CP30711MB3
CP30711MB3
    CLIFF
    DUALSLIM BLACK MTL USBC FM M3
CP30711MB3 数据手册
CLIFF DUALSLIM USB-C Female-Male METAL FRAME FEEDTHROUGH CONNECTOR Can be front or rear mounted in the panel VARIANTS Part No. CP30711M DUALSLIM USB-C F-M Nickel frame, CSK holes CP30711MB DUALSLIM USB-C F-M Black metal frame, CSK holes CP30711M3 DUALSLIM USB-C F-M Nickel frame, M3 holes CP30711MB3 DUALSLIM USB-C F-M Black metal frame, M3 holes CP30711M440 DUALSLIM USB-C F-M Nickel frame, #4-40 holes CP30711MB440 DUALSLIM USB-C F-M Black metal frame, #4-40 holes CP30711MX1 DUALSLIM USB-C F-M Nickel frame, Ø3.2 PLAIN holes CP30711MBX1 DUALSLIM USB-C F-M Black metal frame, Ø3.2 PLAIN holes Feedthrough Features Material: — Fits standard rectangular cutout. 1. Insert: ABS - UL94 HB — Front or rear mounting through the panel. 2. Frame: Diecast, Nickel or Black plated — Various hole mounting options. — No soldering or punch termination. Use standard cable for USB-C Specification: each connector style. Maximum Rated Current - 3A — Low rear profile. Maximum Working Voltage - 30V Withstanding Voltage - 100V for 1 minute. General: Contact Resistance - 40 Milli-ohms Max. Please note: Functionality is affected by cable quality, length and Insulation Resistance - 100 Mega-ohms Min. cable wiring configuration. Insulator Flammability Rating - UL-94V0 Insertion Life - 10,000 Cycles. © CLIFF 02/2021 ISS.1 For further information, contact sales@cliffuk.co.uk Cliff Electronic Components Limited, 76 Holmethorpe Avenue, Holmethorpe Ind. Estate, Redhill, Surrey RH1 2PF U.K. Tel: +44 (0)1737 771375 Fax: +44 (0)1737 766012 üRoHS www.cliffuk.co.uk
CP30711MB3 价格&库存
很抱歉,暂时无法提供与“CP30711MB3”相匹配的价格&库存,您可以联系我们找货
CP30711MB3
    • 1+122.02920
    • 200+48.69720
    • 500+47.06640
    • 1000+46.26720
