CLIFF
DUALSLIM CAT.6 RJ45 SHIELDED METAL
FRAME FEEDTHROUGH CONNECTOR
Can be front or rear mounted in the panel
VARIANTS
Part No.
CP30722SM
DUALSLIM Cat.6 RJ45 Shielded Nickel frame, CSK holes
CP30722SMB
DUALSLIM Cat.6 RJ45 Shielded Black metal frame, CSK holes
CP30722SM3
DUALSLIM Cat.6 RJ45 Shielded Nickel frame, M3 holes
CP30722SMB3
DUALSLIM Cat.6 RJ45 Shielded Black metal frame, M3 holes
CP30722SM440 DUALSLIM Cat.6 RJ45 Shielded Nickel frame, #4-40 holes
CP30722SMB440 DUALSLIM Cat.6 RJ45 Shielded Black metal frame, #4-40 holes
CP30722SMX1
DUALSLIM Cat.6 RJ45 Shielded Nickel frame, Ø3.2 PLAIN holes
CP30722SMBX1 DUALSLIM Cat.6 RJ45 Shielded Black metal frame, Ø3.2 PLAIN holes
Material:
Feedthrough Features
1. RJ45 In-Line Coupler: ABS UL94-V0 Fully Shielded
Fits standard rectangular cutout.
2. RJ45 In-Line Coupler Contact:
Front or rear mounting through the panel.
Phosphor Bronze, 3-50 micro inches
Various hole mounting options.
gold plating over nickel plate.
No soldering or punch termination. Use standard cable for
3. PCB: FR4
each connector style.
4. Frame: Diecast, Nickel or Black plated
Low rear profile.
Performance:
1. T568A & T568B wiring.
General:
2. Meet ISO/IEC 11801 and EN50173
Please note: Functionality is affected by cable quality, length
3. Meet ANSI/TIA/EIA 568B.2
and cable wiring configuration.
4. Rating: 125VAC RMS 1.5A
5. Operating Temperatures: Min -10°C Max +70°C
© CLIFF 04/2022 ISS.2
For further information, contact sales@cliffuk.co.uk
Cliff Electronic Components Limited,
76 Holmethorpe Avenue, Holmethorpe Ind. Estate,
Redhill, Surrey RH1 2PF U.K.
Tel: +44 (0)1737 771375 Fax: +44 (0)1737 766012
üRoHS
www.cliffuk.co.uk
很抱歉,暂时无法提供与“CP30722SM”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+103.53783
- 10+84.51677
- 25+76.73107
- 50+72.08360
- 100+69.06515
- 250+66.03471
