CFM21M150-E
CFM21M150-E
    CINCON
    模块
    封闭式 AC DC 转换器 1 输出 15V 1.4A 90 ~ 264 VAC 输入
CFM21M150-E 数据手册
V12 CFM21M SERIES ︳ 20 WATT SINGLE OUTPUT AC-DC MODULES Features * Universal Input Range 90~264VAC * Class II * Miniature Size Low Profile 0.8" * Industry-Standard Pin Out * Efficiency to 85% * Option for On-Board, Connecter, Screw Terminal or Encapsulated type * Continuous Short Circuit Protection * Over Voltage Protection * No Load Input Power < 0.1W * Leakage Current < 100uA * UL60601-1/IEC60601-1/EN60601-1 Ed.3.1 Medical Safety Approved * 2 MOPP * Peak Load 130% (note 8) * Meet UL62368/IEC62368/EN62368 * Meet UL60335-1/IEC60335-1/EN60335-1 MODEL OUTPUT VOLTAGE OUTPUT CURRENT RIPPLE & NOISE NOTE 1 VOLTAGE ACCURACY NOTE 2 LINE REGULATION NOTE 3 LOAD REGULATION NOTE 4 OUTPUT RATED POWER % EFF. CFM21M050 CFM21M090 CFM21M120 CFM21M150 CFM21M240 5.0 V 9.0 V 12 V 15 V 24 V 4.0 A 2.3 A 1.7 A 1.4 A 0.9 A 50 mV 90 mV 100 mV 100 mV 100 mV ±1% ±1% ±1% ±1% ±1% ±0.5% ±0.5% ±0.5% ±0.5% ±0.5% ±1.0% ±1.0% ±1.0% ±1.0% ±1.0% 20.0 W 20.7 W 20.4 W 21.0 W 21.6 W 81% 83% 85% 85% 86% Specifications are subject to change without notice. 1 V12 Specifications CFM21M Series De-rating Curve INPUT SPECIFICATIONS: Voltage …....………........…........................................... 90~264Vac Frequency ………………………………………….……………..... 47 to 63Hz Input Current ……………………………………….……………..... 0.3 to 0.5A Inrush Current ………….… Cold Start@25℃ ............. 40A max. @230Vac Leakage Current ……………………………… 70uA Typical - 100uA max. Derating curve for Natural Convection 120% 50 LOAD(%) 100% OUTPUT SPECIFICATIONS: Isolation …………………………………………… Input to output = 4000VAC Hold-up Time …………………………….…………..…… 10ms typ. @115Vac Short Circuit Protection …………….………………………….…… Continuous Over Voltage Protection(TVS) ….. 110%-140% of Nominal Output Voltage 80% 60 CFM21 Series 60% CFM21M050, CFM21M090 40% 20% 0% -25 GENERAL SPECIFICATIONS: Efficiency …………………………………………………………….. see Table 70 -15 -5 5 15 25 35 45 55 Ambient Temperature(oC) 65 75 Switching Frequency …….…………………………….………….. 65KHz typ. Operating Temperature ........................................ -25 ~ 70℃(with de-rating) NOTE: Storage Temperature ……………………………...….......……........ -40~85℃ Cooling ………………………………….………………… Natural Convection Humidity ....................................................... 93% RH max. Non condensing Operating Altitude..........................................................................5000m MTBF ……….…. MIL-HDBK-217F, GB ..………………….…… 500Khrs min. Dimensions …………..........….. 2.38x1.60x0.80inches (60.5x40.6x20.4mm) -T: 3.00x1.60x0.77inches (76.2x40.6x19.5mm) -E: 2.53x1.74x0.80Inches (64.2x44.2x20.4mm) -S: 3.00x1.60x0.77Inches (76.2x40.6x19.5mm Weight …………………………………..…….…… 55g, 60g(-T, -S), 110g(-E) 1. Add a 0.1uF ceramic capacitor and a 10uF E.L. capacitor to output for ripple&noise measuring @20MHz BW. 2. Voltage accuracy is set of 100% rated load. 3. Line regulation is measured from high line to low line with full load. 4. Load regulation is measured from 10% to 100% full load. 5. T Version Connection: JST B3P-VH / B4P-VH or equivalent. 6. S Version Connection: DECA MB332-381A or equivalent. 7. Typical efficiency at 230VAC and 100% load at 25℃. 8. Peak load 130% lasting < 10 seconds with a maximum duty cycle of 10% at nominal Line. SAFETY AND EMISSION: Emissions and Immunity (Ed. 4.0) ……. EN55011 Class B, EN61000-3-2(3) EN60601-1-2 2015, IEC 61000-4-2(3/4/5/6/8/11) Safety Approved (Ed.3.1) ….................................................... IEC60601-1 ANSI/AAMI ES 60601-1:2005/A1:2012&C1:2009/(R)2012&2010/(R)2012 CAN/CSA-C22.2 NO. 60601-1:14, EN 60601-1: 2006+A11:2011+A1:2013, IEC 60601-1:2005+A1:2012 Mechanical Specification Annotations: For all models, height does not exceed 34mm max. CFM21MXXX 2 0.76[19.2]max 0.098 [2.50]max 1.60[40.6] 0.15 [3.81] 0.15 [3.81] 2.700 [68.58] 3.00[76.2] 0.61[15.5]max 0.150 [3.80] 0.134 [3.40] Φ0.039 [1.00] Φ0.071 [1.80] 0.61[15.5]max 2.38[60.5] 0.10[2.5]max 2.126 [54.00] ACL ] 50 3. Φ 8[ 13 0.406 [10.32] 0.12 [3.06] -Vo -Vo +Vo +Vo ACN 0. Φ 4- 0.80 [20.32] 0.11 [2.82] +Vo 0.79[20.1]max 1.60[40.6] ACL 1.194 [30.32] -Vo ACN 1.299 [33.00] CFM21MXXX-T V12 Mechanical Specification CFM21MXXX-S 0.787 [20.00] CFM21MXXX-E ACN 1.60[40.6] 1.30 [33.00] 0.15 [3.81] 1.74[44.2] 0.17 [4.24] -Vo TOP VIEW +Vo -Vo -Vo +Vo +Vo ACN ACL 0.463 [11.76] 0.20 [5.10] 2.126 [54.00] 0.15 [3.81] 2.70 [68.58] 3.00[76.2] 1.10[28.0] 8-0.16[4.0] Φ0.039 [1.00] 0.78[19.7] 0.80[20.4] 0.22 [5.60] 2.53[64.2] ] 50 3. Φ 8[ 13 . 0 Φ 4- All Dimensions In Inches[mm] Tolerance: Inches:x.xx= ±0.02,x.xxx= ±0.01 Millimeters:x.x= ±0.5,x.xx= ±0.25 Typical at 25˚C, nominal line and 75% load, unless otherwise Specified 3 0.61[15.5]max 0.098 [2.50]max 0.76[19.2]max 0.69 [17.50] ACL
CFM21M150-E 价格&库存
很抱歉,暂时无法提供与“CFM21M150-E”相匹配的价格&库存,您可以联系我们找货
