CLIFF
17.0
ISS.
AMEND
DATE
1
ISSUED
15/07/22
35.3
2.8
2.3
31
18.8
n24
24
Ø2.50
19
2x FIXING HOLE VARIANTS:
Ø3.5mm CSK 82° x Ø5.85
'X' VERSION HAS Ø2.5 PLAIN HOLES.
26
19.0
Material:
1.
RJ45 In-Line Coupler: ABS UL94-V2
2.
RJ45 In-Line Coupler Contact:
Phosphor Bronze, gold plating.
3.
PCB: FR4
4.
Frame: Polyamide UL94-V2
23.3
Performance:
1.
T568A & T568B wiring.
2.
Meet ISO/IEC 11801 and EN50173
3.
Meet ANSI/TIA/EIA 568B.2
4.
Rating 125VAC RMS 1.5A
5.
Operating Temperatures: Min -10°C Max +60°C
Cliff Electronic Components Ltd.
76 Holmethorpe Avenue, Holmethorpe Industrial Estate,
Redhill, Surrey, RH1 2PF, England, UK
Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk
THE CONTENTS OF THIS DOCUMENT MUST NOT BE COPIED OR DISCLOSED
TO A 3rd PARTY WITHOUT WRITTEN PERMISSION OF CLIFF UK.
© 2022
PANEL CUTOUT
MAXIMUM PANEL
THICKNESS 3mm
HOLES TO SUIT
'X' VERSION
Ø2.5 PLAIN HOLES
SCREW USED
Ø24 +0.2
FINISH:
See Notes
See Notes
DRAWN:
T.J.O.
TOLERANCE
24.0
NO DEC. PLACE ±
1 DEC. PLACE ±
2 DEC. PLACE ±
HOLE Ø ±
ANGLES ±
UNLESS
OTHERWISE STATED
TITLE:
APPROVED: D.P,J.
ü
COMPLIANT
DIMENSIONS IN MILLIMETERS UNLESS OTHERWISE STATED. WORK TO DIMENSIONS. REMOVE ALL BURRS. IF IN DOUBT ASK.
MATERIAL:
RoHS
3rd ANGLE PROJECTION:
DO NOT SCALE
RAFT CAT5e RJ45-RJ45
DRWG. No.
CP30251
FORM: A4DRWGH
很抱歉,暂时无法提供与“CP30251”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+87.11599
- 50+71.11339
- 500+65.60351
