CP30708NX1
CP30708NX1
    CLIFF
    适配器连接器 USB-A(USB TYPE-A),插座 至 USB-A(USB TYPE-A),插座 面板安装,法兰
CP30708NX1 数据手册
CLIFF DUALSLIM USB2.0 A-A FEEDTHROUGH CONNECTOR Can be front or rear mounted in the panel VARIANTS Part No. CP30708N CP30708NX CP30708NX1 DUALSLIM USB2.0 A-A Black plastic frame, CSK holes DUALSLIM USB2.0 A-A Black plastic frame, Ø2.5 PLAIN holes DUALSLIM USB2.0 A-A Black plastic frame, Ø3.2 PLAIN holes Feedthrough Features — Fits standard rectangular cutout. — Front or rear mounting through the panel. — Various hole mounting options. — No soldering or punch termination. Use standard cable for each connector style. — Low rear profile. General: Please note: Functionality is affected by cable quality, length and cable wiring configuration. © CLIFF 11/2020 ISS.1 Material: 1. Insert: ABS UL94 HB 2. Plastic Frame: Polyamide UL94 V-2 3. Inner Overmouldings: PE + PVC 4. Shell: Nickel plated steel 5. Contacts: Gold Plated Notes: 1. Voltage rating: 30V ac 2. Current rating: 1.5 A max 3. Contact resistance: 50mΩ max 4. Insulation resistance: 20MΩ min 5. Dielectric withstanding voltage: 500V AC 6. Operating Temperature: -20°C to 50°C For further information, contact sales@cliffuk.co.uk Cliff Electronic Components Limited, 76 Holmethorpe Avenue, Holmethorpe Ind. Estate, Redhill, Surrey RH1 2PF U.K. Tel: +44 (0)1737 771375 Fax: +44 (0)1737 766012 üRoHS www.cliffuk.co.uk
CP30708NX1 价格&库存
很抱歉,暂时无法提供与“CP30708NX1”相匹配的价格&库存,您可以联系我们找货
CP30708NX1
  • 1+74.774821+9.69224
  • 10+63.5623310+8.23889
  • 25+59.5830025+7.72309
  • 50+56.7364250+7.35412
  • 100+54.02723100+7.00296
  • 250+50.64627250+6.56472
  • 500+48.23045500+6.25159
  • 1000+45.930711000+5.95350
库存:127
CP30708NX1
    • 1+38.13480
    • 200+15.21720
    • 500+14.70960
    • 1000+14.46120
