CFM130S SERIES
130 WATT OPEN FRAME
AC-DC MODULES WITH PFC
Features
Universal Input Range 80~264VAC
High Efficiency up to 94%
2”x 3” Open Frame Compact Size
100W with Natural Convection
130W with Fan-Cooled
Active PFC Function
Continuous Short Circuit Protection
No Load Input Power Consumption95% Reduction
Voltage Interruptions
IEC 61000-4-11:2004, >95% Reduction
Application Note Link
www.cincon.com
3
Criterion A
Criterion B
CFM130S Series App Notes
REVISION: V10
CFM130S
Series
CHARACTERISTIC CURVE
Power Derating Curve
Performance Data
95%
CFM130S120 (Eff Vs Io)
95%
90%
Efficincy (%)
Efficincy (%)
90%
85%
80%
75%
70%
115V
65%
230V
85%
80%
75%
70%
115V
65%
230V
60%
10% 20% 30% 40% 50% 60% 70% 80% 90%100%
60%
Current Load (%)
Current Load (%)
95%
CFM130S360 (Eff Vs Io)
95%
Efficincy (%)
Efficincy (%)
CFM130S480 (Eff Vs Io)
90%
90%
85%
80%
75%
70%
115V
65%
230V
60%
85%
80%
75%
70%
115V
65%
230V
60%
Current Load (%)
Current Load (%)
www.cincon.com
CFM130S240 (Eff Vs Io)
4
REVISION: V10
CFM130S
Series
MECHANICAL SPECIFICATION
CFM130S
CFM130S-B
CFM130S-C
3.598 [91.40]
3.000 [76.20]
2.700 [68.58]
3.598 [91.40]
3.354 [85.20]
0.150 [3.80]
5CM
Air flow
direction
FAN
Air flow
direction
Function
ACL
ACN
-Vout
-Vout
+Vout
+Vout
Air flow
direction
1.299 [33.00]max
0.197 [5.00]max
1.040 [26.40]max
1.201 [30.50]max
0.063 [1.60]
Pin
1
2
3
4
5
6
0.098 [2.50]max
FAN
PIN CONNECTION
2.520 [64.00]
6
5
4
3
2.000 [50.80]
2
1.382 [35.10]
1
5CM
FAN
2.000 [50.80]
6
5
4
3
0.157 [4.00]
2
5CM
6
5
4
3
1
1.380 [35.05]
2
1.700 [43.18]
2.000 [50.80]
1
0.150 [3.81]
0.150 [3.81]
All Dimensions In Inches[mm]
Tolerance Inches:x.xxx= ± 0.02, x.xxx= ± 0.010
Millimeters: x.xx = ± 0.5, x.xx= ± 0.025
5
REVISION: V10
很抱歉,暂时无法提供与“CFM130S240-C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+506.045771+65.59317
