CFM500S240C
CFM500S240C
    CINCON
    AC/DC CONVERTER 24V 410W
CFM500S240C 数据手册
CFM500S SERIES 500 WATT AC-DC POWER SUPPLY WITH PFC Features ⚫ Universal Input Range 80~264Vac ⚫ High Efficiency up to 94.5% ⚫ 3”x 5” Compact Size ⚫ High Power Density Up to 20.96W/Inch3 ⚫ 390W Natural, 470 ~ 500W Conduction Convection ⚫ No Load Power Consumption95% Reduction Criterion A Voltage Interruptions IEC61000-4-11:2017+A1:2017, >95% Reduction Application Note Link Criterion B CFM500S Series App Notes CHARACTERISTIC CURVE Power Derating Curve www.cincon.com Forced Air Flow Forced Air Flow Natural Convection Natural Convection 4 REVISION: V10 CFM500S Conduction Convection with External Baseplate (48x24.8x0.12cm) Series Conduction Convection with External Baseplate (48x24.8x0.12cm) Performance Data www.cincon.com 5 REVISION: V10 CFM500S Series CFM500S480 (Eff Vs Io) 100% Efficincy (%) 95% 90% 85% 80% 115V 75% 230V 70% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) MECHANICAL SPECIFICATION 5.000 [127.00] 4.551 [115.60] OPTION CONNECTION 0.224 [5.70] VR CN2 +Vo CN1 ACL 1 -Vo Air flow direction 21CFM FAN 50mm ACN 3 2.551 [64.80] 1 3.000 [76.20] 0.224 [5.70] 4 +Vo -Vo CN3 1 www.cincon.com 6 1.539 [39.10]max 1.280 [32.50]max .7 *0 4 4-M 0.197 [5.00] 7 REVISION: V10 CFM500S CN1: PIN CONNECTION 5.354 [136.00] OPTION CONNECTION Pin 1 2 3 CN2 +Vo CN1 ACL 1 ACN 3 -Vo 3.425 [87.00] 4 1 Pin Function 1 GND 2 +5VSB 3 GND 4 +12V-FAN -Vo 50mm CN3: PIN CONNECTION 1.673 [42.50] CN3 1 7 Pin 1 2 3 4 5 6 7 Function GND PF FAN-EN PS-ON -Sense +Sense OPTION All Dimensions In Inches[mm] Tolerance Inches:x.xxx= ± 0.02 Millimeters: x.xx = ± 0.5 2.551 [64.80] 0. 7 0.437 [11.10] 4M 4* FAN Function ACL ACN CN2: PIN CONNECTION +Vo Air flow direction 21CFM Series 0.402 [10.20] 4.551 [115.60] 7 REVISION: V10
CFM500S240C 价格&库存
很抱歉,暂时无法提供与“CFM500S240C”相匹配的价格&库存,您可以联系我们找货
CFM500S240C
  • 1+1333.600291+173.29707
CFM500S240C
  • 1+1290.292791+167.66940
  • 25+1120.0277125+145.54400
  • 40+1075.2439940+139.72450
库存:10
