CQB200-24S28
CQB200-24S28
    CINCON
    四分之一砖
    隔离模块 直流转换器 1 输出 28V 7.14A 18V - 36V 输入
CQB200-24S28 数据手册
CQB200 SERIES 200 WATT 2:1 INPUT ISOLATED DC-DC CONVERTER Features ⚫ Efficiency Up to 92% ⚫ Fixed Switching Frequency ⚫ Regulated Outputs ⚫ Remote On/Off ⚫ Low No Load Power Consumption ⚫ Fully protected (OTP/OCP/OVP/UVLO) ⚫ 2250Vdc I/O Isolation ⚫ Operating Case Temperature -40 to +105℃ ⚫ Quarter Brick Size Meet Industrial Standard 2.28”x1.45”x0.5” ⚫ Meet UL62368-1 2nd (Functional Insulation) ⚫ Meet Shock & Vibration MIL-STD-810F/EN61373 ⚫ Fire & Smoke EN45545-2 Compliant ⚫ 3000m Operating Altitude OUTPUT CURRENT INPUT CURRENT MODEL INPUT OUTPUT NUMBER VOLTAGE VOLTAGE MIN. MAX. NO LOAD FULL LOAD CQB200-24S24 18-36 VDC 24 VDC 0 mA 8.33 A 10 mA 9100 mA 91.5 6600uF CQB200-24S28 18-36 VDC 28 VDC 0 mA 7.14 A 10 mA 9100 mA 92 5400uF % EFF. CAPACITOR LOAD MAX. NOTE: 1. Nominal Input Voltage 24 VDC 2. An External Input Capacitor 220uF KY 47mΩmax. for All Models are Recommended to Reduce Input Ripple Voltage PART NUMBER Series CQB200- CQB200 Nominal Input Voltage II 24: 24 VDC Number of Outputs O S: Single Nominal Output Voltage XX Remote On/Off Logic L 24: 24VDC None: 28: 28VDC N: Positive Negative Mounting Inserts None: -C: -Y (Option) M3x0.5 Mounting Inserts Clear Mounting Insert (3.2mm DIA.) Part Number Example: CQB200-24S24N-C: Quarter Brick, 200W, 2:1 18-36Vdc Input, Single 24Vdc Output, Negative Logic, Clear Mounting Insert www.cincon.com 1 REVISION: V10 CQB200 Series TECHNICAL SPECIFICATIONS (All specifications are typical at nominal input, full load at 25°C unless otherwise noted.) ABSOLUTE MAXIMUM RATINGS PARAMETER NOTES and CONDITIONS Device Min. Max. Units Input Voltage Continuous All -0.3 36 Vdc Input Surge Voltage 100ms max. All 50 Vdc Operating Case Temperature At the Center Part of Base Plate All -40 105 °C All -55 125 °C Device Min. Typ. Max. Units All 18 24 36 Vdc Turn-On Voltage Threshold All 16.5 17 17.5 Vdc Turn-Off Voltage Threshold All 15.5 16 16.5 Vdc Lockout Hysteresis Voltage All Storage Temperature Typ. INPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Operating Input Voltage Input Under Voltage Lockout Maximum Input Current Vin=18V, Full Load. No-Load Input Current Vin=24V, Io=0A Input Filter Pi filter. All Inrush Current (I t) As per ETS300 132-2. All Input Reflected Ripple Current P-P thru 12uH inductor, 5Hz to 20MHz. All 2 Vdc 1.0 All A 14 mA See Model Number Table 0.1 A2s mA 60 OUTPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Voltage Set Point Accuracy Vin=24V, Full Load, TC=25°C All -1.0 Load Regulation Full Load to No Load Line Regulation Vin=High Line to Low Line, Full Load Temperature Coefficient TC=-40°C to 105°C Typ. Max. Units +1.0 % All ±0.2 % All ±0.2 % All ±0.02 %/°C 24Vo 280 28Vo 280 24Vo 100 28Vo 100 Output Voltage Regulation Output Voltage Ripple and Noise (5Hz to 20MHz bandwidth) Peak-to-Peak Full load, 10uF tantalum capacitor and 1uF ceramic capacitors RMS. Output Current Range Vin= 18 to 36V Over Current Protection Hiccup Mode. Auto Recovery. Short Circuit Protection Full load (resistive) Output Voltage Trim Range Po≦max rated power, Io ≦ Io_max Output Voltage Remote Sense Range Po≦max rated power, Io ≦ Io_max % of nominal Vo Limited Voltage, % of Nominal Vo 130 150 uF See Model Number Table All % Continuous, Auto Recovery. All External Load Capacitance Over Voltage Protection 110 mV A See Model Number Table All mV -10 All +10 % +10 % All 115 125 140 % Device Min. Typ. Max. Units EFFICIENCY PARAMETER NOTES and CONDITIONS 100% Load Vin=24V www.cincon.com See Model Number Table 2 % REVISION: V10 CQB200 Series DYNAMIC CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Typ. Max. Units Output Voltage Current Transient Error Band Recovery Time Turn-On Delay and Rise Time Turn-On Delay Time, From On/Off Control Turn-On Delay Time, From Input Output Voltage Rise Time 75% to 100% of Io_max step load change di/dt=0.1A/us (within 1% Vout nominal) Full load (Constant resistive load) All ±5 % All 250 us Von/off to 10%Vo_set, Remote On All 35 ms Vin_min to 10%Vo_set, Power Up All 30 ms 10%Vo_set to 90%Vo_set All 15 ms ISOLATION CHARACTERISTICS PARAMETER NOTES and CONDITIONS Isolation Voltage (100% factory Hi-Pot tested @2sec.) 1 minute; Input to Output, All 2250 Vdc 1 minute; Input to Case (Base Plate), All 2250 Vdc 1 minute; Output to Case (Base Plate) All Isolation Resistance Input to Output All Input to Output All 1500 Input to Case (Base Plate) All None Output to Case (Base Plate) All None Isolation Capacitance Device Min. Typ. Max. 2250 Units Vdc MΩ 100 pF FEATURE CHARACTERISTICS PARAMETER NOTES and CONDITIONS Switching Frequency Pulse wide modulation (PWM), Fixed Device Min. Typ. Max. Units All 225 250 275 KHz On/Off Control, Positive Remote On/Off logic, Refer to –Vin pin. Logic Low (Module Off) Von/off at Ion/off=1.0mA All 0 1.2 V Logic High (Module On) Von/off at Ion/off=0.0uA, Pin open=On All 3.5 75 V On/Off Control, Negative Remote On/Off logic, Refer to –Vin pin Logic High (Module Off) Logic Low (Module On) On/Off Current (for both remote on/off logic) Leakage Current (for both remote on/off logic) Off Converter Input Current Over Temperature Shutdown Over Temperature Recovery Von/off at Ion/off=0.0uA, Pin open=Off All 3.5 75 V Von/off at Ion/off=1.0mA All 0 1.2 V Ion/off at Von/off=0V All 1 mA Logic High, Von/off=15V All 30 uA Shutdown input idle current All 5 10 mA Temperature at the Center Part of Base Plate, Non-Latching All 110 °C All 100 °C 0.3 GENERAL SPECIFICATIONS PARAMETER NOTES and CONDITIONS MTBF Io=100% of Io_max; MIL-HDBK - 217F_Notice 1, GB, 25°C Weight Case Material Plastic, DAP, UL 94V-0 Base plate Material Aluminum Potting Material Shock/Vibration UL 94V-0 Base: Copper Plating: Nickel with Matte Tin MEET MIL-STD-810F/EN61373 Humidity 95% RH max. Non Condensing Pin Material www.cincon.com 3 Device Min. Typ. 24S24 730 24S28 625 All 68 Max. Units K hours grams REVISION: V10 CQB200 Series GENERAL SPECIFICATIONS Altitude 3000m Operating Altitude, 12000m Transport Altitude Thermal Shock MIL-STD-810F Fire & Smoke EN45545-2 Compliant EMI Meets EN55032 Compliant (with external filter) Class A Application Note Link CQB200 Series App Notes Packaging Information Link Packaging Information EN45545-2 Fire & Smoke Test Conditions. Item Standard Oxygen Index Test R22 Smoke Density Test Smoke Toxicity Test Oxygen Index Test R23 Smoke Density Test Smoke Toxicity Test R24 Oxygen Index Test R25 Glow - Wire Test R26 Vertical Flame Test Hazard Level EN 45545-2: 2013 EN ISO 4589-2: 2006 EN 45545-2: 2013 EN ISO 5659-2: 2013 EN 45545-2: 2013 NF X70-100: 2006 EN 45545-2: 2013 EN ISO 4589-2: 2006 EN 45545-2: 2013 EN ISO 5659-2: 2013 EN 45545-2: 2013 NF X70-100: 2006 EN45545-2: 2013 EN ISO 4589-2 EN 45545-2:2013 EN 60695-2-11:2001 EN 45545-2: 2013 EN 60695-11-10: 2013 HL1, HL2, HL3 HL1, HL2 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 CHARACTERISTIC CURVE Power Derating Curve CQB200-24S Derating Curve with Heatsink QBL127 (Vin=24V) 110 100 90 80 70 60 50 40 30 20 10 0 Natural Output Power (%) Output Power (%) CQB200-24S Derating Curve without Heatsink (Vin=24V) 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 0 10 20 30 40 50 60 70 80 90 100 110 110 100 90 80 70 60 50 40 30 20 10 0 Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 0 Ambient Temperature (℃) 10 20 30 40 50 60 70 80 90 100 110 Ambient Temperature (℃) Output Power (%) CQB200-24S Derating Curve with Heatsink QBT210 (Vin=24V) 110 100 90 80 70 60 50 40 30 20 10 0 Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 0 10 20 30 40 50 60 70 80 90 100 110 Ambient Temperature (℃) www.cincon.com 4 REVISION: V10 CQB200 Series Performance Data CQB200-24S24 Eff Vs Io @25 Deg. C CQB200-24S24 Pd Vs Po @25 Deg. C Power Dissipation (W) Efficincy (%) 100% 90% 18V 24V 36V 80% 10% 20% 30% 40% 50% 60% 70% 80% 22 20 18 16 14 12 10 8 6 4 2 0 90% 100% 18V 24V 36V 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) CQB200-24S28 Eff Vs Io @25 Deg. C CQB200-24S28 Pd Vs Po @25 Deg. C Power Dissipation (W) Efficincy (%) 100% 90% 18V 24V 36V 80% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% 20 18 16 14 12 10 8 6 4 2 0 18V 24V 36V 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) MECHANICAL SPECIFICATION 0.600[15.24] 1.03[26.2] 1.45 [36.8] 2.000[50.8] 3 2 0.600[15.24] 0.300[7.62] 2.28 [57.9] Pin 1 2 3 4 5 6 7 8 4 5 6 7 8 BOTTOM VIEW 1 Function +V Input On/Off -V Input -V Output -Sense Trim +Sense +V Output CASE QB All Dimensions In Inches(mm) Tolerances Inches: X.XX= ±0.02 , X.XXX= ±0.010 Millimeters: X.X= ±0.5 , X.XX=±0.25 1.86[47.2] Mounting Inserts M3*0.5 Through 2pl. 0.059[1.50] DIA 2PLACES 0.040[1.02] 0.16min [4.1] 0.50 [12.7] DIA 6PLACES 5 REVISION: V10
CQB200-24S28 价格&库存
很抱歉,暂时无法提供与“CQB200-24S28”相匹配的价格&库存,您可以联系我们找货
CQB200-24S28
  • 1+1160.082731+149.91993
  • 5+1116.845825+144.33233
  • 10+1098.6890110+141.98589
  • 25+1075.1007325+138.93753
  • 50+1057.5766850+136.67286
库存:20
