CQB50W8-36S12-CMFD
CQB50W8-36S12-CMFD
    CINCON
    DC/DC CONVERTER 12V 50W
CQB50W8-36S12-CMFD 数据手册
CQB50W8 CMFC(D) SERIES 50 WATT 8:1 INPUT ISOLATED DC-DC CONVERTERS Features  Efficiency Up to 90%  Fixed Switching Frequency  Regulated Outputs  Remote On/Off  Low No Load Power Consumption  Fully protected (OTP/OCP/OVP/UVLO)  3000Vac I/O Isolation  Operating Case Temperature -40 to +105℃  UL62368-1 2nd (Reinforce Insulation) Approval for DC Modules  EN50155 for EMC, Environmental and Characteristic  Shock & Vibration EN50155 (EN61373) Compliant  Fire & Smoke EN45545-2 Compliant  Safety Meets IEC/EN/UL 62368-1  Build-In EMI Filter  Chassis Mount, Baseplate Cooled MODEL NUMBER CQB50W8-36S12□-CMFC CQB50W8-36S12□-CMFD CQB50W8-36S15□-CMFC CQB50W8-36S15□-CMFD CQB50W8-36S24□-CMFC CQB50W8-36S24□-CMFD CQB50W8-36S28□-CMFC CQB50W8-36S28□-CMFD CQB50W8-36S48□-CMFC CQB50W8-36S48□-CMFD INPUT OUTPUT OUTPUT CURRENT INPUT CURRENT % CAPACITOR VOLTAGE VOLTAGE MIN. MAX. 9.5-75 VDC 12 VDC 0 mA 4.17 A 10 mA 1544mA 90 8000µF 9.5-75 VDC 15 VDC 0 mA 3.33 A 10 mA 1542mA 90 6800µF 9.5-75 VDC 24 VDC 0 mA 2.08 A 12 mA 1541mA 90 2350µF 9.5-75 VDC 28 VDC 0 mA 1.79 A 12 mA 1547mA 90 2350µF 9.5-75 VDC 48 VDC 0 mA 1.05 A 12 mA 1556mA 90 700µF NO LOAD FULL LOAD EFF. LOAD MAX. NOTE: 1. Nominal Input Voltage 36 VDC. 2. □ = N or none 3. VR1 is Used for Output Voltage Adjustment. 4. Refer to Application Note for Thermal Resistance and Derating Information. 5. TVS is Included for Input Surge Voltage Protection. 6. Recommend an External Fuse for Input Reverse Polarity Protection (shunt diode is included inside). 7. Output connector CN3 wafer with TAIWAN KING PIN TERMINAL P110I series and mate with JST housing PH series or equivalent. 8. CN1 & CN2 connection: DINKLE EK500V-04P series or equivalent, suitable electric wire: 24~12AWG (IEC 0.5~2.5mm2). PART NUMBER Series CQB50W8- CQB50W8 Nominal Input Voltage II 36: 36 VDC Number of Outputs O S: Single Nominal Output Voltage XX 12: 12VDC 15: 15VDC 24: 24VDC 28: 28VDC 48: 48VDC Remote On/Off Logic L None: Chassis Mount Type -YYY Positive CMF: N: Negative Chassis Mount Built in Filter C: Z Open Frame D: With Cover Part Number Example: CQB50W8-36S12N-CMFC: Chassis Mount, 50W, 8:1 9.5-75Vdc Input, Single 12Vdc Output, Negative Logic, Open Frame www.cincon.com 1 REVISION: V10 CQB50W8 CMFC(D) Series TECHNICAL SPECIFICATIONS (All specifications are typical at nominal input, full load at 25°C unless otherwise noted.) ABSOLUTE MAXIMUM RATINGS PARAMETER NOTES and CONDITIONS Device Min. Input Voltage Continuous All -0.3 Input Surge Voltage 100ms max. All Operating Case Temperature At the Center Part of Base Plate All -40 All -40 Device Min. All Storage Temperature Typ. Max. Units 75 Vdc 100 Vdc 105 °C 105 °C Typ. Max. Units 9.5 36 75 Vdc 8.8 9.3 Vdc 7.9 8.4 Vdc INPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Operating Input Voltage Input Under Voltage Lockout Turn-On Voltage Threshold Full Load All 8.4 Turn-Off Voltage Threshold Full Load All 7.5 Lockout Hysteresis Voltage Full Load All Maximum Input Current Vin=9.5V, Full Load All No-Load Input Current Vin=36V, Io=0A Vdc 0.9 A 7.5 mA See Model Number Table OUTPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Voltage Set Point Accuracy Vin=36V, Full Load, Tc=25°C All -1.0 Load Regulation Full Load to No Load Line Regulation Vin=High Line to Low Line, Full Load Temperature Coefficient Tc=-40°C to 105°C Typ. Max. Units +1.0 % All ±0.2 % All ±0.2 % All ±0.02 %/°C 12Vo 150 15Vo 150 24Vo 240 28Vo 240 48Vo 480 12Vo 80 Output Voltage Regulation Output Voltage Ripple and Noise (5Hz to 20MHz bandwidth) Peak-to-Peak Full load, 1uF ceramic capacitor RMS. Output Current Range Vin= 9.5 to 75V Over Current Protection Hiccup Mode. Auto Recovery. 80 24Vo 120 28Vo 120 48Vo 220 All 110 Full load (resistive) Output Voltage Trim Range Po≦max rated power, Io ≦ Io_max Output Voltage Remote Sense Range Po≦max rated power, Io ≦ Io_max % of nominal Vo Limited Voltage, % of Nominal Vo 210 uF See Model Number Table All % Continuous, Auto Recovery. All External Load Capacitance 150 mV A See Model Number Table Short Circuit Protection Over Voltage Protection 15Vo mV -20 All +15 % +15 % All 117 125 140 % Device Min. Typ. Max. Units EFFICIENCY PARAMETER NOTES and CONDITIONS 100% Load Vin=36V www.cincon.com See Model Number Table 2 % REVISION: V10 CQB50W8 CMFC(D) Series DYNAMIC CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Typ. Max. Units Output Voltage Current Transient Error Band Recovery Time Turn-On Delay and Rise Time Turn-On Delay Time, From On/Off Control Turn-On Delay Time, From Input Output Voltage Rise Time 75% to 100% of Io_max step load change di/dt=0.1A/us (within 1% Vout nominal) Full load (Constant resistive load) All ±5 % All 250 us Von/off to 10%Vo_set, Remote On All 20 ms Vin_min to 10%Vo_set, Power Up All 20 ms 10%Vo_set to 90%Vo_set All 10 ms ISOLATION CHARACTERISTICS PARAMETER Isolation Voltage (100% factory Hi-Pot tested @2sec.) Isolation Resistance Isolation Capacitance NOTES and CONDITIONS Device 1 minute; Input to Output, All 1 minute; Input to Case (Base Plate), All Min. Typ. 1 minute; Output to Case (Base Plate) All Input to Output All Input to Output All 15000 Input to Case (Base Plate) All 16000 Output to Case (Base Plate) All 23000 Max. Units 3000 Vac 4200 Vdc 2100 Vac 3000 Vdc 1500 Vac 2100 Vdc MΩ 100 pF FEATURE CHARACTERISTICS PARAMETER NOTES and CONDITIONS Switching Frequency Pulse wide modulation (PWM), Fixed Device Min. Typ. Max. Units All 180 200 220 KHz On/Off Control, Positive Remote On/Off logic, Refer to –Vin pin. Logic Low (Module Off) Von/off at Ion/off=1.0mA All 0 1.0 V Logic High (Module On) Von/off at Ion/off=0.0uA, Pin open=On All 4.0 75 V Von/off at Ion/off=0.0uA, Pin open=Off All 4.0 75 V Von/off at Ion/off=1.0mA All 0 1.0 V Ion/off at Von/off=0V All 1 mA Logic High, Von/off=15V All 30 uA 10 mA On/Off Control, Negative Remote On/Off logic, Refer to –Vin pin Logic High (Module Off) Logic Low (Module On) On/Off Current (for both remote on/off logic) Leakage Current (for both remote on/off logic) Off Converter Input Current Over Temperature Shutdown Over Temperature Recovery 0.3 Shutdown input idle current All 5 Temperature at the Center Part of Base Plate, Non-Latching All 110 °C All 100 °C GENERAL SPECIFICATIONS PARAMETER MTBF NOTES and CONDITIONS Io=100% of Io_max; MIL-HDBK - 217F_Notice 1, GB, 25°C Weight Base plate Material Aluminum Potting Material UL 94V-0 (DC Module) www.cincon.com 3 Device Min. Typ. 36S12 526 36S15 585 36S24 577 36S28 568 36S48 594 -CMFC 215 -CMFD 300 Max. Units K hours grams REVISION: V10 CQB50W8 CMFC(D) Series GENERAL SPECIFICATIONS Shock/Vibration EN50155 (EN61373) Compliant Humidity 95% RH max. Non Condensing Altitude 5000m Operating Altitude, 12000m Transport Altitude Thermal Shock MIL-STD-810F Fire & Smoke EN45545-2 Compliant EMI EN55032 & EN50155 Compliant ESD EN61000-4-2 Level 3: Air ±8kV, Contact ±6kV Perf. Criteria A Radiated immunity EN61000-4-3 Level 3: 80~1000MHz, 20V/m Perf. Criteria A Fast Transient EN61000-4-4 Level 3: On power input port, ±2kV Perf. Criteria A Surge EN61000-4-5 Level 4: Line to earth, ±4kV, Line to line, ±2kV Perf. Criteria A Conducted immunity EN61000-4-6 Level 3: 0.15~80MHz, 10V Perf. Criteria A Interruptions of Voltage Supply EN50155 Class S3: 20ms interruptions Perf. Criteria A Supply Change Over EN50155 Class C2: During a supply break of 30 ms Application Note Link Class A Perf. Criteria A CQB50W8-36S CMFC(D) Series App Notes Packaging Information Link Packaging Information Immunity to Environmental Conditions. Phenomenon EN50155; 2017 Reference Clause(s) Reference Standard Low Temperature Start-up test 13.4.4 EN 60068-2-1 Dry Heat Test 13.4.5 EN 60068-2-2 Low Temperature Storage Test 13.4.6 EN 60068-2-1 Cyclic Damp Heat Test 13.4.7 EN 60068-2-30 Random Vibration Test 13.4.11 EN 61373 Simulated Long Life Test at Increased Random Vibration Levels 13.4.11 EN 61373 Shock Test 13.4.11 EN 61373 www.cincon.com 4 Test Conditions Class OT6 Temperature: -40℃ Duration: 2 hrs Class OT6 & ST2 Temperature: 85℃ Duration: 6 hrs Extended temperature: 100℃ Extended Duration: 10min Temperature: -40℃ Duration: 16 hrs Temperature: 25℃ - 55℃ Humidity: 90% RH Duration: 48 hrs Temperature: 25℃ +/- 10℃ Humidity: 50% +/-25% RH Frequency range: 5 ~ 150 Hz 2 Vertical: 1.01 𝑚⁄𝑠 2 Transverse: 0.450 𝑚⁄𝑠 2 Longitudinal: 0.700 𝑚⁄𝑠 Duration: 10 min / axis Temperature: 25℃ +/-10℃ Humidity: 50% +/-25% RH Frequency range: 5 ~ 150 Hz 2 Vertical: 5.72 𝑚⁄𝑠 2 Transverse: 2.55 m⁄s 2 ⁄ Longitudinal: 3.96 𝑚 𝑠 Duration: 5 hrs / axis Temperature: 25℃ +/-10℃ Humidity: 50% +/-25% RH Frequency range: 5 ~ 150 Hz 2 +/-Vertical: 30 m⁄s 2 +/-Transverse: 30 𝑚⁄𝑠 2 +/-Longitudinal: 50 𝑚⁄𝑠 Duration: 30ms x18 (Each axis 3 shocks) Result Pass Pass Pass Pass Pass Pass Pass REVISION: V10 CQB50W8 CMFC(D) Series EN45545-2 Fire & Smoke Test Conditions. Item Standard EN 45545-2: 2013 EN ISO 4589-2: 2006 EN 45545-2: 2013 EN ISO 5659-2: 2013 EN 45545-2: 2013 NF X70-100: 2006 EN 45545-2: 2013 EN ISO 4589-2: 2006 EN 45545-2: 2013 EN ISO 5659-2: 2013 EN 45545-2: 2013 NF X70-100: 2006 EN45545-2: 2013 EN ISO 4589-2 EN 45545-2:2013 EN 60695-2-11:2001 EN 45545-2: 2013 EN 60695-11-10: 2013 Oxygen Index Test R22 Smoke Density Test Smoke Toxicity Test Oxygen Index Test R23 Smoke Density Test Smoke Toxicity Test R24 Oxygen Index Test R25 Glow - Wire Test R26 Vertical Flame Test Hazard Level HL1, HL2, HL3 HL1, HL2 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 CHARACTERISTIC CURVE Output Power (%) Power Derating Curve CQB50W8-36SXX-CMFC(D) Derating Curve with Heat Sink (Vin=36V) 120 110 100 90 80 70 60 50 40 30 20 10 0 75 80 Heat Sink with FBL254 Heat Sink with Iron Plate (17x17x0.04 inch) 0 10 20 30 40 50 60 70 80 90 100 110 Ambient Temperature (℃) Performance Data CQB50W8-36S12-CMFC Eff Vs Io @25 Deg. C CQB50W8-36S12-CMFC Pd Vs Po @25 Deg. C Power Dissipation (W) Efficincy (%) 100% 90% 80% 9.5V 12V 24V 36V 48V 75V 70% 60% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) www.cincon.com 13 12 11 10 9 8 7 6 5 4 3 2 1 0 9.5V 12V 24V 36V 48V 75V 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 5 REVISION: V10 CQB50W8 CMFC(D) CQB50W8-36S15-CMFC Eff Vs Io @25 Deg. C CQB50W8-36S15-CMFC Pd Vs Po @25 Deg. C Power Dissipation (W) Efficincy (%) 100% 90% 80% 9.5V 12V 24V 36V 48V 75V 70% 60% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% 60% 40% 50% 60% 70% 80% 24V 36V 48V 75V 0% Power Dissipation (W) Efficincy (%) 60% 40% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% 50% 60% 70% 80% 12 11 10 9 8 7 6 5 4 3 2 1 0 90% 100% 9.5V 12V 24V 36V 48V 75V 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) CQB50W8-36S48-CMFC Eff Vs Io @25 Deg. C CQB50W8-36S48-CMFC Pd Vs Po @25 Deg. C Power Dissipation (W) 100% 90% Efficincy (%) 12V CQB50W8-36S28-CMFC Pd Vs Po @25 Deg. C 9.5V 12V 24V 36V 48V 75V 80% 9.5V 12V 24V 36V 48V 75V 70% 60% 40% 50% 60% 70% 80% 90% 100% Current Load (%) www.cincon.com 9.5V CQB50W8-36S28-CMFC Eff Vs Io @25 Deg. C 70% 30% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 80% 20% 75V 12 11 10 9 8 7 6 5 4 3 2 1 0 90% 100% 90% 50% 10% 48V Current Load (%) 100% 30% 36V 0% Power Dissipation (W) Efficincy (%) 9.5V 12V 24V 36V 48V 75V 20% 24V CQB50W8-36S24-CMFC Pd Vs Po @25 Deg. C 70% 50% 10% 12V CQB50W8-36S24-CMFC Eff Vs Io @25 Deg. C 80% 30% 9.5V Output Power (%) 90% 20% 13 12 11 10 9 8 7 6 5 4 3 2 1 0 Current Load (%) 100% 50% 10% Series 12 11 10 9 8 7 6 5 4 3 2 1 0 9.5V 12V 24V 36V 48V 75V 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 6 REVISION: V10 CQB50W8 CMFC(D) Series MECHANICAL SPECIFICATION CFMC CN3 LED 2.40[61.0] VR1 CN2 5 6 7 8 CN1 1 2 3 4 0.200[5.08] 0.200[5.08] 2.000[50.80] ] 50 4. [ 77 .1 0 Φ 4- 4.60[116.8] 4.200[106.68] JP2 1.46[37.0]max 0.52[13.20]max JP1 1234 CN3 CFMD with Cover VR1 CN2 5 6 7 8 CN1 1 2 3 4 CN3 LED JP2 1.46[37.0]max 0.52[13.20]max JP1 Millimeters:x.x=±0.5 , x.xx±0.25 2.49[63.4] 0 Φ 4- 0.200[5.08] 2.000[50.80] 4.200[106.68] ] 50 4. [ 77 All Dimensions in Inches[mm] .1 Tolerance Inches:x.xx=±0.02 , x.xxx=±0.010 0.248[6.31] 4.60[116.8] 1234 CN1&CN2 PIN CONNECTION Function Pin 1 +V Input 2 -V Input Remote 3 Case 4 +V Output 5 +V Output 6 -V Output 7 -V Output 8 CN3 PIN CONNECTION Function Pin -V Output 1 2 -Sense +Sense 3 +V Output 4 *JP1:Short PIN1 & PIN2 *JP2:Short PIN3 & PIN4 CN3 7 REVISION: V10
CQB50W8-36S12-CMFD 价格&库存
很抱歉,暂时无法提供与“CQB50W8-36S12-CMFD”相匹配的价格&库存,您可以联系我们找货
CQB50W8-36S12-CMFD
  • 1+1333.016111+166.57330
  • 5+1269.806135+158.67460
  • 25+1157.6739825+144.66260
库存:3
CQB50W8-36S12-CMFD
  • 1+1581.898881+197.67362
  • 5+1522.897265+190.30080
  • 10+1498.1279310+187.20563
  • 25+1465.9544725+183.18524
  • 50+1442.0426650+180.19723
