CQB75-300S24N-CMFC
CQB75-300S24N-CMFC
    CINCON
    开放框架 直流转换器 1 输出 24V 3.12A 450V 输入
CQB75-300S24N-CMFC 数据手册
CQB75-300S-CMFC(D) SERIES 50-75 WATT 2:1 INPUT ISOLATED DC-DC CONVERTERS Features  Efficiency Up to 90%  Fixed Switching Frequency  Regulated Outputs  Remote On/Off  Low No Load Power Consumption  Fully protected (OTP/OCP/OVP/UVLO)  3000Vac I/O Isolation  Operating Case Temperature -40 to +100℃  EN55032/22 for EMC Characteristic  Shock & Vibration Mil-STD-810F Compliant  Fire & Smoke EN45545-2 Compliant  Safety Meets IEC/EN/UL 62368-1  Build-In EMI Filter  Chassis Mount, Baseplate Cooled OUTPUT CURRENT INPUT CURRENT MODEL INPUT OUTPUT NUMBER VOLTAGE VOLTAGE MIN. MAX. 180-450 VDC 5 VDC 0 mA 15.0 A 10 mA 305 mA 82 15000uF 180-450 VDC 12 VDC 0 mA 6.25 A 10 mA 284 mA 88 6250uF 180-450 VDC 15 VDC 0 mA 5.0 A 10 mA 284 mA 88 5000uF 180-450 VDC 24 VDC 0 mA 3.12 A 10 mA 280 mA 90 3300µF 180-450 VDC 48 VDC 0 mA 1.56 A 10 mA 281 mA 89 1000µF CQB75-300S05□-CMFC CQB75-300S05□-CMFD CQB75-300S12□-CMFC CQB75-300S12□-CMFD CQB75-300S15□-CMFC CQB75-300S15□-CMFD CQB75-300S24□-CMFC CQB75-300S24□-CMFD CQB75-300S48□-CMFC CQB75-300S48□-CMFD NO LOAD % CAPACITOR FULL LOAD EFF. LOAD MAX. NOTE: 1. Nominal Input Voltage 300 VDC 2. □ = N or none 3. VR is Used for Output Voltage Adjustment. 4. Refer to Application Note for Thermal Resistance and Derating Information. 5. TVS is Included for Input Surge Voltage Protection. 6. Recommend an External Fuse for Input Reverse Polarity Protection (shunt diode is included inside). 7. Output connector CN3 wafer with TAIWAN KING PIN TERMINAL P110I series and mate with JST housing PH series or equivalent. 8. CN1 connection: DINKLE 166-04P5 series or equivalent, suitable electric wire: 18~12AWG (IEC 0.5~4mm2). 9. CN2 connection: DINKLE EK500V-04P series or equivalent, suitable electric wire: 24~12AWG (IEC 0.5~2.5mm2). PART NUMBER Series CQB75- Nominal Input Voltage II CQB75 300: 300 VDC Number of Outputs O S: Single Nominal Output Voltage XX 05: 5VDC 12: 12VDC 15: 15VDC 24: 24VDC 48: 48VDC Remote On/Off Logic L None: Chassis Mount Type -YYY Positive CMF: N: Negative Chassis Mount Built in Filter Z C: Open Frame D: With Cover Part Number Example: CQB75-300S12N-CMFC: Chassis Mount, 75W, 2:1 180-450Vdc Input, Single 12Vdc Output, Negative Logic, Open Frame www.cincon.com 1 REVISION: V13 CQB75-300S CMFC(D) Series TECHNICAL SPECIFICATIONS (All specifications are typical at nominal input, full load at 25°C unless otherwise noted.) ABSOLUTE MAXIMUM RATINGS PARAMETER NOTES and CONDITIONS Device Min. Input Voltage Input Surge Voltage Continuous All -0.3 100ms max. All Operating Case Temperature At the Center Part of Base Plate All Storage Temperature Typ. Max. Units 450 Vdc 500 Vdc -40 100 °C All -40 105 °C Device Min. Typ. Max. Units All 180 300 450 Vdc INPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Operating Input Voltage Input Under Voltage Lockout Turn-On Voltage Threshold Full Load All 165 170 175 Vdc Turn-Off Voltage Threshold Full Load All 155 160 165 Vdc Lockout Hysteresis Voltage Full Load All 10 300S05 520 Other 477 Maximum Input Current Vin=180V, Full Load No-Load Input Current Vin=300V, Io=0A Vdc mA mA See Model Number Table OUTPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Voltage Set Point Accuracy Vin=300V, Full Load, Tc=25°C All -1.0 Load Regulation Full Load to No Load Line Regulation Vin=High Line to Low Line, Full Load Temperature Coefficient Tc=-40°C to 100°C Typ. Max. Units +1.0 % All ±0.2 % All ±0.2 % All ±0.02 %/°C 05Vo 12Vo 15Vo 24Vo 48Vo 100 150 150 240 480 mV Output Voltage Regulation Output Voltage Ripple and Noise (5Hz to 20MHz bandwidth) Peak-to-Peak Full load, 1uF ceramic capacitors RMS. Output Current Range Vin= 180 to 450V Over Current Protection Hiccup Mode. Auto Recovery. 60 60 60 100 48Vo 200 All 110 160 % Continuous, Auto Recovery. All Full load (resistive) 135 mV A See Model Number Table Short Circuit Protection External Load Capacitance 05Vo 12Vo 15Vo 24Vo uF See Model Number Table Output Voltage Trim Range Po≦max rated power, Io ≦ Io_max Output Voltage Remote Sense Range Po≦max rated power, Io ≦ Io_max % of nominal Vo 05Vo Other 05Vo Other Over Voltage Protection Limited Voltage, % of Nominal Vo All 117 125 140 % Device Min. Typ. Max. Units -20 -20 +10 +20 +10 +20 % % EFFICIENCY PARAMETER NOTES and CONDITIONS 100% Load Vin=300V www.cincon.com See Model Number Table 2 % REVISION: V10 CQB75-300S CMFC(D) Series DYNAMIC CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Typ. Max. Units Output Voltage Current Transient Error Band Recovery Time Turn-On Delay and Rise Time Turn-On Delay Time, From On/Off Control Turn-On Delay Time, From Input Output Voltage Rise Time 75% to 100% of Io_max step load change di/dt=0.1A/us (within 1% Vout nominal) Full load (Constant resistive load) All ±5 % All 250 us Von/off to 10%Vo_set, Remote On All 30 ms Vin_min to 10%Vo_set, Power Up All 30 ms 10%Vo_set to 90%Vo_set All 30 ms ISOLATION CHARACTERISTICS PARAMETER Isolation Voltage (100% factory Hi-Pot tested @2sec.) Isolation Resistance Isolation Capacitance NOTES and CONDITIONS Device 1 minute; Input to Output, All 1 minute; Input to Case (Base Plate), All 1 minute; Output to Case (Base Plate) All Input to Output All Input to Output All Input to Case (Base Plate) Output to Case (Base Plate) Min. Typ. Max. Units 3000 Vac 4200 Vdc 2500 Vac 3500 Vdc 500 Vac 700 Vdc MΩ 100 05Vo 12Vo 15Vo 24Vo 48Vo 333 2220 1880 1560 2000 2080 All 18800 pF FEATURE CHARACTERISTICS PARAMETER NOTES and CONDITIONS Switching Frequency Pulse wide modulation (PWM), Fixed Device Min. Typ. Max. Units All 270 300 330 KHz On/Off Control, Positive Remote On/Off logic, Refer to –Vin pin. Logic Low (Module Off) Von/off at Ion/off=0.0uA, Pin open=Off All 0 1.2 V Logic High (Module On) Von/off at Ion/off=1.0mA All 3.5 12 V Von/off at Ion/off=1.0mA All 3.5 12 V Von/off at Ion/off=0.0uA, Pin open=On All 0 1.2 V Ion/off at Von/off=3.5-12V All 0.3 2.1 mA 5 mA On/Off Control, Negative Remote On/Off logic, Refer to –Vin pin Logic High (Module Off) Logic Low (Module On) On/Off Current (for both remote on/off logic) Off Converter Input Current Over Temperature Shutdown Over Temperature Recovery Shutdown input idle current All 3 Temperature at the Center Part of Base Plate, Non-Latching All 110 °C All 100 °C GENERAL SPECIFICATIONS PARAMETER MTBF NOTES and CONDITIONS Io=100% of Io_max; MIL-HDBK - 217F_Notice 1, GB, 25°C Weight Base plate Material Aluminum Potting Material UL 94V-0 (DC Module) www.cincon.com 3 Device 05Vo 12Vo 15Vo 24Vo Min. Typ. 466 566 607 700 48Vo 650 -CMFC 210 -CMFD 296 Max. Units K hours grams REVISION: V10 CQB75-300S CMFC(D) Series Shock/Vibration MIL-STD-810F Compliant Humidity 95% RH max. Non Condensing Altitude 3000m Operating Altitude, 12000m Transport Altitude Thermal Shock MIL-STD-810F Fire & Smoke EN45545-2 Compliant EMI EN55032 & EN55022 Compliant ESD EN61000-4-2 Level 3: Air ±8kV, Contact ±6Kv Perf. Criteria A Radiated immunity EN61000-4-3 Level 3: 80~1000MHz, 20V/m Perf. Criteria A Fast Transient EN61000-4-4 Level 3: On power input port, ±2Kv Perf. Criteria A Surge EN61000-4-5 Level 4: Line to earth, ±4kV, Line to line, ±2Kv Perf. Criteria A Conducted immunity Power Frequency Magnetic Field immunity Application Note Link EN61000-4-6 Level 3: 0.15~80MHz, 10V Perf. Criteria A EN61000-4-8 50/60Hz, 3A/m (r.m.s.) Perf. Criteria A Class A CQB75-300S CMFC(D) Series App Notes Packaging Information Link Packaging Information Immunity to Environmental Conditions. Phenomenon Reference Clause(s) Reference Standard Vibration Test MIL-STD-810F Table 514.5C-VIII Figure 514.5C-6 MIL-STD-810F Shock Test MIL-STD-810F 516.5 Table 516.5-I MIL-STD-810F Thermal Shock Cycling Test MIL-STD-810F 503.4 Figure 503.4-1 MIL-STD-810F Thermal Humidity Cycling Test MIL-STD-810F Notice 3 Method 507.4 MIL-STD-810F Test Conditions Result Unit are non-operating Vibration Waveform: Random Vibration Frequency: 15 ~ 2000 Hz Total Grms: 4.01997 grms Vibration axis: X、Y、Z axis Duration: 1hr/axis Wave form: Sawtooth wave Test Category: Crash Hazard Test for Ground Equipment Duration: 10 ms Peak Acceleration: 75 G Cross-over Frequency: 80 Hz No. of Shock: Each axis 3 times Shock Direction: ±X, ±Y, ±Z axis Temperature:-55℃to 105℃ Humidity: 95%RH Duration: 8hrs/ 3 times cycling& 4hrs dwell time Temperature: 60℃to 30℃ Humidity: 95%RH Duration: 240 hrs Vibration Test Shock Test Thermal Shock Cycling Test Thermal Humidity Cycling Test EN45545-2 Fire & Smoke Test Conditions. Item Standard EN 45545-2: 2013 EN ISO 4589-2: 2006 EN 45545-2: 2013 EN ISO 5659-2: 2013 EN 45545-2: 2013 NF X70-100: 2006 EN 45545-2: 2013 EN ISO 4589-2: 2006 EN 45545-2: 2013 EN ISO 5659-2: 2013 EN 45545-2: 2013 NF X70-100: 2006 EN45545-2: 2013 EN ISO 4589-2 EN 45545-2:2013 EN 60695-2-11:2001 EN 45545-2: 2013 EN 60695-11-10: 2013 Oxygen Index Test R22 Smoke Density Test Smoke Toxicity Test Oxygen Index Test R23 Smoke Density Test Smoke Toxicity Test R24 Oxygen Index Test R25 Glow - Wire Test R26 Vertical Flame Test www.cincon.com 4 Hazard Level HL1, HL2, HL3 HL1, HL2 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 REVISION: V10 CQB75-300S CMFC(D) Series CHARACTERISTIC CURVE Output Power (%) Power Derating Curve CQB75-300SXX-CMFC(D) Derating Curve with Heat Sink (Vin=300V) 120 110 100 90 80 70 60 50 40 30 20 10 0 66 71 Heat Sink with FBL254 Heat Sink with Iron Plate (17x17x0.04 inch) 0 10 20 30 40 50 60 70 80 90 100 110 Ambient Temperature (℃) Performance Data CQB75-300S05-CMFC Eff Vs Io @25 Deg. C CQB75-300S05-CMFC Pd Vs Po @25 Deg. C Power Dissipation (W) Efficincy (%) 90% 80% 70% 180V 60% 300V 450V 50% 10% 20% 30% 40% 50% 60% 70% 80% 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 90% 100% 180V 300V 450V 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) CQB75-300S12-CMFC Eff Vs Io @25 Deg. C CQB75-300S12-CMFC Pd Vs Po @25 Deg. C Power Dissipation (W) Efficincy (%) 90% 80% 70% 180V 60% 300V 450V 50% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) www.cincon.com 13 12 11 10 9 8 7 6 5 4 3 2 1 0 180V 300V 450V 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 5 REVISION: V10 CQB75-300S CMFC(D) CQB75-300S15-CMFC Eff Vs Io @25 Deg. C CQB75-300S15-CMFC Pd Vs Po @25 Deg. C Power Dissipation (W) 100% Efficincy (%) 90% 80% 70% 180V 300V 60% 450V 50% 10% 20% 30% 40% 50% 60% 70% 80% 12 11 10 9 8 7 6 5 4 3 2 1 0 90% 100% 180V 300V 450V 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) CQB75-300S24-CMFC Eff Vs Io @25 Deg. C CQB75-300S24-CMFC Pd Vs Po @25 Deg. C Power Dissipation (W) 100% Efficincy (%) 90% 80% 70% 180V 60% 300V 50% 450V 40% 10% 20% 30% 40% 50% 60% 70% 80% 12 11 10 9 8 7 6 5 4 3 2 1 0 180V 300V 450V 0% 90% 100% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) CQB75-300S48-CMFC Eff Vs Io @25 Deg. C CQB75-300S48-CMFC Pd Vs Po @25 Deg. C Power Dissipation (W) 100% Efficincy (%) 90% 80% 70% 180V 60% 300V 50% 450V 40% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) www.cincon.com Series 13 12 11 10 9 8 7 6 5 4 3 2 1 0 180V 300V 450V 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 6 REVISION: V10 CQB75-300S CMFC(D) Series MECHANICAL SPECIFICATION CMFC ] .50 4 [Φ 77 1 . Φ0 4- 4.60 [116.8] 4.200 [106.68] 0.200 [5.08] 5 CN2 6 7 8 2 3 4 0.200 [5.08] VR 1 2.000 [50.80] 2.40 [61.0] CN1 1.24 [31.4] 0.512 [13.00] CN3 1 2 3 CN3 CMFD with Cover 4.60 [116.8] 4.200 [106.68] 0.200 [5.08] 4- 0] .5 4 Φ 7[ 17 . Φ0 2 6 7 8 3 4 1.35 [34.2] 0.512 [13.00] CN3 7 2.000 [50.80] 2.49 [63.4] VR 5 CN2 0.247 [6.28] CN1 1 4 CN1 & CN2 PIN CONNECTION PIN Function 1 +V Input 2 -V Input 3 Remote 4 Case 5 +V Output 6 +V Output 7 -V Output 8 -V Output CN3 PIN CONNECTION 1 2 CN3 3 4 PIN Function 1 -V Output 2 -Sense 3 +Sense 4 +V Output All Dimensions in Inches[mm] Tolerance Inches: x.xx=±0.02, x .xxx=±0.010 Millimeters: x.x=±0.5, x.xx=±0.25 REVISION: V10
CQB75-300S24N-CMFC
物料型号:CQB75-300S-CMFC(D)系列
器件简介:该系列转换器提供高达90%的效率,具有固定的开关频率、调节输出、远程开关、低无负载功耗、全面保护(OTP/OCP/OVP/UVLO)、3000Vac输入/输出隔离、工作温度范围-40至+100℃,符合EMC特性EN55032/22、震动和冲击标准Mil-STD-810F以及防火和烟雾标准EN45545-2。
引脚分配:文档提供了详细的引脚分配图和每个引脚的功能说明。
参数特性:包括输入电压范围、输入浪涌电压、工作和存储温度、输入特性、输出特性、效率、动态特性、隔离特性、特性特性等详细参数。
功能详解:文档详细描述了转换器的工作原理和特性,如开关频率、远程开关控制、过温保护等。
应用信息:提供了应用指南链接和包装信息链接。
封装信息:包括机械规格和引脚连接详情。
CQB75-300S24N-CMFC 价格&库存
很抱歉,暂时无法提供与“CQB75-300S24N-CMFC”相匹配的价格&库存,您可以联系我们找货
CQB75-300S24N-CMFC
  • 1+1590.447101+206.75298
  • 5+1526.906445+198.49290
  • 10+1500.3229010+195.03713
  • 25+1465.8888825+190.56081
  • 50+1440.3721550+187.24372
库存:18
