FCR20663
FCR20663
    CLIFF
    4(3 电源 + PE) 针位圆形连接器 插头,公引脚 螺钉
FCR20663 数据手册
CLIFF CLIFFCON® CONNECTORS Our Cliffcon® 4 pole connectors are intended for any application where a reliable locking touch proof connector system is required. Incorporating a tough, durable construction with gold plated touch proof contacts, easy locking / unlocking mechanism and integral cable clamp, Cliffcon® is the ideal connector for many different applications. Sockets are available for chassis and PCB mounting. Specific, non-compatable versions for low (LV) and high (HV) voltage applications. FCR2068 - 4PC/S/LV FCR20681 - 4PC/S/PC/LV FCR2069 - 4PC/S/HV FCR20691 - 4PC/S/PC/HV FCR2066 - 4PC/P/LV FCR2067 - 4PC/P/HV FCR20663 - 4PC/P90/LV FCR20673 - 4PC/P90/HV Significant Features - Safety leading ground pin - makes first, breaks last to prevent damage from arcing if disconnected under load - Combination Faston quick disconnect and screw connections with clearly marked pin identification inside the line connectors. - Colour coded system - Blue for 120VAC, Red for 250VAC with different mechanical keying to avoid the possibility of intermating. - Integral cable clamp for 6mm to 15mm diameter cable. © CLIFF 08/2021 ISS.2 For further information, contact sales@cliffuk.co.uk Cliff Electronic Components Limited, 76 Holmethorpe Avenue, Holmethorpe Ind. Estate, Redhill, Surrey RH1 2PF U.K. Tel: +44 (0)1737 771375 Fax: +44 (0)1737 766012 üRoHS www.cliffuk.co.uk DIMENSIONS Specification 1) Safety leading ground pin - makes first, breaks last. 2) Rated Voltage - Blue (LV) 120V, Red (HV) 250V AC max * 3) Rated Current: 4 pin 20A RMS @ 80°C, 30A RMS @ 20°C (5% duty cycle) 4) Inrush Current: >30A / 20mS 5) Contact Resistance: 20MΩ @ 4000V 7) Operating Temp: -20°C to +80°C 8) Max wire size: 6mm2 / 10AWG solid, 4mm2 / 12AWG stranded * Connectors identical electrically, only the designation is LV and HV
FCR20663 价格&库存
很抱歉,暂时无法提供与“FCR20663”相匹配的价格&库存,您可以联系我们找货
FCR20663
  • 1+164.237961+21.34315
  • 10+139.5911010+18.14022
  • 25+130.8465625+17.00385
  • 50+124.6006550+16.19218
  • 100+118.65653100+15.41972
  • 300+109.81324300+14.27051
  • 500+105.93084500+13.76599
库存:73
