CP30724M3
CP30724M3
    CLIFF
    模块 耦合器 连接器 插孔,6p4c(RJ11,RJ14) 至 插孔,6p4c(RJ11,RJ14) Cat3 无屏蔽
CP30724M3 数据手册
CLIFF DUALSLIM CAT3 RJ12 6P6C METAL FEEDTHROUGH CONNECTOR Can be front or rear mounted in the panel VARIANTS Part No. CP30724M DUALSLIM Cat3 RJ12 6P4C Nickel frame, CSK holes CP30724MB DUALSLIM Cat3 RJ12 6P4C Black metal frame, CSK holes CP30724M3 DUALSLIM Cat3 RJ12 6P4C Nickel frame, M3 holes CP30724MB3 DUALSLIM Cat3 RJ12 6P4C Black metal frame, M3 holes CP30724M440 DUALSLIM Cat3 RJ12 6P4C Nickel frame, #4-40 holes CP30724MB440 DUALSLIM Cat3 RJ12 6P4C Black metal frame, #4-40 holes CP30724MX1 DUALSLIM Cat3 RJ12 6P4C Nickel frame, Ø3.2 PLAIN holes CP30724MBX1 DUALSLIM Cat3 RJ12 6P4C Black metal frame, Ø3.2 PLAIN holes Material: Feedthrough Features 1. RJ12 In-Line Coupler: PC/ABS, UL94 V-0 Black — Fits standard rectangular cutout. 2. RJ12 In-Line Coupler Contact: — Front or rear mounting through the panel. Phosphor Bronze, 3-50 micro inches — Various hole mounting options. gold plating over nickel plate. — No soldering or punch termination. Use standard cable for each 3. PCB: FR4, UL94 V-0 connector style. 4. FT Frame: Diecast, Nickel or Black plated — Low rear profile. 5. Operating Temperatures: Min -10°C Max +60°C General: Please note: Functionality is affected by cable quality, length and cable wiring configuration. © CLIFF 07/2022 ISS.1 For further information, contact sales@cliffuk.co.uk Cliff Electronic Components Limited, 76 Holmethorpe Avenue, Holmethorpe Ind. Estate, Redhill, Surrey RH1 2PF U.K. Tel: +44 (0)1737 771375 Fax: +44 (0)1737 766012 üRoHS www.cliffuk.co.uk
CP30724M3 价格&库存
很抱歉,暂时无法提供与“CP30724M3”相匹配的价格&库存,您可以联系我们找货
