FCR20642
FCR20642
    CLIFF
    4(3 电源 + PE) 针位圆形连接器 插座,母型插口 焊接
FCR20642 数据手册
CLIFF CLIFFCON® CONNECTORS Connectors designed for high power applications, where a high quality, reliable, locking, touch-proof connector system is required. Features § Touchproof contacts § Polarized § Easy Locking / Unlocking § Reliable wiping contacts / Gold plated § Faston and screw / solder connections § Built in cable clamp (6mm - 15mm cable) § Chassis connector is panel airtight. Fits std XLR cutout § Tough and durable FCR2062 4 Pole Plug FCR2064 4 Pole Socket Solder Tags FCR20642 4 Pole Socket PC Tags CLIFF CLIFFCON® CONNECTORS FCR2063 4 Pole 90° Plug Specification 1) Safety leading ground pin - makes first, breaks last. 2) Rated Voltage - 240VAC 3) Rated Current: 4 pin 20A RMS @ 80°C, 30A RMS @ 20°C (5% duty cycle) 4) Inrush Current: >30A / 20mS 5) Contact Resistance: 20MΩ @ 4000V 7) Operating Temp: -20°C to +80°C 8) Max wire size: 6mm2 / 10AWG solid, 4mm2 / 12AWG stranded 9) Gold plated touchproof contacts. © CLIFF 09/2021 iss 3 For further information, contact sales@cliffuk.co.uk Cliff Electronic Components Limited, 76 Holmethorpe Avenue, Holmethorpe Ind. Estate, Redhill, Surrey RH1 2PF U.K. Tel: +44 (0)1737 771375 Fax: +44 (0)1737 766012 üRoHS www.cliffuk.co.uk
FCR20642 价格&库存
很抱歉,暂时无法提供与“FCR20642”相匹配的价格&库存,您可以联系我们找货
