CHB200W12-72S12
CHB200W12-72S12
    CINCON
    半砖
    隔离模块 直流转换器 1 输出 12V 16.7A 14V - 160V 输入
CHB200W12-72S12 数据手册
CHB200W12 SERIES 200 WATT 12:1 INPUT ISOLATED DC-DC CONVERTER Features  Efficiency Up to 90%  Fixed Switching Frequency  Regulated Outputs  Remote On/Off  Fully protected (OTP/OCP/OVP/UVLO)  3000Vac I/O Isolation  Operating Case Temperature -40 to +100℃  Half Brick Size Meet Industrial Standard 2.28×2.40x0.50  CB Test Certificate IEC62368-1  EN50155 Compliant with External Circuits  UL62368-1 2nd (Reinforce Insulation) Approval  Shock & Vibration EN50155 (EN61373) Compliant  Fire & Smoke EN45545-2 Compliant  5000m Operating Altitude OUTPUT CURRENT INPUT CURRENT % EFF. CAPACITOR FULL LOAD (1) (2) LOAD MAX. 3086 mA 90 90 16700uF 50 mA 3086 mA 90 89 13500uF 50 mA 3156 mA 88 88 8000µF 2121 mA 89 89 2200µF MODEL INPUT OUTPUT NUMBER VOLTAGE VOLTAGE MIN. MAX. NO LOAD CHB200W12-72S12 14-160 VDC 12 VDC 0 mA 16.7 A 50 mA CHB200W12-72S15 14-160 VDC 15 VDC 0 mA 13.5 A CHB200W12-72S24 14-160 VDC 24 VDC 0 mA 8.4 A CHB200W12-72S48 14-160 VDC 48 VDC 0 mA 4.2 A 50 mA NOTE: 1. Nominal Input Voltage 72 VDC 2. Measured at 110Vin 3. An External Input Capacitor 100uF for All Models are Recommended to Reduce Input Ripple Voltage 4. An External Electrolytic Capacitor at least 240uF connected between BUS and -Vin is necessary PART NUMBER Series CHB200W12- CHB200W12 Nominal Input Voltage II 72: 72 VDC Number of Outputs O S: Single Nominal Output Voltage XX Remote On/Off Logic L 12: 12VDC 15: 15VDC None: 24: 24VDC N: 48: 48VDC Mounting Inserts -Y (Option) None: Positive Negative -C: M3x0.5 Mounting Inserts Clear Mounting Inserts (3.2mm DIA.) Part Number Example: CHB200W12-72S12N-C: Half Brick, 200W, 12:1 14-160Vdc Input, Single 12Vdc Output, Negative Logic, Clear Mounting Insert www.cincon.com 1 REVISION: V10 CHB200W12 Series TECHNICAL SPECIFICATIONS (All specifications are typical at nominal input, full load at 25°C unless otherwise noted.) ABSOLUTE MAXIMUM RATINGS PARAMETER NOTES and CONDITIONS Device Min. Input Voltage Continuous All -0.3 Input Surge Voltage 100ms max. All Operating Case Temperature At the Center Part of Base Plate All -40 Max. Units 160 Vdc 180 Vdc 100 °C All -55 125 °C Device Min. Typ. Max. Units All 14 72 160 Vdc Turn-On Voltage Threshold All 12.5 13 13.5 Vdc Turn-Off Voltage Threshold All 10.5 11 11.5 Vdc Lockout Hysteresis Voltage All Storage Temperature Typ. INPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Operating Input Voltage Input Under Voltage Lockout Maximum Input Current Vin=16.5V, Full Load. No-Load Input Current Vin=72V, Io=0A Input Filter Pi filter. All Inrush Current (I t) As per ETS300 132-2. All Input Reflected Ripple Current P-P thru 12uH inductor, 5Hz to 20MHz. All 2 Vdc 2 All A 15 mA See Model Number Table 0.1 A2s mA 50 OUTPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Voltage Set Point Accuracy Vin=72V, Full Load, Tc=25°C Device Min. All -1.0 Typ. Max. Units +1.0 % Output Voltage Regulation Load Regulation Full Load to No Load All ±0.2 % Line Regulation Vin=High Line to Low Line, Full Load All ±0.2 % Temperature Coefficient Tc=-40°C to 100°C All ±0.02 %/°C 12Vo 200 15Vo 200 24Vo 240 48Vo 240 Output Voltage Ripple and Noise (5Hz to 20MHz bandwidth) Peak-to-Peak Full load, 10uF tantalum and 1.0uF ceramic capacitors (for Vo=48V: Full Load 10uF aluminum and 1uF ceramic capacitors). RMS. 12Vo 80 15Vo 60 24Vo 100 48Vo See Model Number Table Vin= 14 to 16.5V See Model Number Table,Full Load 10S Over Current Protection
CHB200W12-72S12 价格&库存
很抱歉,暂时无法提供与“CHB200W12-72S12”相匹配的价格&库存,您可以联系我们找货
CHB200W12-72S12
  • 1+1753.227271+219.08277
  • 5+1687.819005+210.90937
  • 10+1660.3597510+207.47807
  • 25+1624.6936925+203.02125
  • 50+1598.1911250+199.70950
库存:1
