CFM81S120-P
CFM81S120-P
    CINCON
    开放框架 AC DC 转换器 1 输出 12V 90 ~ 264 VAC 输入
CFM81S120-P 数据手册
CFM81S SERIES 80 WATT OPEN FRAME AC-DC MODULES Features  Universal Input Range 90~264VAC  Continuous Short Circuit Protection  High Efficiency up to 91%  No Load Power 95% Reduction Application Note Link www.cincon.com 3 Class B Criterion B CFM81S Series App Notes REVISION: V10 CFM81S Series CHARACTERISTIC CURVE Power Derating Curve 200 180 160 140 120 100 80 60 40 20 0 Power Derating 100% Derating curve for Natural Convection 75% LOAD (%) Rated Load(%) Peak Load Vin De-Rating 20LFM(Natural Convection) 50% 25% 20LFM(Natural Convection) 0% -30 -20 -10 0 10 20 30 40 50 60 70 80 90 110 130 150 170 190 210 230 250 Vin Voltage(Vac) Ambient Temperature(oC) Performance Data CFM81S150 (Eff Vs Io) 95% 90% 90% Efficincy (%) Efficincy (%) CFM81S120 (Eff Vs Io) 95% 85% 80% 115V 75% 70% 65% 10% 30% 40% 50% 60% 70% 80% 80% 115V 75% 70% 230V 20% 85% 65% 10% 90% 100% 230V 20% 30% Current Load (%) 90% 90% 85% 80% 115V 75% 70% 40% 50% 60% 70% 80% 90% 100% Current Load (%) www.cincon.com 70% 80% 90% 100% 85% 80% 115V 75% 70% 230V 30% 60% CFM81S480 (Eff Vs Io) 95% Efficincy (%) Efficincy (%) CFM81S240 (Eff Vs Io) 20% 50% Current Load (%) 95% 65% 10% 40% 65% 10% 230V 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) 4 REVISION: V10 CFM81S Series MECHANICAL SPECIFICATION CFM81SXXX 2 0.1 4 -Φ 6[ CFM81SXXX-P 0] 3.2 CN1 1 CFM81SXXX-CA 26 0 .1 4-Φ ] 20 [3. 0.62[15.8] CN1 1 2 3 4 CN2 0.150 [3.81] 2 1 2 3 4 CN2 0.150 [3.81] 2.700 [68.58] 2.700 [68.58] 3.000 [76.20] 3.000 [76.20] PIN CONNECTION Pin Function 1 ACN 2 ACL CN1 1 1.969 [50.00] 2 2.000 [50.80] 1 2 3 4 CN2 1 0.150 [3.81] 1.700 [43.18] 0.150 [3.81] 2 1.700 [43.18] 2.000 [50.80] CN1 All Dimensions In Inches[mm] Tolerance Inches:x.xxx=+0.039/-0 Millimeters:x.xx= +1.0/-0 3.200 [81.28] 2.362 [60.00] 0.063 [1.60] 0.197 [5.00] 0.472 [12.00] 1.575[40.00] 0.063 [1.60] 1.413 [35.90]max. 0.098[2.50]max. 0.063 [1.60] 0.173 [4.40] 0.150 [3.80] 0.039 [1.00] 2.441 [62.00] Φ0.039 [1.00] 2.720[69.10] 2.000 [50.80] 3x 0 4- M 0.600 [15.24] .5 5 1.700 [43.18] PIN CONNECTION Pin Function 1 -Vout -Vout 2 3 +Vout +Vout 4 Φ0.071 [1.80] 0.370 [9.41] CN2 1.339[34.00]Max. 0.098 [2.50]Max. 0.236 [6.00] REVISION: V10
CFM81S120-P 价格&库存
很抱歉,暂时无法提供与“CFM81S120-P”相匹配的价格&库存,您可以联系我们找货
CFM81S120-P
  • 1+386.267351+49.96958
  • 5+367.868775+47.58944
  • 10+360.2196510+46.59991
  • 40+345.4109140+44.68418
  • 80+338.2331080+43.75562
  • 120+334.10459120+43.22153
库存:40
