CLIFF
CLIFFCON® CONNECTORS
Our Cliffcon® 4 pole connectors are intended for any application where a reliable locking touch
proof connector system is required. Incorporating a tough, durable construction with gold plated
touch proof contacts, easy locking / unlocking mechanism and integral cable clamp, Cliffcon® is the
ideal connector for many different applications. Sockets are available for chassis and PCB
mounting. Specific, non-compatable versions for low (LV) and high (HV) voltage applications.
FCR2068 - 4PC/S/LV
FCR20681 - 4PC/S/PC/LV
FCR2069 - 4PC/S/HV
FCR20691 - 4PC/S/PC/HV
FCR2066 - 4PC/P/LV
FCR2067 - 4PC/P/HV
FCR20663 - 4PC/P90/LV
FCR20673 - 4PC/P90/HV
Significant Features
- Safety leading ground pin - makes first, breaks last to prevent damage from
arcing if disconnected under load
- Combination Faston quick disconnect and screw connections with clearly
marked pin identification inside the line connectors.
- Colour coded system - Blue for 120VAC, Red for 250VAC with different
mechanical keying to avoid the possibility of intermating.
- Integral cable clamp for 6mm to 15mm diameter cable.
© CLIFF 08/2021 ISS.2
For further information, contact sales@cliffuk.co.uk
Cliff Electronic Components Limited,
76 Holmethorpe Avenue, Holmethorpe Ind. Estate,
Redhill, Surrey RH1 2PF U.K.
Tel: +44 (0)1737 771375 Fax: +44 (0)1737 766012
üRoHS
www.cliffuk.co.uk
DIMENSIONS
Specification
1) Safety leading ground pin - makes first, breaks last.
2) Rated Voltage - Blue (LV) 120V, Red (HV) 250V AC max *
3) Rated Current: 4 pin 20A RMS @ 80°C, 30A RMS @ 20°C (5% duty cycle)
4) Inrush Current: >30A / 20mS
5) Contact Resistance: 20MΩ @ 4000V
7) Operating Temp: -20°C to +80°C
8) Max wire size: 6mm2 / 10AWG solid, 4mm2 / 12AWG stranded
* Connectors identical electrically, only the designation is LV and HV
很抱歉,暂时无法提供与“FCR20673”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+160.631721+20.87451
- 10+136.4944110+17.73780
- 25+127.9471025+16.62706
- 50+121.8401250+15.83344
- 100+116.02717100+15.07803
- 300+107.38089300+13.95442
- 500+103.58397500+13.46101
