V10
ECLB75W SERIES
75 WATT 4:1 INPUT
DC-DC CONVERTERS
FEATURES
* 75W Isolated Output
* Efficiency to 92.5%
* Low No Load Power Consumption
* 2.05’’x1.2x0.4’’ Six-Sided Shield Metal Case
* Standard 2”X1” Pin Out Compatible
* 4:1 Input Range
* Regulated Outputs
* Fixed Switching Frequency
* Input Under Voltage Protection
* Over Current Protection
* Remote On/Off
* Continuous Short Circuit Protection
* No Tantalum Capacitor Inside
* Safety Meets IEC/EN/UL62368-1
* Full Load Operation Up to 54℃ with Heat-Sink
LBT127 (M-C655) Natural Convection
MODEL
NUMBER
INPUT
VOLTAGE
ECLB75W-24S05
9-36 VDC
ECLB75W-24S12
OUTPUT
VOLTAGE
OUTPUT CURRENT
INPUT CURRENT
% EFF.
FULL LOAD (3)
(2)
CAPACITOR
LOAD MAX.
MIN.
MAX.
NO LOAD
5 VDC
0 mA
15000 mA
10 mA
3415 mA
92
91.5
15000µF
9-36 VDC
12 VDC
0 mA
6250 mA
10 mA
3415 mA
92
91
6250µF
ECLB75W-24S15
9-36 VDC
15 VDC
0 mA
5000 mA
10 mA
3434 mA
92
90.5
5000µF
ECLB75W-24D12
9-36 VDC
±12 VDC
0 mA
±3120 mA
12 mA
3448 mA
91
90.5
3200µF
ECLB75W-24D15
9-36 VDC
±15 VDC
0 mA
±2500 mA
12 mA
3453 mA
91
91
2500µF
ECLB75W-24D24
9-36 VDC
±24 VDC
0 mA
±1560 mA
18 mA
90.5
1560µF
ECLB75W-48S05 18-75 VDC
5 VDC
0 mA
15000 mA
8 mA
3448 mA
1708 mA
91
92
91.5
15000µF
ECLB75W-48S12 18-75 VDC
12 VDC
0 mA
6250 mA
8 mA
1708 mA
92
91
6250µF
ECLB75W-48S15 18-75 VDC
15 VDC
0 mA
5000 mA
8 mA
1717 mA
92.5
91
5000µF
ECLB75W-48D12 18-75 VDC
±12 VDC
0 mA
±3120 mA
8 mA
1724 mA
91.5 90.5
3200µF
ECLB75W-48D15 18-75 VDC
±15 VDC
0 mA
±2500 mA
1717 mA
91.5
91
2500µF
ECLB75W-48D24 18-75 VDC
±24 VDC
0 mA
±1560 mA
8 mA
8 mA
1715 mA
92
91.5
1560uF
NOTE:
1. Nominal Input Voltage 24 or 48 VDC
2. Measured at Nominal Input Voltage
3. Measured at 12VDC for 24Vin, 24VDC for 48Vin
4. An External input Capacitor 100uF for 48Vin Models and 220uF for 24Vin Models are Recommended to
Reduce Input ripple Voltage.
1
V10
SPECIFICATIONS
All Specifications Typical At Nominal Line, Full Load, and 25℃ Unless Otherwise Noted
INPUT SPECIFICATIONS:
GENERAL SPECIFICATIONS:
Input Voltage Range ....……………..............…. 24VDC ................ 9 – 36VDC
48VDC ….…..…. 18 – 75VDC
Input Surge Voltage (100ms max.) ………….. 24VDC ……...... 50VDC max.
48VDC ….…... 100VDC max.
Under Voltage Lockout …………... 24Vin Power Up .……..……. 8.5VDC typ.
24Vin Power Down ….…….. 7.8VDC typ.
48Vin Power Up ….….....….16VDC typ.
48Vin Power Down ……......15VDC typ.
Input Filter (note6) .………………………………..……….……………. PI Type
Remote On/Off Control (note3&4)
Efficiency ................................................……..………............ See Table
Isolation Voltage ................ Input/Output ..........…..….….. 2250VDC min.
Input/Case, Output/Case ..... 1600VDC min.
9
Isolation Resistance …..................……….……….………. 10 ohm min.
Isolation Capacitance ……. Input/Output …..........……..…… 1500pF typ.
Input/Case, Output/Case ……... 1000pF typ.
Switching Frequency .......... Single …. 270KHz typ, Dual … 330KHz typ.
EMI/RFI ………………………………....…. Six-Sided Continuous Shield
Operating Ambient Temperature Range ...…..…...…….... -40℃ to +85℃
De-rating, Above 22℃ (note5) …..…. Linearly to Zero Power at +105℃
OUTPUT SPECIFICATIONS:
Case Temperature (note5) …….…………………………….. 105℃ max.
Voltage Accuracy ………………....………..……….......……...…… ±1.0% max.
Voltage Balance (Dual) …….…..………………………….…….…. ±1.0% max.
Transient Response: 75%~100% Step Load Change
Cooling ………………………………………………… Natural Convection
Storage Temperature Range ...……..........……....…....... -55℃ to +125℃
Temperature Coefficient ....................….………...…..……….. ±0.02%/℃ max.
Thermal Shutdown, Case Temp. .………….....................……. 110℃ typ.
Humidity ................................................. 95% RH max. Non-Condensing
MTBF … MIL-HDBK-217F, GB, 25℃ , Full Load
Vo=5V 904Khrs typ., Vo=12V 840Khrs typ., Vo=15V 995Khrs typ.
Vo=±12V 792Khrs typ., Vo=±15V 998Khrs typ., Vo=±24V 691Khrs typ.
Shock/Vibration ……………………..……………… Meet MIL-STD-810F
Dimensions ....................... 2.05x1.20x0.40 inches (52.0x30.5x10.2 mm)
Line Regulation (note1) .……..……. Single/Dual ......................…. ±0.2% max.
Load Regulation (note2) .……..…. Single/Dual ....................…. ±0.5% max.
Case Material ………………….… Aluminum with Non-Conductive Base
Weight ………………………………………………………………….. 39g
Cross Regulation (Dual Output) Load Cross Variation 10%/100% ... ±5% max.
NOTE :
Over Voltage Protection ………………….…….………… Zener or TVS Clamp
Current Limit ………………………………….…. 110% - 160% Nominal Output
Output Short Circuit Protection .............................. Continuous (Hiccup Mode)
External Trim Adj. Range …………………………………..………. +10%, -20%
Start Up Time ……………………………………………………………. 30ms typ.
1. Measured from high line to low line.
2. Measured from full load to min. load.
3. Logic compatibility … CMOS or open collector TTL, refer to –Vin.
Module on ……………...… >3.5VDC to 75VDC or open circuit
Module off ………………..……………….………. 0 to < 1.2VDC
4. Suffix "N" to the model number with negative logic remote on/off
Module on ………….…….……………………..…. 0 to < 1.2 VDC
Module off …………...…..….. >3.5VDC to 75VDC or open circuit
5. Maximum case temperature under any operating condition should
not be exceeded 105℃.
6. An external input capacitor 100uF for 48Vin models and 220uF for
24Vin models are recommended to reduce input ripple voltage.
Error Band ……..… ±5% Vout Nominal, Recovery Time ………..
很抱歉,暂时无法提供与“ECLB75W-24D15”相匹配的价格&库存,您可以联系我们找货
