EC7BW18-72S05-ECRT
EC7BW18-72S05-ECRT
    CINCON
    封闭式 直流转换器 1 输出 5V 4A 160V 输入
EC7BW18-72S05-ECRT 数据手册
EC7BW18 ECRT/EDRT SERIES 20 WATT 16:1 INPUT ISOLATED DC-DC CONVERTERS Features ⚫ Efficiency Up to 88% ⚫ Fixed Switching Frequency ⚫ Regulated Outputs ⚫ Negative Logic Remote On/Off ⚫ Low No Load Power Consumption ⚫ Fully protected (OTP/OCP/OVP/UVLO) ⚫ 3000Vac I/O Isolation ⚫ Operating Case Temperature -40 to +100℃ ⚫ UL62368-1 2nd (Reinforced Insulation) Approval for DC Modules ⚫ Compliant with EN50155/ EN50121-3-2/ EN45545-2 ⚫ Safety Meets IEC/EN/UL 62368-1 ⚫ Chassis Mount, Baseplate Cooled ⚫ Low Inrush Current ⚫ Input Reverse Polarity Protection ⚫ EN50155 Class S3/ Class C2 Criteria A Without External Capacitor ⚫ Output LED Indicator ⚫ 4.45”x2.33”x0.68” Size MODEL NUMBER INPUT OUTPUT OUTPUT CURRENT INPUT CURRENT % CAPACITOR VOLTAGE VOLTAGE MIN. EC7BW18-72S05-ZZZZW 10-160 VDC 5 VDC 0 mA 4000 mA 8 mA 330 mA 84 6800uF EC7BW18-72S12-ZZZZW 10-160 VDC 12 VDC 0 mA 1670 mA 10 mA 320 mA 87 3300uF MAX. NO LOAD FULL LOAD EFF. LOAD MAX. EC7BW18-72S15-ZZZZW 10-160 VDC 15 VDC 0 mA 1330 mA 10 mA 316 mA 88 2200μF EC7BW18-72D12-ZZZZW 10-160 VDC ±12 VDC 0 mA ±833 mA 10 mA 320 mA 87 820μF EC7BW18-72D15-ZZZZW 10-160 VDC ±15 VDC 0 mA ±667 mA 10 mA 316 mA 88 680μF EC7BW18-72D24-ZZZZW 10-160 VDC ±24 VDC 0 mA ±417 mA 10 mA 316 mA 88 330μF NOTE: 1. Nominal Input Voltage 72 VDC. 2. VR1 is Used for Output Voltage Adjustment (Single Output Only). 3. Refer to Application Note for Thermal Resistance and Derating Information. 4. TVS is Included for Input Surge Voltage Protection. 5. Fuse & Shunt Diode is Include Inside for Input Reverse Polarity Protection. 6. CN1 & CN2 connection: DINKLE 0137-1103 Series or Equivalent, Suitable Electric Wire: 26~16AWG (IEC 0.2~1.5mm2 ). 7. EC7BW18-72XYY-ZZZZW has De-rating by Input Voltage is Required See Power Derating Curve. 8. EDRT & EDRTP with Din Mount, the Clip is Suitable for TS-35 Din Rail. PART NUMBER Series EC7BW18- Nominal Input Voltage II Number of Outputs O S: Single EC7BW18 72: 72 VDC D: Dual Nominal Output Voltage XX 05: 5VDC 12: 15: 24: 12VDC 15VDC 24VDC Chassis Mount Type ECRT: EDRT: -ZZZZ Enclosed Chassis Mount + Railway Turnkey Enclosed Chassis Mount + Din Rail + Railway Turnkey Coating W None: P: Without Protective Coating Coming Soon Part Number Example: EC7BW18-72S12-EDRTP: Enclosed Chassis Mount + Din Rail, 20W, 18:1 10-160Vdc Input, Single 12Vdc Output, With Protective Coating www.cincon.com 1 REVISION: V10 EC7BW18-ECRT/EDRT Series TECHNICAL SPECIFICATIONS (All specifications are typical at nominal input, full load at 25°C unless otherwise noted.) ABSOLUTE MAXIMUM RATINGS PARAMETER NOTES and CONDITIONS Device Min. Input Voltage Continuous All -0.3 Input Surge Voltage 100ms max. All Operating Case Temperature At the Center Part of Case Plate All -40 All -40 Device Min. All Storage Temperature Typ. Max. Units 160 Vdc 200 Vdc 100 °C 105 °C Typ. Max. Units 10 72 160 Vdc 9.2 9.9 Vdc 8.7 9.1 Vdc INPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Operating Input Voltage Input Under Voltage Lockout Turn-On Voltage Threshold 70% Load All 8.5 Turn-Off Voltage Threshold 70% Load All 8.1 Lockout Hysteresis Voltage 70% Load All 0.5 Maximum Input Current Vin=14V, Full Load All 2.0 Maximum Input Inrush Current Vin=160V, Full Load All No-Load Input Current Vin=72V, Io=0A Vdc A 15 A mA See Model Number Table OUTPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Voltage Set Point Accuracy Vin=72V, Full Load, Tc=25°C Device Min. All -1.2 Typ. Max. Units +1.0 % Single ±1.5 % Dual ±1.0 % Output Voltage Regulation Load Regulation Full Load to No Load Line Regulation Vin=High Line to Low Line, Full Load Cross Regulation Load cross variation 25%/100% Temperature Coefficient Tc=-40°C to 100°C All ±0.2 % Dual ±5.0 % All ±0.02 %/°C All 100 mV All 40 mV Output Voltage Ripple and Noise (5Hz to 20MHz bandwidth) Peak-to-Peak RMS. Full load, 1uF ceramic capacitors See Model Number Table & Power Derating Curve Output Current Range Vin= 10 to 160V Over Current Protection Hiccup Mode. Auto Recovery. Short Circuit Protection External Load Capacitance All 180 Po≦max rated power, Io ≦ Io_max Zener Clamp % uF See Model Number Table -20 +15 72S12 72S15 Over Voltage Protection 150 Continuous, Auto Recovery. All Full load (resistive) 72S05 Output Voltage Trim Range 110 mA % See Power Derating Curve 5Vo 6.2 12Vo 15 15Vo 18 ±12Vo ±15 ±15Vo ±18 ±24Vo ±30 Vdc EFFICIENCY PARAMETER NOTES and CONDITIONS 100% Load Vin=72V www.cincon.com Device Min. Typ. See Model Number Table 2 Max. Units % REVISION: V10 EC7BW18-ECRT/EDRT Series DYNAMIC CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Typ. Max. Units Output Voltage Current Transient Error Band Recovery Time Turn-On Delay and Rise Time Turn-On Delay Time, From On/Off Control Turn-On Delay Time, From Input Output Voltage Rise Time 75% to 100% of Io_max step load change di/dt=0.1A/us (within 1% Vout nominal) Full load (Constant resistive load) All ±5 % All 250 us Von/off to 10%Vo_set, Remote On All 30 ms Vin_min to 10%Vo_set, Power Up All 30 ms 5Vo 10 ms Others 5 ms 10%Vo_set to 90%Vo_set ISOLATION CHARACTERISTICS PARAMETER NOTES and CONDITIONS Device Min. Typ. Max. Units Isolation Voltage (100% factory Hi-Pot tested @2sec.) 1 minute; Input to Output, All 3000 Vac 1 minute; Input to Case All 2000 Vac 1 minute; Output to Case All 500 Isolation Resistance Input to Output All Input to Output All 2400 Isolation Capacitance Input to Case All 2400 Output to Case All 1900 Vac MΩ 1000 pF FEATURE CHARACTERISTICS PARAMETER NOTES and CONDITIONS Switching Frequency Pulse wide modulation (PWM), Fixed Device Min. Typ. Max. Units All 180 200 220 KHz Von/off at Ion/off>0.3mA All 3.5 12 V Von/off at Ion/off=0.0uA, Pin open=On All 0 1.2 V Ion/off at Von/off=3.5-12V All 0.3 2.4 mA 5 mA On/Off Control, Remote On/Off logic, Refer to –Vin pin Logic High (Module Off) Logic Low (Module On) On/Off Current (for both remote on/off logic) Off Converter Input Current Over Temperature Shutdown Over Temperature Recovery Shutdown input idle current All 3 Temperature at the Center Part of Case Plate, Non-Latching All 106 °C All 92 °C GENERAL SPECIFICATIONS PARAMETER MTBF NOTES and CONDITIONS Io=100% of Io_max; MIL-HDBK - 217F_Notice 1, GB, 25°C Weight Case plate Material Aluminum Potting Material UL 94V-0 (DC Module) Device 72S05 462 481 72S15 527 72D12 518 72D15 549 72D24 523 -ECRT 129 -EDRT 144 -ECRTP 135 -EDRTP 150 EN50155 (EN61373) Compliant Humidity 95% RH max. Non Condensing Altitude 5000m Operating Altitude, 12000m Transport Altitude Thermal Shock MIL-STD-810F 3 Typ. 72S12 Shock/Vibration www.cincon.com Min. Max. Units K hours grams REVISION: V10 EC7BW18-ECRT/EDRT Series GENERAL SPECIFICATIONS Fire & Smoke EN45545-2 Compliant EMI EN50155 Compliant ESD EN61000-4-2 Level 3: Air ±8kV, Contact ±6Kv Perf. Criteria A Radiated immunity EN61000-4-3 Level 3: 80~1000MHz, 20V/m Perf. Criteria A Fast Transient EN61000-4-4 Level 3: On power input port, ±2kV Perf. Criteria A Surge EN61000-4-5 Level 4: Line to earth, ±4kV, Line to line, ±2kV Perf. Criteria A Conducted immunity EN61000-4-6 Level 3: 0.15~80MHz, 10V Perf. Criteria A Interruptions of Voltage Supply EN50155 Class S3: 20ms interruptions Perf. Criteria A Supply Change Over EN50155 Class C2: During a supply break of 30 ms, Perf. Criteria A Class A Application Note Link EC7BW18-72S EC(D)RT Series App Notes Packaging Information Link Packaging Information Immunity to Environmental Conditions. Phenomenon EN50155; 2017 Reference Clause(s) Reference Standard Low Temperature Start-up test 13.4.4 EN 60068-2-1 Dry Heat Test 13.4.5 EN 60068-2-2 Low Temperature Storage Test 13.4.6 EN 60068-2-1 Cyclic Damp Heat Test 13.4.7 EN 60068-2-30 Random Vibration Test 13.4.11 EN 61373 Simulated Long Life Test at Increased Random Vibration Levels 13.4.11 EN 61373 Shock Test 13.4.11 EN 61373 www.cincon.com 4 Test Conditions Class OT4 Temperature: -40℃ Duration: 2 hrs Class OT4 & ST2 Temperature: 70℃ Duration: 6 hrs Extended temperature: 85℃ Extended Duration: 10min Temperature: -40℃ Duration: 16 hrs Temperature: 25℃ - 55℃ Humidity: 90% RH Duration: 48 hrs Temperature: 25℃ +/- 10℃ Humidity: 50% +/-25% RH Frequency range: 5 ~ 150 Hz 2 Vertical: 1.01 𝑚⁄𝑠 2 Transverse: 0.450 𝑚⁄𝑠 2 Longitudinal: 0.700 𝑚⁄𝑠 Duration: 10 min / axis Temperature: 25℃ +/-10℃ Humidity: 50% +/-25% RH Frequency range: 5 ~ 150 Hz 2 Vertical: 5.72 𝑚⁄𝑠 2 Transverse: 2.55 m⁄s 2 Longitudinal: 3.96 𝑚⁄𝑠 Duration: 5 hrs / axis Temperature: 25℃ +/-10℃ Humidity: 50% +/-25% RH Frequency range: 5 ~ 150 Hz 2 +/-Vertical: 30 m⁄s 2 +/-Transverse: 30 𝑚⁄𝑠 2 +/-Longitudinal: 50 𝑚⁄𝑠 Duration: 30ms x18 (Each axis 3 shocks) Result Pass Pass Pass Pass Pass Pass Pass REVISION: V10 EC7BW18-ECRT/EDRT Series EN45545-2 Fire & Smoke Test Conditions. Item Standard Oxygen Index Test R22 Smoke Density Test Smoke Toxicity Test Oxygen Index Test R23 Smoke Density Test Smoke Toxicity Test R24 Oxygen Index Test R25 Glow - Wire Test R26 Vertical Flame Test Hazard Level EN 45545-2: 2013 EN ISO 4589-2: 2006 EN 45545-2: 2013 EN ISO 5659-2: 2013 EN 45545-2: 2013 NF X70-100: 2006 EN 45545-2: 2013 EN ISO 4589-2: 2006 EN 45545-2: 2013 EN ISO 5659-2: 2013 EN 45545-2: 2013 NF X70-100: 2006 EN45545-2: 2013 EN ISO 4589-2 EN 45545-2:2013 EN 60695-2-11:2001 EN 45545-2: 2013 EN 60695-11-10: 2013 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 HL1, HL2, HL3 CHARACTERISTIC CURVE Power Derating Curve EC7BW18-72XXX-ECRT/EDRT Derating Curve for Natural Convection (Vin=72V) 110 100 90 80 70 60 50 40 30 20 10 0 Output Power (%) Output Power (%) EC7BW18-72XXX-ECRT/EDRT Input Voltage Derating Curve 67 74 76 Other 72S05 72S12 72D12 -40 -30 -20 -10 0 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 10 20 30 40 50 60 70 80 90 100 Ambient Temperature (℃) Input Voltage (V) www.cincon.com 120 110 100 90 80 70 60 50 40 30 20 10 0 5 REVISION: V10 EC7BW18-ECRT/EDRT Series Performance Data EC7BW18-72S05-ECRT Eff Vs Io @25 Deg. C EC7BW18-72S05-ECRT Pd Vs Po @25 Deg. C 7 Power Dissipation (W) 90% Efficincy (%) 80% 70% 14V 24V 48V 72V 96V 110V 160V 60% 50% 40% 10% 30% 40% 50% 60% 70% 80% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% EC7BW18-72S12-ECRT Eff Vs Io @25 Deg. C EC7BW18-72S12-ECRT Pd Vs Po @25 Deg. C 6 Power Dissipation (W) Efficincy (%) 1 0% 70% 14V 24V 48V 72V 96V 110V 160V 60% 14V 24V 48V 72V 96V 110V 160V 5 4 3 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) EC7BW18-72S15-ECRT Eff Vs Io @25 Deg. C EC7BW18-72S15-ECRT Pd Vs Po @25 Deg. C 6 Power Dissipation (W) 100% 90% Efficincy (%) 2 Output Power (%) 50% 80% 70% 14V 24V 48V 72V 96V 110V 160V 60% 50% 14V 24V 48V 72V 96V 110V 160V 5 4 3 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) EC7BW18-72D12-ECRT Eff Vs Io @25 Deg. C EC7BW18-72D12-ECRT Pd Vs Po @25 Deg. C 6 Power Dissipation (W) 100% 90% Efficincy (%) 3 Current Load (%) 80% 80% 70% 14V 24V 48V 72V 96V 110V 160V 60% 50% 40% 10% 4 90% 100% 90% 40% 10% 5 0 20% 100% 40% 10% 14V 24V 48V 72V 96V 110V 160V 6 14V 24V 48V 72V 96V 110V 160V 5 4 3 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% Current Load (%) www.cincon.com 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Output Power (%) 6 REVISION: V10 EC7BW18-ECRT/EDRT EC7BW18-72D15-ECRT Eff Vs Io @25 Deg. C EC7BW18-72D15-ECRT Pd Vs Po @25 Deg. C 6 Power Dissipation (W) 100% Efficincy (%) 90% 80% 70% 14V 24V 48V 72V 96V 110V 160V 60% 50% 40% 10% 14V 24V 48V 72V 96V 110V 160V 5 4 3 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) EC7BW18-72D24-ECRT Eff Vs Io @25 Deg. C EC7BW18-72D24-ECRT Pd Vs Po @25 Deg. C 6 Power Dissipation (W) 100% 90% Efficincy (%) Series 80% 70% 14V 24V 48V 72V 96V 110V 160V 60% 50% 40% 10% 14V 24V 48V 72V 96V 110V 160V 5 4 3 2 1 0 20% 30% 40% 50% 60% 70% 80% 90% 100% 0% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) Output Power (%) MECHANICAL SPECIFICATION EC7BW18-72XXX-ECRT 2.33[59.2] 1 2 3 VR1 LED 0.85[21.6] 4 5 6 www.cincon.com 0.68[17.4] 4.45[113.0] 7 REVISION: V10 EC7BW18-ECRT/EDRT Series EC7BW18-72XXX-EDRT 2.33[59.2] 1 2 3 VR1 LED 1.27[32.2] 1.43[36.4] 4 5 6 All Dimensions in Inches[mm] Tolerance Inches: X.XX=±0.02 , X.XXX= ±0.010 Millimeters: X.X= ±0.5 , X.XX=±0.25 4.45[113.0] www.cincon.com PIN CONNECTION Single Dual Pin +V Input +V Input 1 -V Input -V Input 2 Remote Remote 3 -V Output NA 4 -V Output Common 5 +V Output +V Output 6 8 REVISION: V10
EC7BW18-72S05-ECRT 价格&库存
很抱歉,暂时无法提供与“EC7BW18-72S05-ECRT”相匹配的价格&库存,您可以联系我们找货
EC7BW18-72S05-ECRT
  • 1+1603.293261+208.07820
  • 5+1519.358505+197.18500
  • 25+1385.0977125+179.76040
