FCR2062
FCR2062
    CLIFF
    4(3 电源 + PE) 针位圆形连接器 插头,公引脚 螺钉
FCR2062 数据手册
CLIFF CLIFFCON® CONNECTORS Connectors designed for high power applications, where a high quality, reliable, locking, touch-proof connector system is required. Features § Touchproof contacts § Polarized § Easy Locking / Unlocking § Reliable wiping contacts / Gold plated § Faston and screw / solder connections § Built in cable clamp (6mm - 15mm cable) § Chassis connector is panel airtight. Fits std XLR cutout § Tough and durable FCR2062 4 Pole Plug FCR2064 4 Pole Socket Solder Tags FCR20642 4 Pole Socket PC Tags CLIFF CLIFFCON® CONNECTORS FCR2063 4 Pole 90° Plug Specification 1) Safety leading ground pin - makes first, breaks last. 2) Rated Voltage - 240VAC 3) Rated Current: 4 pin 20A RMS @ 80°C, 30A RMS @ 20°C (5% duty cycle) 4) Inrush Current: >30A / 20mS 5) Contact Resistance: 20MΩ @ 4000V 7) Operating Temp: -20°C to +80°C 8) Max wire size: 6mm2 / 10AWG solid, 4mm2 / 12AWG stranded 9) Gold plated touchproof contacts. © CLIFF 09/2021 iss 3 For further information, contact sales@cliffuk.co.uk Cliff Electronic Components Limited, 76 Holmethorpe Avenue, Holmethorpe Ind. Estate, Redhill, Surrey RH1 2PF U.K. Tel: +44 (0)1737 771375 Fax: +44 (0)1737 766012 üRoHS www.cliffuk.co.uk
FCR2062 价格&库存
很抱歉,暂时无法提供与“FCR2062”相匹配的价格&库存,您可以联系我们找货
FCR2062
  • 1+143.483491+18.64605
  • 10+121.9269210+15.84472
  • 25+114.2940525+14.85281
  • 50+108.8364050+14.14357
  • 100+103.64363100+13.46876
  • 250+97.16007250+12.62620
  • 500+92.52738500+12.02417
库存:30
