CQB75-300S24
CQB75-300S24
    CINCON
    四分之一砖
    隔离模块 直流转换器 1 输出 24V 3.12A 180V - 450V 输入
CQB75-300S24 数据手册
CQB75-300S SERIES 75 WATT 2:1 INPUT ISOLATED DC-DC CONVERTER Features ⚫ Efficiency Up to 90% ⚫ Fixed Switching Frequency ⚫ Regulated Outputs ⚫ Remote On/Off ⚫ Low No Load Power Consumption ⚫ Fully protected (OTP/OCP/OVP/UVLO) ⚫ 3000Vac I/O Isolation ⚫ Operating Case Temperature -40 to +105℃ ⚫ Quarter Brick Size Meet Industrial Standard 2.28”x1.45”x0.5” ⚫ Safety Meets IEC/EN/UL 62368-1 2nd (Reinforce Insulation) ⚫ Shock & Vibration MIL-STD-810F Compliant ⚫ Fire & Smoke EN45545 Compliant ⚫ 3000m Operating Altitude OUTPUT CURRENT INPUT CURRENT MODEL INPUT OUTPUT CAPACITOR NUMBER VOLTAGE VOLTAGE MIN. MAX. NO LOAD FULL LOAD CQB75-300S05 180-450 VDC 5 VDC 0 mA 15 A 10 mA 305 mA 82 15000μF CQB75-300S12 180-450 VDC 12 VDC 0 mA 6.25 A 10 mA 281 mA 88 6250μF CQB75-300S15 180-450 VDC 15 VDC 0 mA 5A 10 mA 281 mA 90 5000μF CQB75-300S24 180-450 VDC 24 VDC 0 mA 3.12 A 10 mA 281 mA 90 3300μF CQB75-300S48 180-450 VDC 48 VDC 0 mA 1.56 A 10 mA 281 mA 89 1000μF % EFF. LOAD MAX. NOTE: 1. Nominal Input Voltage 300 VDC 2. Measured at 300Vin 3. An External Input Capacitor 33uF for All Models are Recommended to Reduce Input Ripple Voltage PART NUMBER Series CQB75 Nominal Input Voltage II CQB75 300 Number of Outputs O S: Single Nominal Output Voltage XX 05: 5.0VDC 12: 12VDC 15: 15VDC 24: 24VDC 48: 48VDC Remote On/Off Logic L None: N: Positive Negative Mounting Inserts -Y (Option) None: -C: M3x0.5 Mounting Inserts Clear Mounting Insert (3.2mm DIA.) Part Number Example: CQB75-300S12N-C: Quarter Brick, 75W, 2:1 180-450Vdc Input, Single 12Vdc Output, Negative Logic, Clear Mounting Insert www.cincon.com 1 REVISION: V10 CQB75-300S Series TECHNICAL SPECIFICATIONS (All specifications are typical at nominal input, full load at 25°C unless otherwise noted.) ABSOLUTE MAXIMUM RATINGS PARAMETER NOTES and CONDITIONS Device Min. Input Voltage Continuous All -0.3 Input Surge Voltage 100ms max. All Operating Case Temperature At the Center Part of Base Plate All -40 Max. Units 450 Vdc 500 Vdc 105 °C All -55 125 °C Device Min. Typ. Max. Units All 180 300 450 Vdc Turn-On Voltage Threshold All 165 170 175 Vdc Turn-Off Voltage Threshold All 155 160 165 Vdc Lockout Hysteresis Voltage All 10 05Vo 520 Others 477 Storage Temperature Typ. INPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Operating Input Voltage Input Under Voltage Lockout Maximum Input Current Vin=180V, Full Load. No-Load Input Current Vin=300V, Io=0A Input Filter Pi filter. All Inrush Current (I2t) As per ETS300 132-2. All Input Reflected Ripple Current P-P thru 12uH inductor, 5Hz to 20MHz. All Vdc mA mA See Model Number Table 0.1 A2s mA 30 OUTPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Voltage Set Point Accuracy Vin=300V, Full Load, Tc=25°C All -1.0 Load Regulation Full Load to No Load All Line Regulation Vin=High Line to Low Line, Full Load Temperature Coefficient Tc=-40°C to 105°C Typ. Max. Units +1.0 % Output Voltage Regulation ±0.2 % All ±0.2 % All ±0.02 %/°C Output Voltage Ripple and Noise (5Hz to 20MHz bandwidth) Peak-to-Peak Output ripple and noise measured with an external MLCC 1000pF connected between –Vin to Case, and 10uF aluminum and 1uF ceramic capacitor across output for 48Vout, and with 10uF tantalum and 1uF ceramic capacitor for others. RMS. 05Vo 100 12Vo 150 15Vo 150 24Vo 240 48Vo 480 05Vo 60 12Vo 60 15Vo 60 24Vo 100 48Vo Output Current Range Vin= 180 to 450V Over Current Protection Hiccup Mode. Auto Recovery. Full load (resistive) Output Voltage Trim Range Po≦max rated power, Io ≦ Io_max Over Voltage Protection www.cincon.com 110 A 135 160 uF See Model Number Table Po≦max rated power, Io ≦ Io_max % of nominal Vo Limited Voltage, % of Nominal Vo 2 % Continuous, Auto Recovery. All External Load Capacitance Output Voltage Remote Sense Range All mV 200 See Model Number Table Short Circuit Protection mV 05Vo -20 +10 Others -20 +20 % 05Vo +10 % All +20 % 05Vo Others 112 122 % 130 % 130 % REVISION: V10 CQB75-300S Series EFFICIENCY PARAMETER NOTES and CONDITIONS 100% Load Vin=300V, Full Load. Device Min. Typ. Max. Units % See Model Number Table DYNAMIC CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Typ. Max. Units Output Voltage Current Transient Error Band Recovery Time Turn-On Delay and Rise Time Turn-On Delay Time, From On/Off Control Turn-On Delay Time, From Input Output Voltage Rise Time 75% to 100% of Io_max step load change di/dt=0.1A/us (within 1% Vout nominal) Full load (Constant resistive load) All ±5 % All 250 us Von/off to 10%Vo_set, Remote On All 30 ms Vin_min to 10%Vo_set, Power Up All 30 ms 10%Vo_set to 90%Vo_set All 30 ms ISOLATION CHARACTERISTICS PARAMETER NOTES and CONDITIONS 1 minute; Input to Output, Isolation Voltage (100% factory Hi-Pot tested @2sec.) Isolation Capacitance Min. Typ. All 1 minute; Input to Case (Base Plate), 1 minute; Output to Case (Base Plate) Isolation Resistance Device All All Input to Output All Input to Output All 333 Input to Case (Base Plate) All None Output to Case (Base Plate) All 4400 Max. Units 3000 Vac 4200 Vdc 2500 Vac 3500 Vdc 500 Vac 700 Vdc MΩ 100 pF FEATURE CHARACTERISTICS PARAMETER NOTES and CONDITIONS Switching Frequency Pulse wide modulation (PWM), Fixed Device Min. Typ. Max. Units All 270 300 330 KHz On/Off Control, Positive Remote On/Off logic, Refer to –Vin pin. Logic Low (Module Off) Von/off at Ion/off=1.0mA All 0 1.2 V Logic High (Module On) Von/off at Ion/off=0.0uA, Pin open=On All 3.5 75 V On/Off Control, Negative Remote On/Off logic, Refer to –Vin pin Logic High (Module Off) Logic Low (Module On) On/Off Current (for both remote on/off logic) Leakage Current (for both remote on/off logic) Off Converter Input Current Over Temperature Shutdown Over Temperature Recovery www.cincon.com Von/off at Ion/off=0.0uA, Pin open=Off All 3.5 75 V Von/off at Ion/off=1.0mA All 0 1.2 V Ion/off at Von/off=0V All 1 mA Logic High, Von/off=15V All 30 uA 10 mA 0.3 Shutdown input idle current All 5 Temperature at the Center Part of Base Plate, Non-Latching All 110 °C All 100 °C 3 REVISION: V10 CQB75-300S Series GENERAL SPECIFICATIONS PARAMETER MTBF NOTES and CONDITIONS Io=100% of Io_max; MIL-HDBK - 217F_Notice 1, GB, 25°C Weight Device Min. Typ. 300S05 850 300S12 850 300S15 850 300S24 850 300S48 1050 All 61 Max. Units K hours grams Case Material Plastic, DAP, UL 94V-0 Base plate Material Aluminum Potting Material Shock/Vibration UL 94V-0 Base: Copper Plating: Nickel with Matte Tin MIL-STD-810F Compliant Humidity 95% RH max. Non Condensing Altitude 3000m Operating Altitude, 12000m Transport Altitude Thermal Shock MIL-STD-810F Fire & Smoke EN45545-2 Compliant EMI Meets EN55032 & EN55022 Compliant (with external filter) ESD EN61000-4-2 Level 3: Air ±8kV, Contact ±6kV Perf. Criteria A Radiated immunity EN61000-4-3 EN61000-4-4 Perf. Criteria A Pin Material Class A Surge EN61000-4-5 Level 3: 80~1000MHz, 20V/m Level 3: On power input port, ±2kV, external input capacitor required, Level 4: Line to earth, ±4kV, Line to line, ±2kV Conducted immunity Power Frequency Magnetic Field immunity Application Note Link EN61000-4-6 Level 3: 0.15~80MHz, 10V Perf. Criteria A EN61000-4-8 50/60Hz, 3A/m (r.m.s.) Perf. Criteria A Fast Transient Perf. Criteria A Perf. Criteria A CQB75-300S Series App Notes Packaging Information Link Packaging Information Immunity to Environmental Conditions. Phenomenon Reference Clause Reference Standard Vibration Test MIL-STD-810F Table 514.5C-VIII Figure 514.5C-6 MIL-STD-810F Shock Test MIL-STD-810F 516.5 Table 516.5-I MIL-STD-810F Thermal Shock Cycling Test MIL-STD-810F 503.4 Figure 503.4-1 MIL-STD-810F Thermal Humidity Cycling Test MIL-STD-810F Notice 3 Method 507.4 MIL-STD-810F www.cincon.com 4 Test Conditions Unit are non-operating Vibration Waveform:Random Vibration Frequency:15 ~ 2000 Hz Total Grms:4.01997 grms Vibration axis:X、Y、Z axis Duration:1hr / axis Wave form:Sawtooth wave Test Category : Crash Hazard Test for Ground Equipment Duration:10 ms Peak Acceleration:75 G Cross-over Frequency:80 Hz No. of Shock:Each axis 3 times Shock Direction:±X , ±Y , ±Z axis Temperature:-55℃to 105℃ Humidity:95%RH Duration:8hrs/ 3 times cycling& 4hrs dwell time Temperature:60℃to 30℃ Humidity:95%RH Duration:240 hrs Result Pass Pass Pass Pass REVISION: V10 CQB75-300S Series EN45545-2 Fire & Smoke Test Conditions. Item Standard Oxygen Index Test R22 Smoke Density Test Smoke Toxicity Test Oxygen Index Test R23 Smoke Density Test Smoke Toxicity Test R24 Oxygen Index Test R25 Glow - Wire Test R26 Vertical Flame Test Hazard Level EN 45545-2: 2013 EN ISO 4589-2: 2006 EN 45545-2: 2013 EN ISO 5659-2: 2013 EN 45545-2: 2013 NF X70-100: 2006 EN 45545-2: 2013 EN ISO 4589-2: 2006 EN 45545-2: 2013 EN ISO 5659-2: 2013 EN 45545-2: 2013 NF X70-100: 2006 EN45545-2: 2013 EN ISO 4589-2 EN 45545-2:2013 EN 60695-2-11:2001 EN 45545-2: 2013 EN 60695-11-10: 2013 HL1, HL2, HL3 HL1, HL2 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 CHARACTERISTIC CURVE Power Derating Curve Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 0 Output Power (%) Output Power (%) 110 100 90 80 70 60 50 40 30 20 10 0 CQB75-300S12, 15, 24, 48 Derating Curve without Heatsink (Vin=300V) 10 110 100 90 80 70 60 50 40 30 20 10 0 20 30 40 50 60 70 80 90 100 110 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 10 20 30 40 50 60 70 80 90 100 110 Ambient Temperature (℃) CQB75-300S05 Derating Curve with Heatsink QBL127 (Vin=300V) CQB75-300S12, 15, 24, 48 Derating Curve with Heatsink QBL127 (Vin=300V) 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 10 Natural 0 Natural 0 110 100 90 80 70 60 50 40 30 20 10 0 Ambient Temperature (℃) Output Power (%) Output Power (%) CQB75-300S05 Derating Curve without Heatsink (Vin=300V) 20 30 40 50 60 70 80 90 100 110 Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 0 Ambient Temperature (℃) www.cincon.com 110 100 90 80 70 60 50 40 30 20 10 0 10 20 30 40 50 60 70 80 90 100 110 Ambient Temperature (℃) 5 REVISION: V10 CQB75-300S 110 100 90 80 70 60 50 40 30 20 10 0 CQB75-300S12, 15, 24, 48 Derating Curve with Heatsink QBL127 (Vin=300V) Output Power (%) Output Power (%) CQB75-300S05 Derating Curve with Heatsink QBT210 (Vin=300V) Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 0 10 20 30 40 50 60 70 80 90 Series 110 100 90 80 70 60 50 40 30 20 10 0 100 110 Natural 100 ft./min. 200 ft./min. 300 ft./min. 400 ft./min. 0 Ambient Temperature (℃) 10 20 30 40 50 60 70 80 90 100 110 Ambient Temperature (℃) Performance Data CQB75-300S05 Eff Vs Io @25 Deg. C CQB75-300S05 Pd Vs Po @25 Deg. C 18 Power Dissipation (W) 95% Efficincy (%) 90% 85% 80% 75% 180V 70% 300V 65% 60% 10% 450V 15 12 9 6 180V 3 300V 450V 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% Current Load (%) 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) CQB75-300S12 Eff Vs Io @25 Deg. C CQB75-300S12 Pd Vs Po @25 Deg. C Power Dissipation (W) 95% Efficincy (%) 90% 85% 80% 75% 180V 70% 300V 65% 60% 10% 450V 12 10 8 6 4 180V 2 300V 450V 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% Current Load (%) 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) CQB75-300S15 Eff Vs Io @25 Deg. C CQB75-300S15 Pd Vs Po @25 Deg. C Power Dissipation (W) 95% Efficincy (%) 90% 85% 80% 75% 180V 70% 300V 65% 60% 10% 450V 12 10 8 6 4 180V 2 300V 450V 0 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) www.cincon.com 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 6 REVISION: V10 CQB75-300S CQB75-300S24 Eff Vs Io @25 Deg. C Series CQB75-300S24 Pd Vs Po @25 Deg. C Power Dissipation (W) 95% Efficincy (%) 90% 85% 80% 75% 180V 70% 300V 65% 60% 10% 450V 12 10 8 6 180V 4 300V 2 450V 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% Current Load (%) 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) CQB75-300S48 Eff Vs Io @25 Deg. C CQB75-300S48 Pd Vs Po @25 Deg. C Power Dissipation (W) 95% Efficincy (%) 90% 85% 80% 75% 70% 180V 65% 300V 60% 55% 10% 450V 12 10 8 6 4 180V 2 300V 450V 0 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) www.cincon.com 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 7 REVISION: V10 CQB75-300S Series MECHANICAL SPECIFICATION BOTTOM VIEW 3 4 2 5 6 1 7 8 Mounting lnserts M3*0.5 Through 2pl. Φ0.040[1.02] 6pl. Φ0.059 [1.50] 2pl. 0.16 [4.1]min. 1.86 [47.2] 0.50 [12.8] 0.525 [13.34] 0.60 [15.2] 0.21 [5.3] 0.600 [15.24] 0.16 [4.1] 0.150 [3.81] 0.300 [7.62] 1.957 [49.70] 1.030 [26.15] 1.45 [36.8] 0.150 [3.81] 2.28 [57.9] PIN CONNECTION Pin Function 1 +V Input 2 On/Off 3 -V Input 4 -V Output 5 -Sense 6 Trim 7 +Sense 8 +V Output All Dimensions in Inches[mm] Tolerance Inches:x.xx=±0.02 ,x.xxx=±0.010 Millimeters:x.x=±0.5 , x.xx=±0.25 8 REVISION: V10
CQB75-300S24 价格&库存
很抱歉,暂时无法提供与“CQB75-300S24”相匹配的价格&库存,您可以联系我们找货
CQB75-300S24
  • 1+898.736871+112.41139
  • 5+865.268195+108.22523
  • 10+851.2098710+106.46686
  • 25+832.9455825+104.18241
  • 60+815.8334660+102.04208
库存:17
