CP30722SMB440
CP30722SMB440
    CLIFF
    模块 耦合器 连接器 插孔,8p8c(RJ45) 至 插孔,8p8c(RJ45) Cat6 屏蔽
CP30722SMB440 数据手册
CLIFF DUALSLIM CAT.6 RJ45 SHIELDED METAL FRAME FEEDTHROUGH CONNECTOR Can be front or rear mounted in the panel VARIANTS Part No. CP30722SM DUALSLIM Cat.6 RJ45 Shielded Nickel frame, CSK holes CP30722SMB DUALSLIM Cat.6 RJ45 Shielded Black metal frame, CSK holes CP30722SM3 DUALSLIM Cat.6 RJ45 Shielded Nickel frame, M3 holes CP30722SMB3 DUALSLIM Cat.6 RJ45 Shielded Black metal frame, M3 holes CP30722SM440 DUALSLIM Cat.6 RJ45 Shielded Nickel frame, #4-40 holes CP30722SMB440 DUALSLIM Cat.6 RJ45 Shielded Black metal frame, #4-40 holes CP30722SMX1 DUALSLIM Cat.6 RJ45 Shielded Nickel frame, Ø3.2 PLAIN holes CP30722SMBX1 DUALSLIM Cat.6 RJ45 Shielded Black metal frame, Ø3.2 PLAIN holes Material: Feedthrough Features 1. RJ45 In-Line Coupler: ABS UL94-V0 Fully Shielded — Fits standard rectangular cutout. 2. RJ45 In-Line Coupler Contact: — Front or rear mounting through the panel. Phosphor Bronze, 3-50 micro inches — Various hole mounting options. gold plating over nickel plate. — No soldering or punch termination. Use standard cable for 3. PCB: FR4 each connector style. 4. Frame: Diecast, Nickel or Black plated — Low rear profile. Performance: 1. T568A & T568B wiring. General: 2. Meet ISO/IEC 11801 and EN50173 Please note: Functionality is affected by cable quality, length 3. Meet ANSI/TIA/EIA 568B.2 and cable wiring configuration. 4. Rating: 125VAC RMS 1.5A 5. Operating Temperatures: Min -10°C Max +70°C © CLIFF 04/2022 ISS.2 For further information, contact sales@cliffuk.co.uk Cliff Electronic Components Limited, 76 Holmethorpe Avenue, Holmethorpe Ind. Estate, Redhill, Surrey RH1 2PF U.K. Tel: +44 (0)1737 771375 Fax: +44 (0)1737 766012 üRoHS www.cliffuk.co.uk
CP30722SMB440 价格&库存
很抱歉,暂时无法提供与“CP30722SMB440”相匹配的价格&库存,您可以联系我们找货
