CP30752MB3
CP30752MB3
    CLIFF
    模块 耦合器 连接器 插孔,8p8c(RJ45) 至 插孔,8p8c(RJ45) Cat6 无屏蔽
CP30752MB3 数据手册
CLIFF DUALSLIM CAT.6 RJ45 RIGHT ANGLE METAL FEEDTHROUGH CONNECTOR Can be front or rear mounted in the panel VARIANTS Part No. CP30752M RAFT DUALSLIM Cat.6 RJ45 Nickel frame, CSK holes CP30752MB RAFT DUALSLIM Cat.6 RJ45 Black metal frame, CSK holes CP30752M3 RAFT DUALSLIM Cat.6 RJ45 Nickel frame, M3 holes CP30752MB3 RAFT DUALSLIM Cat.6 RJ45 Black metal frame, M3 holes CP30752M440 RAFT DUALSLIM Cat.6 RJ45 Nickel frame, #4-40 holes CP30752MB440 RAFT DUALSLIM Cat.6 RJ45 Black metal frame, #4-40 holes CP30752MX1 RAFT DUALSLIM Cat.6 RJ45 Nickel frame, Ø3.2 PLAIN holes CP30752MBX1 RAFT DUALSLIM Cat.6 RJ45 Black metal frame, Ø3.2 PLAIN holes Feedthrough Features Material: — Fits standard rectangular cutout. 1. RJ45 In-Line Coupler: ABS UL94-V2 — Front or rear mounting through the panel. 2. RJ45 In-Line Coupler Contact: — Various hole mounting options. Phosphor Bronze, gold plating — No soldering or punch termination. Use standard cable for 3. PCB: FR4 each connector style. 4. Frame: Diecast, Nickel or Black plated — Low rear profile. Performance: l 90° or right angle rear cable entry. 1. T568A & T568B wiring. 2. Meet ISO/IEC 11801 and EN50173 General: 3. Meet ANSI/TIA/EIA 568B.2 Please note: Functionality is affected by cable quality, length and 4. Rating: 125VAC RMS 1.5A 5. Operating Temperatures: Min -10°C Max +60°C cable wiring configuration. © CLIFF 07/2022 ISS.1 For further information, contact sales@cliffuk.co.uk Cliff Electronic Components Limited, 76 Holmethorpe Avenue, Holmethorpe Ind. Estate, Redhill, Surrey RH1 2PF U.K. Tel: +44 (0)1737 771375 Fax: +44 (0)1737 766012 üRoHS www.cliffuk.co.uk
CP30752MB3 价格&库存
很抱歉,暂时无法提供与“CP30752MB3”相匹配的价格&库存,您可以联系我们找货
CP30752MB3
库存:49
