CP30722M
CP30722M
    CLIFF
    模块 耦合器 连接器 插孔,8p8c(RJ45) 至 插孔,8p8c(RJ45) Cat6 无屏蔽
CP30722M 数据手册
CLIFF DUALSLIM CAT.6 RJ45 METAL FRAME FEEDTHROUGH CONNECTOR Can be front or rear mounted in the panel VARIANTS Part No. CP30722M DUALSLIM Cat.6 RJ45 Nickel frame, CSK holes CP30722MB DUALSLIM Cat.6 RJ45 Black metal frame, CSK holes CP30722M3 DUALSLIM Cat.6 RJ45 Nickel frame, M3 holes CP30722MB3 DUALSLIM Cat.6 RJ45 Black metal frame, M3 holes CP30722M440 DUALSLIM Cat.6 RJ45 Nickel frame, #4-40 holes CP30722MB440 DUALSLIM Cat.6 RJ45 Black metal frame, #4-40 holes CP30722MX1 DUALSLIM Cat.6 RJ45 Nickel frame, Ø3.2 PLAIN holes CP30722MBX1 DUALSLIM Cat.6 RJ45 Black metal frame, Ø3.2 PLAIN holes Feedthrough Features Material: — Fits standard rectangular cutout. 1. RJ45 In-Line Coupler: ABS UL94-V0 — Front or rear mounting through the panel. 2. RJ45 In-Line Coupler Contact: — Various hole mounting options. Phosphor Bronze, 3-50 micro inches — No soldering or punch termination. Use standard cable for gold plating over nickel plate. each connector style. 3. PCB: FR4 — Low rear profile. 4. Frame: Diecast, Nickel or Black plated Performance: General: 1. T568A & T568B wiring. Please note: Functionality is affected by cable quality, length and 2. Meet ISO/IEC 11801 and EN50173 cable wiring configuration. 3. Meet ANSI/TIA/EIA 568B.2 4. Rating: 125VAC RMS 1.5A 5. Operating Temperatures: Min -10°C Max +60°C © CLIFF 04/2022 ISS.2 For further information, contact sales@cliffuk.co.uk Cliff Electronic Components Limited, 76 Holmethorpe Avenue, Holmethorpe Ind. Estate, Redhill, Surrey RH1 2PF U.K. Tel: +44 (0)1737 771375 Fax: +44 (0)1737 766012 üRoHS www.cliffuk.co.uk
CP30722M 价格&库存
很抱歉,暂时无法提供与“CP30722M”相匹配的价格&库存,您可以联系我们找货
