CP30737
CP30737
    CLIFF
    同轴连接器(RF) - 适配器 BNC 插孔,母插口 至 BNC 插孔,母插口 50 欧姆
CP30737 数据手册
CLIFF ISS. AMEND DATE 1 ISSUED 12/01/22 DUAL MOUNT CAN BE FRONT OR REAR MOUNTED 17.15 (0.675") HOLES TO SUIT SCREW USED 22.86 (0.900") 29.00 PLAIN HOLE VARIANTS 'X' VERSION Ø2.5 'X1' VERSION Ø3.2 33.0 19.0 2.80 16.7 2.3 29.00 35.5 22.5 RoHS ü Ø4.4 COMPLIANT 3x HOLE VARIANTS ∅3.2mm CSK 90° x Ø5.85 'X' PLAIN Ø2.5 HOLES 'X1' PLAIN Ø3.2 HOLES Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk THE CONTENTS OF THIS DOCUMENT MUST NOT BE COPIED OR DISCLOSED TO A 3rd PARTY WITHOUT WRITTEN PERMISSION OF CLIFF UK. © 2022 TOLERANCE Material: 1. SLIM Frame: Polyamide UL94 V2 2. BNC Frame: ABS UL94 V2 3. BNC Body: Brass - Nickel Plated 4. BNC Centre: Brass - Copper Plated 5. BNC Insulator: PP UL94 V2 NO DEC. PLACE ± 1 DEC. PLACE ± 2 DEC. PLACE ± HOLE Ø ± ANGLES ± UNLESS OTHERWISE STATED DIMENSIONS IN MILLIMETERS UNLESS OTHERWISE STATED. WORK TO DIMENSIONS. REMOVE ALL BURRS. IF IN DOUBT ASK. FINISH: See Notes See Notes DRAWN: T.J.O. MATERIAL: TITLE: APPROVED: D.P.J. 3rd ANGLE PROJECTION: DO NOT SCALE DUAL MOUNT SLIM FT BNC 50ohm DRWG. No. CP30737 FORM: A4DRWGH
CP30737 价格&库存
很抱歉,暂时无法提供与“CP30737”相匹配的价格&库存,您可以联系我们找货
CP30737
  • 1+68.680901+8.87774
  • 10+58.3915410+7.54773
  • 25+54.7296325+7.07439
  • 50+52.1161350+6.73657
  • 100+49.62861100+6.41503
  • 250+46.52208250+6.01348
  • 500+44.30299500+5.72664
  • 1000+42.190491000+5.45357
库存:16
