CP30752M3
CP30752M3
    CLIFF
    模块 耦合器 连接器 插孔,8p8c(RJ45) 至 插孔,8p8c(RJ45) Cat6 无屏蔽
CP30752M3 数据手册
CLIFF 17.0 ISS. AMEND DATE 1 ISSUED 15/07/22 Material: 1. RJ45 In-Line Coupler: ABS UL94-V2 2. RJ45 In-Line Coupler Contact: Phosphor Bronze, gold plating. 3. PCB: FR4 4. FT Frame: Nickel Plated Zinc Diecast 35.3 19.0 2.3 16.7 2.80 Ø3.20 PLAIN HOLE PIN 1 29.00 23.3 PIN 8 CP30752MX1 PIN 8 35.5 17.15 4x HOLE VARIANTS Ø3.2mm CSK 90° x Ø5.85 M3 x 0.5 THREAD #4-40 UNC THREAD PLAIN Ø3.2 HOLES HOLES TO SUIT SCREW USED (0.675") 22.86 (0.900") DUAL MOUNT CAN BE FRONT OR REAR MOUNTED PIN 1 22.5 18.8 29.00 Performance: 1. T568A & T568B wiring. 2. Meet ISO/IEC 11801 and EN50173 3. Meet ANSI/TIA/EIA 568B.2 4. Rating 125VAC RMS 1.5A 5. Operating Temperatures: Min -10°C Max +60°C RoHS ü COMPLIANT TOLERANCE NO DEC. PLACE ± 1 DEC. PLACE ± 2 DEC. PLACE ± HOLE Ø ± ANGLES ± UNLESS OTHERWISE STATED Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk THE CONTENTS OF THIS DOCUMENT MUST NOT BE COPIED OR DISCLOSED TO A 3rd PARTY WITHOUT WRITTEN PERMISSION OF CLIFF UK. © 2022 DIMENSIONS IN MILLIMETERS UNLESS OTHERWISE STATED. WORK TO DIMENSIONS. REMOVE ALL BURRS. IF IN DOUBT ASK. FINISH: See Notes See Notes DRAWN: T.J.O. MATERIAL: TITLE: APPROVED: D.P.J. 3rd ANGLE PROJECTION: DO NOT SCALE RAFT DUALSLIM METAL CAT6 RJ45 DRWG. No. CP30752M FORM: A4DRWGH
CP30752M3 价格&库存
很抱歉,暂时无法提供与“CP30752M3”相匹配的价格&库存,您可以联系我们找货
CP30752M3
