CFM130S120
CFM130S120
    CINCON
    AC/DC CONVERTER 12V 100W
CFM130S120 数据手册
CFM130S SERIES 130 WATT OPEN FRAME AC-DC MODULES WITH PFC Features  Universal Input Range 80~264VAC  High Efficiency up to 94%  2”x 3” Open Frame Compact Size  100W with Natural Convection  130W with Fan-Cooled  Active PFC Function  Continuous Short Circuit Protection  No Load Input Power Consumption95% Reduction Voltage Interruptions IEC 61000-4-11:2004, >95% Reduction Application Note Link www.cincon.com 3 Criterion A Criterion B CFM130S Series App Notes REVISION: V10 CFM130S Series CHARACTERISTIC CURVE Power Derating Curve Performance Data 95% CFM130S120 (Eff Vs Io) 95% 90% Efficincy (%) Efficincy (%) 90% 85% 80% 75% 70% 115V 65% 230V 85% 80% 75% 70% 115V 65% 230V 60% 10% 20% 30% 40% 50% 60% 70% 80% 90%100% 60% 10% 20% 30% 40% 50% 60% 70% 80% 90%100% Current Load (%) Current Load (%) 95% CFM130S360 (Eff Vs Io) 95% Efficincy (%) Efficincy (%) CFM130S480 (Eff Vs Io) 90% 90% 85% 80% 75% 70% 115V 65% 230V 60% 10% 20% 30% 40% 50% 60% 70% 80% 90%100% 85% 80% 75% 70% 115V 65% 230V 60% 10% 20% 30% 40% 50% 60% 70% 80% 90%100% Current Load (%) Current Load (%) www.cincon.com CFM130S240 (Eff Vs Io) 4 REVISION: V10 CFM130S Series MECHANICAL SPECIFICATION CFM130S CFM130S-B CFM130S-C 3.598 [91.40] 3.000 [76.20] 2.700 [68.58] 3.598 [91.40] 3.354 [85.20] 0.150 [3.80] 5CM Air flow direction FAN Air flow direction Function ACL ACN -Vout -Vout +Vout +Vout Air flow direction 1.299 [33.00]max 0.197 [5.00]max 1.040 [26.40]max 1.201 [30.50]max 0.063 [1.60] Pin 1 2 3 4 5 6 0.098 [2.50]max FAN PIN CONNECTION 2.520 [64.00] 6 5 4 3 2.000 [50.80] 2 1.382 [35.10] 1 5CM FAN 2.000 [50.80] 6 5 4 3 0.157 [4.00] 2 5CM 6 5 4 3 1 1.380 [35.05] 2 1.700 [43.18] 2.000 [50.80] 1 0.150 [3.81] 0.150 [3.81] All Dimensions In Inches[mm] Tolerance Inches:x.xxx= ± 0.02, x.xxx= ± 0.010 Millimeters: x.xx = ± 0.5, x.xx= ± 0.025 5 REVISION: V10
CFM130S120 价格&库存
很抱歉,暂时无法提供与“CFM130S120”相匹配的价格&库存,您可以联系我们找货
CFM130S120
  • 1+569.719721+74.00370
  • 10+537.0972010+69.76620
  • 25+510.3902225+66.29710
  • 50+489.5988050+63.59640
  • 100+456.97628100+59.35890
库存:1
