CP30706NM
CP30706NM
    CLIFF
    适配器连接器 USB-B(USB TYPE-B),插座 至 USB-A(USB TYPE-A),插座 面板安装,法兰
CP30706NM 数据手册
CLIFF DUALSLIM USB3.0 B-A METAL FRAME FEEDTHROUGH CONNECTOR Can be front or rear mounted in the panel VARIANTS Part No. CP30706NM DUALSLIM USB3.0 B-A Nickel frame, CSK holes CP30706NMB DUALSLIM USB3.0 B-A Black metal frame, CSK holes CP30706NM3 DUALSLIM USB3.0 B-A Nickel frame, M3 holes CP30706NMB3 DUALSLIM USB3.0 B-A Black metal frame, M3 holes CP30706NM440 DUALSLIM USB3.0 B-A Nickel frame, #4-40 holes CP30706NMB440 DUALSLIM USB3.0 B-A Black metal frame, #4-40 holes CP30706NMX1 DUALSLIM USB3.0 B-A Nickel frame, Ø3.2 PLAIN holes CP30706NMBX1 DUALSLIM USB3.0 B-A Black metal frame, Ø3.2 PLAIN holes Feedthrough Features Material: — Fits standard rectangular cutout. 1. Insert: ABS UL94 HB — Front or rear mounting through the panel. 2. Frame: Diecast, Nickel or Black plated — Various hole mounting options. 3. Shell: Nickel plated steel — No soldering or punch termination. Use standard cable for 4. Contacts: Gold Plated each connector style. Notes: — Low rear profile. 1. Voltage rating: 30V ac 2. Current rating: 1.8 A max General: 3. Contact resistance: 50mΩ max Please note: Functionality is affected by cable quality, length and 4. Insulation resistance: 20MΩ min cable wiring configuration. 5. Dielectric withstanding voltage: 500V AC 6. Operating Temperature: -20°C to 50°C © CLIFF 02/2021 ISS.1 For further information, contact sales@cliffuk.co.uk Cliff Electronic Components Limited, 76 Holmethorpe Avenue, Holmethorpe Ind. Estate, Redhill, Surrey RH1 2PF U.K. Tel: +44 (0)1737 771375 Fax: +44 (0)1737 766012 üRoHS www.cliffuk.co.uk
CP30706NM 价格&库存
很抱歉,暂时无法提供与“CP30706NM”相匹配的价格&库存,您可以联系我们找货
CP30706NM
    • 1+90.39600
    • 200+36.07200
    • 500+34.86240
    • 1000+34.26840
    CP30706NM
    • 1+170.528731+22.16360
    • 10+144.9094210+18.83386
    • 25+135.8298425+17.65379
    • 50+129.3494350+16.81153
    • 100+123.17754100+16.00937
    • 250+115.47205250+15.00789
    • 500+109.96804500+14.29253
    库存:17
