CFM41S480
CFM41S480
    CINCON
    DIP6 模块
    开放框架 AC DC 转换器 1 输出 48V 830mA 90 ~ 264 VAC,120 ~ 370 VDC 输入
CFM41S480 数据手册
V12 CFM41S SERIES ︳ 40 WATT SINGLE OUTPUT AC-DC OPEN FRAME Features * Universal Input 90~264VAC * EN55032 Class B and CISPR/FCC Class B * IEC/EN/UL62368-1 * Meets IEC/EN60335-1 * Continuous Short Circuit Protection * Over Voltage Protection * No Load Power Consumption < 0.15W * Peak Load (2 times of rated current) * Class II Ordering information CFM41SXXX- X Blank: PCB mount E: Encapsulated T: WAFER MODEL Output Voltage Output Current PEAK Current NOTE6 Ripple (mV p-p) NOTE1 Voltage Accuracy N O TE 2 Line Regulation N O TE 3 Load Regulation N O TE 4 % EFF. (typ.) N O TE 5 CFM41S050 5V 6A 12 A 100mV ±2% ±0.5% ±1% 87% CFM41S120 12 V 3.34 A 6.66 A 120mV ±1% ±0.5% ±1% 90% CFM41S150 15 V 2.67 A 5.34 A 150mV ±1% ±0.5% ±1% 90% CFM41S240 24 V 1.67 A 3.34 A 240mV ±1% ±0.5% ±1% 90% CFM41S360 36 V 1.11 A 2.22 A 360mV ±1% ±0.5% ±1% 90% CFM41S480 48 V 0.83 A 1.66 A 480mV ±1% ±0.5% ±1% 90% Typical at 25˚C, nominal line and 75% load, unless otherwise Specified 1 V12 Specifications CFM41S Series De-rating Curve INPUT SPECIFICATIONS: CFM41SXXX、CFM41SXXX-E Voltage .....…….…...………………….…..……………………… 90~264Vac 120~370Vdc Frequency ………………………………………….……………..... 47 to 63Hz Inrush Current ……..…………...…. 70A max. @240Vac, Cold Start @25℃ Leakage Current ……………………….………….. 0.25mA max. @ 264Vac Input Current ………..……………… 100Vac/1A max., 240Vac/0.55A max. OUTPUT SPECIFICATIONS: Holdup Time ………………………..…………………… 10ms typ. @115Vac Short Circuit Protection ………………..…… Hiccup Mode (Auto Recovery) CFM41SXXX-T Temperature Coefficient .…………………….............................… ±0.05%/℃ Over Voltage Protection ……….……………..… TVS Component to Clamp Startup time ……………………….…….….. 115Vac
CFM41S480 价格&库存
很抱歉,暂时无法提供与“CFM41S480”相匹配的价格&库存,您可以联系我们找货
