14 DCDC-21S 27,51 DCDC-21S 16,15 DCDC-15S 23,70 DCDC-15S 12,34 21 18 DCDC-25S 30,05 DCDC-25S 18,69 DCDC-21S 27,51 DCDC-21S 16,15 24 21 DCDC-31S 33,86 DCDC-31S 22,50 DCDC-25S 30,05 DCDC-25S 18,69 28 24 DCDC-37S 37,67 DCDC-37S 26,31 DCDC-31S 33,86 DCDC-31S 22,50 32 28 DCDC-51S 36,40 DCDC-51S 25,04 DCDC-37S 37,67 DCDC-37S 26,31 30 32 NOTES: NOTES: DCDC-100S 54,94 DCDC-100S 35,20 DCDC-51S 36,40 DCDC-51S 25,04 45 30 NOTES: NOTES: 1. DIMENSIONS ARE FOR REFERENCE 1. DIMENSIONS ONLY ARE FOR REFERE DCDC-100S 54,94 DCDC-100S 35,20 45 H OVERALL OVERALL LENGTH LENGTH 0.25"0.25" 6. FLOAT MOUNT FLOAT MOUNT Hexhead HEXHEAD HEAD HEX JACKPOST JACKPOST Jackscrew Jackpost Float Mount Hexhead Jackscrew JACKSCREW JACKSCREW FRONT FRONT PANEL PANEL JACKSCREW JACKSCREW (P) (P) JACKSCREW JACKSCREW FRONT PANEL FRONT PANEL JACKSCREW JACKSCREW (P) (P) (Non-Removeable) (Front Panel Mount) with Circlip (NON-REMOVEABLE) (NON-REMOVEABLE) MOUNT MOUNT HEXHEX HEAD HEAD CIRCLIP CIRCLIP FLOAT FLOAT MOUNT MOUNT HEXHEX HEAD HEAD JACKPOST JACKPOST H 4,654,65 MAX. MAX. (Y) (Y) 7,627,62 MAX. MAX. (W) (W) 4,654,65 MAX. MAX. (Y) (Y) 7,627,62 MAX. MAX. (W) (W) OVERALL OVERALL LENGTH LENGTH 0.25"0.25" DETAIL A GROUND SPRING GROUND SPRING SCALE 15:1 SCALE 15:1 IF REQUIRED IF REQUIRED GROUND SPRING GROUND SPRING 7. 7. INSULATOR: INSULATOR: >PBT< >PBT< PER PER MIL-M-24519 OR OR >DAP< PER PER ASTM-D5948. ASTM-D5948. 6. CONTACT (FEMALE (FEMALE SOCKETS): SOCKETS): >Cu >Cu ALLOYPBT< >PBT< PER PERMIL-M-24519 MIL-M-24519 MIL-M-24519 OR OR >DAP< >DAP< PER PER ASTM-D5948. ASTM-D5948. 11. 11. WIRE: WIRE: SEE SEE SALES-CODE SALES-CODE NOMENCLATURE. NOMENCLATURE. 10. 10. DUSTCAP: DUSTCAP: >LDPE< >LDPE< OR OR ANTI-STATIC ANTI-STATIC >HDPEHDPECu >Cu ALLOYCu ALLOYCu ALLOYLDPE< OR OR ANTI-STATIC ANTI-STATIC >HDPEHDPEFVMQ< >FVMQ< PERPER MIL-R-25988 MIL-R-25988 OR OR >PMQ< >PMQ< PERPER ZZ-R-765. ZZ-R-765. 10. 10. DUSTCAP: DUSTCAP: >LDPE< >LDPE< OR OR ANTI-STATIC ANTI-STATIC >HDPEHDPEASTM ALLOY< SAE-AMS-QQ-A-250. MATERIAL MATERIAL SPECIFICATIONS: SPECIFICATIONS: 4. 4. CONNECTOR CONNECTOR CONNECTOR SHELL: SHELL:>ASTM >ASTM >ASTMALLOY< ALLOY< ALLOYASTM >ASTM ALLOY< ALLOY< SAE-AMS-QQ-A-250. SAE-AMS-QQ-A-250. ELECTROLESS ELECTROLESSNi NiPER PERSAE-AMS-C-26074. SAE-AMS-C-26074. GOLD GOLD PER PER MIL-G-45204. MIL-G-45204. CADMIUM CADMIUM PER PER SAE-AMS-QQ-P-416. SAE-AMS-QQ-P-416. GOLD GOLD PER PER MIL-G-45204. MIL-G-45204. ELECTROLESS ELECTROLESS Ni PER Ni PER SAE-AMS-C-26074. SAE-AMS-C-26074. 5. 5. CONTACT CONTACT (MALE (MALE PINS): >Cu ALLOYCu >Cu >CuALLOYPMQ< PER ZZ-R-765. 8. 8. HARDWARE: >303SS< >303SS< PASSIVATE PASSIVATE DIP DIP SAE-AMS-QQ-P-35. SAE-AMS-QQ-P-35. 9. 9.HARDWARE: INTERFACIAL INTERFACIAL GASKET: GASKET: >FVMQ< >FVMQ< PER PERPER MIL-R-25988 MIL-R-25988 OR OR>PMQ< >PMQ< >PMQ
DCDC100GP6K5-36.0ANLG 价格&库存
很抱歉,暂时无法提供与“DCDC100GP6K5-36.0ANLG”相匹配的价格&库存,您可以联系我们找货
