CHB150W12-72S48N
CHB150W12-72S48N
    CINCON
    半砖
    隔离模块 直流转换器 1 输出 48V 3.2A 14V - 160V 输入
CHB150W12-72S48N 数据手册
CHB150W12 SERIES 150 WATT 12:1 INPUT ISOLATED DC-DC CONVERTER Features  Efficiency Up to 91%  Fixed Switching Frequency  Regulated Outputs  Remote On/Off  Fully protected (OTP/OCP/OVP/UVLO)  3000Vac I/O Isolation  Operating Case Temperature -40 to +100℃  Half Brick Size Meet Industrial Standard 2.28×2.40x0.50  CB Test Certificate IEC62368-1  EN50155 Compliant with External Circuits  UL62368-1 2nd (Reinforce Insulation) Approval  Shock & Vibration EN50155 (EN61373) Compliant  Fire & Smoke EN45545-2 Compliant  5000m Operating Altitude OUTPUT CURRENT MODEL INPUT OUTPUT NUMBER VOLTAGE VOLTAGE MIN. MAX. CHB150W12-72S05 14-160 VDC 5 VDC 0 mA 25 A CHB150W12-72S12 14-160 VDC 12 VDC 0 mA 12.5 A CHB150W12-72S15 14-160 VDC 15 VDC 0 mA 10 A CHB150W12-72S24 14-160 VDC 24 VDC 0 mA 6.25 A CHB150W12-72S48 14-160 VDC 48 VDC 0 mA 3.2 A INPUT CURRENT % EFF. CAPACITOR NO LOAD FULL LOAD (1) (2) LOAD MAX. 50 mA 1929 mA 90 90 25000uF 50 mA 2289 mA 91 90 16700uF 50 mA 2315 mA 90 90 10000uF 50 mA 2341 mA 89 89 6250µF 50 mA 2370 mA 90 89 1500µF NOTE: 1. Nominal Input Voltage 72 VDC 2. Measured at Input Voltage 110 VDC 3. An External Input Capacitor 100uF for All Models are Recommended to Reduce Input Ripple Voltage 4. An External Electrolytic Capacitor at least 240uF connected between BUS and -Vin is necessary PART NUMBER Series CHB150W12- CHB150W12 Nominal Input Voltage II 72: 72 VDC Number of Outputs O S: Single Nominal Output Voltage XX 05: 5VDC 12: 12VDC Remote On/Off Logic L Mounting Inserts -Y (Option) None: 15: 15VDC None: 24: 24VDC N: 48: 48VDC Positive Negative -C: M3x0.5 Mounting Inserts Clear Mounting Inserts (3.2mm DIA.) Part Number Example: CHB150W12-72S12N-C: Half Brick, 150W, 12:1 14-160Vdc Input, Single 12Vdc Output, Negative Logic, Clear Mounting Insert www.cincon.com 1 REVISION: V10 CHB150W12 Series TECHNICAL SPECIFICATIONS (All specifications are typical at nominal input, full load at 25°C unless otherwise noted.) ABSOLUTE MAXIMUM RATINGS PARAMETER NOTES and CONDITIONS Device Min. Input Voltage Continuous All -0.3 Input Surge Voltage 100ms max. All Operating Case Temperature At the Center Part of Base Plate All -40 Max. Units 160 Vdc 180 Vdc 100 °C All -55 125 °C Device Min. Typ. Max. Units All 14 72 160 Vdc Turn-On Voltage Threshold All 12.5 13 13.5 Vdc Turn-Off Voltage Threshold All 10.5 11 11.5 Vdc Lockout Hysteresis Voltage All Storage Temperature Typ. INPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Operating Input Voltage Input Under Voltage Lockout Maximum Input Current Vin=16.5V, Full Load. No-Load Input Current Vin=72V, Io=0A Input Filter Pi filter. All Inrush Current (I t) As per ETS300 132-2. All Input Reflected Ripple Current P-P thru 12uH inductor, 5Hz to 20MHz. All 2 Vdc 2 All A 12 mA See Model Number Table 0.1 A2s mA 50 OUTPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Voltage Set Point Accuracy Vin=72V, Full Load, Tc=25°C Device Min. All -1.0 Typ. Max. Units +1.0 % Output Voltage Regulation Load Regulation Full Load to No Load All ±0.2 % Line Regulation Vin=High Line to Low Line, Full Load All ±0.2 % Temperature Coefficient Tc=-40°C to 100°C All ±0.02 %/°C 5Vo 150 12Vo 200 15Vo 200 24Vo 240 48Vo 240 5Vo 60 12Vo 80 Output Voltage Ripple and Noise (5Hz to 20MHz bandwidth) Peak-to-Peak Full load, 10uF tantalum and 1uF ceramic capacitors (for Vo=48V: Full Load 10uF aluminum and 1uF ceramic capacitors). RMS. 15Vo 60 24Vo 100 48Vo See Model Number Table Vin= 14 to 16.5V See Model Number Table,Full Load 10S Over Current Protection
CHB150W12-72S48N 价格&库存
很抱歉,暂时无法提供与“CHB150W12-72S48N”相匹配的价格&库存,您可以联系我们找货
CHB150W12-72S48N
  • 1+1841.740001+239.42024
