CP30218M3
CP30218M3
    CLIFF
    耦合器 光纤连接器 ST 插座 至 ST 插座 面板安装,法兰(2 孔)
CP30218M3 数据手册
CLIFF ISS. AMEND DATE 1 2 ISSUED ST REVERSED 11/05/18 27/09/22 19.0 HOLES TO SUIT SCREW USED Ø24 +0.2 0 24.0 12.8 Material: 1. Insert: ABS UL94 HB 2. Frame: Nickel plated zinc diecast 3. ST Contacts: Nickel Plated 5.1 14.0 2.8 2.3 n24 31 24 RoHS ü COMPLIANT TOLERANCE 19 2 HOLES: Ø3.5mm CSK 82° x Ø5.85 26 NO DEC. PLACE ± 1 DEC. PLACE ± 2 DEC. PLACE ± HOLE Ø ± ANGLES ± M3 VERSION HAS M3 THREAD HOLES. UNLESS OTHERWISE STATED Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk THE CONTENTS OF THIS DOCUMENT MUST NOT BE COPIED OR DISCLOSED TO A 3rd PARTY WITHOUT WRITTEN PERMISSION OF CLIFF UK. © 2018 DIMENSIONS IN MILLIMETERS UNLESS OTHERWISE STATED. WORK TO DIMENSIONS. REMOVE ALL BURRS. IF IN DOUBT ASK. FINISH: See Notes See Notes DRAWN: T.J.O. MATERIAL: TITLE: APPROVED: D.P.J. 3rd ANGLE PROJECTION: DO NOT SCALE METAL FEED THROUGH ST FIBRE DRWG. No. CP30218M FORM: A4DRWGH
CP30218M3 价格&库存
很抱歉,暂时无法提供与“CP30218M3”相匹配的价格&库存,您可以联系我们找货
CP30218M3
    • 1+46.05120
    • 200+18.38160
    • 500+17.76600
    • 1000+17.46360
    CP30218M3
    • 1+79.988831+10.35372
    • 10+67.9541310+8.79596
    • 25+63.6961925+8.24481
    • 50+60.6522050+7.85080
    • 100+57.75801100+7.47618
    • 250+54.14285250+7.00823
    • 500+51.56061500+6.67399
    • 1000+49.102341000+6.35579
    库存:27
