CP30225SM
CP30225SM
    CLIFF
    模块 耦合器 连接器 插孔,8p8c(RJ45) 至 插孔,8p8c(RJ45) Cat6a 屏蔽
CP30225SM 数据手册
CLIFF PANEL CUTOUT MAXIMUM PANEL THICKNESS 3mm ISS. AMEND DATE 1 2 3 ISSUED ADD M3 VARIANT ADD MIN MAX TEMP 11/04/18 16/07/18 30/06/20 19.0 HOLES TO SUIT SCREW USED Ø24 +0.2 0 14.5 Material: 1. RJ45 In-Line Coupler: PC/ABS, UL 94V-0, Black colour 2. RJ45 In-Line Coupler Contact: Phosphor Bronze, 3-50 micro inches gold plating over nickel plate. 3. PCB: FR4, UL 94V-0 4. Frame: Nickel plated zinc diecast 24.0 28 5 2.8 Performance: 1. T568A & T568B wiring. 2. Meet ISO/IEC 11801 and EN50173 4. Meet ANSI/TIA/EIA 568B.2 5. Operating Temperatures: Min -10°C Max +70°C 2.3 n24 31 16 24 RoHS ü COMPLIANT TOLERANCE 19 2 HOLES: Ø3.5mm CSK 82° x Ø5.85 26 NO DEC. PLACE ± 1 DEC. PLACE ± 2 DEC. PLACE ± HOLE Ø ± ANGLES ± M3 VERSION HAS M3 THREAD HOLES. UNLESS OTHERWISE STATED Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk THE CONTENTS OF THIS DOCUMENT MUST NOT BE COPIED OR DISCLOSED TO A 3rd PARTY WITHOUT WRITTEN PERMISSION OF CLIFF UK. © 2018 DIMENSIONS IN MILLIMETERS UNLESS OTHERWISE STATED. WORK TO DIMENSIONS. REMOVE ALL BURRS. IF IN DOUBT ASK. FINISH: See Notes See Notes DRAWN: T.J.O. MATERIAL: TITLE: APPROVED: D.P.J. 3rd ANGLE PROJECTION: DO NOT SCALE FT METAL FTP CAT6A RJ45 SHIELDED DRWG. No. CP30225SM FORM: A4DRWGH
CP30225SM 价格&库存
很抱歉,暂时无法提供与“CP30225SM”相匹配的价格&库存,您可以联系我们找货
CP30225SM
  • 1+149.58126
  • 5+131.74602
  • 10+119.00143
  • 50+105.59805
