TR220MA480-01E13 VI
TR220MA480-01E13 VI
    CINCON
    48V 220 W AC/DC 外部 台式(类 I) 适配器 软线 输入
TR220MA480-01E13 VI 数据手册
TR220M SERIES 220 WATT MEDICAL SWITCH ADAPTER Features  Universal Input Range 80~264Vac  High Efficiency up to 94%  Class I (TR220MA), Class II (TR220MB)  No Load Input Power Consumption < 150mW  Approval IEC/EN/UL 60601-1 2 MOPP  Approval IEC/EN 60601-1-11 (TR220MB)  Approval EN55011 and CISPR/FCC Class B  Approval IP22  Operating Altitude 5000m  Continuous Short Circuit Protection  Over Voltage Protection  Meets CoC Tier 2 and DOE Level VI MODEL OUTPUT OUTPUT NUMBER VOLTAGE CURRENT TR220MA120 TR220MA240 TR220MA360 TR220MA480 TR220MA560 TR220MB120 TR220MB240 TR220MB360 TR220MB480 TR220MB560 12 V 24 V 36 V 48 V 56 V 12 V 24 V 36 V 48 V 56 V 16.67 A 9.17 A 6.11 A 4.58 A 3.93 A 16.67A 9.17 A 6.11 A 4.58 A 3.93 A RIPPLE & VOLTAGE LINE LOAD %EFF. NOISE ACCURACY REGULATION REGULATION (Typ.) NOTE1 NOTE2 NOTE3 NOTE4 NOTE5 120mV 200mV 200mV 200mV 200mV 120mV 200mV 200mV 200mV 200mV ±2% ±2% ±2% ±2% ±2% ±2% ±2% ±2% ±2% ±2% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±1% ±4% ±3% ±2% ±2% ±2% ±4% ±3% ±2% ±2% ±2% 91% 93% 93% 94% 94% 91% 93% 93% 94% 94% Note: 1. Add a 0.1uF ceramic capacitor and a 10uF E.L. capacitor to output for ripple & noise measuring @20MHz BW. 2. Voltage accuracy is set at 60% full load. 3. Line regulation is measured from 100Vac to 240Vac with full load. 4. Load regulation measured from 60% to 100% full load and from 60% to 20% full load (60%±40% full load). 5. Typical efficiency at 230Vac and 75% full load at 25℃. PART NUMBER Series TR220M X Output Voltage DC Plug Type Cable Type Cable Length XXX -XX E XX 120:12V 220W Medical Adapter A:Class I B:Class II 240:24V 360:36V 471:950mm with Ferrite Core See Page 6 E:UL2464 with OVP 12:1220mm with Ferrite Core 480:48V 13:1800mm with DC Jack 560:56V See page 6 restrictions Part Number Example: TR220MA240-1538E12, 220W, Class I, 24Vdc Output, Din Power Plug Molded Type, Cable Length 1220mm TR220MB360-11E13, 220W, Class II, 36Vdc Output, DC Jack Type, Cable Length 1800mm www.cincon.com 1 REVISION: V10 TR220M Series TECHNICAL SPECIFICATIONS (All specifications are typical at nominal input, full load at 25℃ unless otherwise noted.) ABSOLUTE MAXIMUM RATINGS PARAMETER NOTES and CONDITIONS Input Voltage Operating Temperature See Derating Curve Storage Temperature Input/Output Isolation Voltage 1 minute Operating Altitude Device Min. Typ. Max. Units Vac All 80 264 All -30 70 ℃ All -40 85 ℃ All 4000 Vac All 5000 m Max. Units 240 Vac 63 Hz INPUT CHARACTERISTICS PARAMETER NOTES and CONDITIONS Operating Voltage Range Input Frequency Range Maximum Input Current Min. All 100 All 47 Typ. All 2.5 A Leakage Current (Earth) All 300 uA Leakage Current (Touch) All Under Voltage Protection All 50 All 0.92 Power Factor 100% Load, Vin=100Vac Device 230Vac/50Hz @ Full load 100 uA 60 65 V Units OUTPUT CHARACTERISTICS PARAMETER Output Voltage Set Point Operating Output Current Range Holdup Time NOTES and CONDITIONS Vin=115Vac and 230Vac, Io=60% Full load Tc=25℃ Vin=115Vac and 230Vac,Tc=25℃ Vin=115Vac Device Min. Typ. Max. TR220MA/B120 11.76 12 12.24 TR220MA/B240 23.52 24 24.48 TR220MA/B360 35.28 36 36.72 TR220MA/B480 47.04 48 48.96 TR220MA/B560 54.88 56 57.12 TR220MA/B120 0 16.67 TR220MA/B240 0 9.17 TR220MA/B360 0 6.11 TR220MA/B480 0 4.58 TR220MA/B560 0 3.93 All 20 22 Vdc A ms Output Voltage Regulation Load Regulation Line Regulation Over Voltage Protection Output Ripple and Noise www.cincon.com 60%±40% Full load change Vin=High line to low line TR220MA/B120 ±4 TR220MA/B240 ±3 TR220MA/B360 ±2 TR220MA/B480 ±2 TR220MA/B560 ±2 All Latch Off 1. Add a 0.1uF ceramic capacitor and a 10uF aluminum electrolytic capacitor to output 2. Oscilloscope is 20MHz band width 3. Ambient temperature=25℃ 2 ±1 TR220MA/B120 13.5 TR220MA/B240 30 TR220MA/B360 42 TR220MA/B480 56 TR220MA/B560 59.2 % % Vdc TR220MA/B120 120 TR220MA/B240 200 TR220MA/B360 200 TR220MA/B480 200 TR220MA/B560 200 mV REVISION: V10 TR220M PARAMETER Load Capacitance Efficiency NOTES and CONDITIONS 1. Vin=115Vac and 230Vac 2. Output is max. load 3. Ambient temperature=25℃ 1. Vin=230Vac 2. Output is 75% full load 3. Ambient temperature=25℃ Device Min. Typ. Series Max. TR220MA/B120 16500 TR220MA/B240 9270 TR220MA/B360 6160 TR220MA/B480 4540 TR220MA/B560 4070 TR220MA/B120 91% TR220MA/B240 93% TR220MA/B360 93% TR220MA/B480 94% TR220MA/B560 94% Units uF % ISOLATION CHARACTERISTICS PARAMETER NOTES and CONDITIONS Input to Output 1 minute (without dielectric breakdown) Input to Earth (Ground) Output to Earth (Ground) Isolation Resistance Device Min. Typ. Max. Units All 4400 Vac 1 minute (without dielectric breakdown) All 1800 Vac 1 minute (without dielectric breakdown) All 1800 Input to output All 100 Device Min. Vac MΩ FEATURE CHARACTERISTICS PARAMETER NOTES and CONDITIONS Switching Frequency All Typ. Max. 100 Units kHz GENERAL SPECIFICATIONS PARAMETER NOTES and CONDITIONS Device Min. MTBF Io=100%; Ta=25℃ per MIL-HDBK217F All 585 Life Time @ 75% Load, 40℃ All 26 Humidity Non-condensing MIL-STD-810F Table 516.5,TABLE 516.5-I 10ms, each axis 3 times(±X、 ±Y、±Z axis) MIL-STD-810F Table 514.5C-VIII, 15~2000Hz, X、Y、Z axis, 1 hour(each axis),. total 3 hours. All Shock Vibration Typ. Max. Units 93 k hours k hours % RH All 75 g All 4 g Weight All Dimension All 950 7.087x2.953x1.752 Inches (180x75x44.5mm) grams Ed 3.1 EMC Emission Class I, Class II, IEC60601-1, EN60601-1, ANSI/AAMI ES60601-1 IEC/EN 60601-1-11 for TR220MB (Home Health Care) EN55011:2016+A1:2017, EN61000-3-2:2014, EN6100-3-3:2013, FCC CFR47 Part 15 Conducted Disturbance Radiated Disturbance EN55011:2016+A1:2017, FCC CFR47 Part 15 EN55011:2016+A1:2017, FCC CFR47 Part 15 Class B Class B Harmonic Current Emissions EN 61000-3-2:2014 Class A Voltage Fluctuations & Flicker EN 61000-3-3:2013 Criterion A EMC Immunity EN60601-1-2:2015, IEC61000-4-2, 3, 4, 5, 6, 8, 11 Electrostatic Discharge (ESD) Radio-Frequency, Continuous Radiated Disturbance Electrical Fast Transient (EFT) IEC 61000-4-2:2008 Air Discharge: ±15kV Contact Discharge: ±8kV Criterion A IEC 61000-4-3:2020 Criterion A IEC61000-4-4:2012, ±1kV, ±2kV Criterion A Surge Conducted Disturbances, Induced by RF Fields Power Frequency Magnetic Field IEC61000-4-5:2014+A1:2017, L-N: ±0.5kV, ±1kV, ±2kV L-E (Ground): ±0.5kV, ±1kV, ±2kV Criterion A IEC 61000-4-6:2013+COR1:2015 Criterion A IEC 61000-4-8:2009 Criterion A Voltage Dips IEC 61000-4-11:2004+A1:2017, Dips:30% reduction, Dips: >95% Reduction, Criteria A Criterion A Voltage Interruptions IEC 61000-4-11:2004+A1:2017, >95% Reduction Criterion B Safety Application Note Link www.cincon.com Ed 4.0 TR220M Series App Notes 3 REVISION: V10 TR220M Series CHARACTERISTIC CURVE Power Derating Curve TR220M Derating Curve TR220M Input Voltage Derating Curve 100% 100% Rated Load (%) 120% Rated Load (%) 120% 80% 60% 40% 20 LFM (Natural Convection) 20% 0% 80% 60% 40% 20 LFM (Natural Convection) 20% 0% -30 -20 -10 0 10 20 30 40 50 60 70 80 100 120 Ambient Temperature (℃) 140 160 180 200 220 240 260 Input Voltage (Vac) Performance Data TR220M240 (Eff Vs Io) 95% 95% 90% 90% Efficincy (%) Efficincy (%) TR220M120 (Eff Vs Io) 85% 80% 75% 115V 70% 230V 80% 75% 115V 70% 230V 65% 60% 10% 85% 65% 20% 30% 40% 50% 60% 70% 80% 60% 10% 90% 100% 20% 30% Current Load (%) 50% 60% 70% 80% TR220M480 (Eff Vs Io) 95% 90% 90% Efficincy (%) 95% 85% 80% 75% 115V 70% 85% 80% 75% 115V 70% 230V 230V 65% 60% 10% 90% 100% Current Load (%) TR220M360 (Eff Vs Io) Efficincy (%) 40% 65% 20% 30% 40% 50% 60% 70% 80% 60% 10% 90% 100% Current Load (%) 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) TR220M560 (Eff Vs Io) 95% Efficincy (%) 90% 85% 80% 75% 115V 70% 230V 65% 60% 10% 20% 30% 40% 50% 60% 70% 80% 90% 100% Current Load (%) www.cincon.com 4 REVISION: V10 TR220M Series MECHANICAL SPECIFICATION All Dimensions are in inches[mm] Tolerance:Inches:X.XXX±0.02 Millimeters:X.XX±0.5 UNIT:inches[mm] Din Power Plug 7.087[180.00] 37.402[950.00]±1.969[50.00] LED IEC320/C14 2.953[75.00] P1 P3 P2 P4 Pin1,3:- Pin2,4:+ Shell:NC 4Pin Power Plug Assembly Type 16AWG/950mm 1.713[43.50] IEC320/C8 DC Jack 7.087[180.00] 70.866[1800.00]±1.969[50.00] LED 2.953[75.00] IEC320/C14 DC Plug type: V+ ─●)─ VDC Plug :Straight(ψ5.5/ψ2.5) L12mm 16AWG/1800mm 1.713[43.50] IEC320/C8 * For Output Voltage 12Vdc and 24V model, it must select Din Power Plug Molded Type or equivalent * For Output Voltage 36Vdc to 56Vdc models, it’s able to select Din Power Plug Molded Type, DC Jack or equivalent. www.cincon.com 5 REVISION: V10 TR220M Series Cable Type Cable Length Cable AWG UL2464 1800mm with Ferrite Core Cable Type Cable Length STANDARD OUTPUT DC PLUG DC Plug Type A B C OD (mm) ID (mm) L (mm) 11E13 Φ5.5 Φ2.1 12 12E13 Φ5.5 Φ2.5 12 23E13 Φ5.5 Φ2.1 9.5 26E13 Φ5.5 Φ2.5 9.5 01E13 Φ5.5 Φ2.1 12 02E13 Φ5.5 Φ2.5 12 21E13 Φ5.5 Φ2.5 9.5 24E13 Φ5.5 Φ2.1 9.5 Cable NumberXXXXX 16AWG for 36V,48V,56V Pin Assignment Din Plug Type KYCON KPPX-4P equivalent with Lock (Din Power Plug Assembly Type) Cable Number XXXXX 1446E12 1446E471 KYCON KPPX-4P equivalent without Lock (Din Power Plug Molded Type) 1538E12 1538E471 PIN No. Polarity P1 - P2 + P3 - P4 + Shell No Connection P1 + P2 + P3 - P4 - Shell No Connection Cable AWG 1200mm with Ferrite Core 16AWG for 24V UL2464 950mm with Ferrite Core 16AWG for 12V 1200mm with Ferrite Core 16AWG for 24V UL2464 950mm with Ferrite Core 16AWG for 12V ※Other DC Plug Type please refer to the link: https://www.cincon.com/productdownload/TR220M-cable-DC-plug.pdf 6 REVISION: V10
TR220MA480-01E13 VI 价格&库存
很抱歉,暂时无法提供与“TR220MA480-01E13 VI”相匹配的价格&库存,您可以联系我们找货
TR220MA480-01E13 VI
  • 1+950.862521+118.81950
  • 10+897.5093210+112.15250
  • 25+848.9488725+106.08440
  • 50+810.1547650+101.23670
  • 100+756.80156100+94.56970
库存:9
