CP30788M3
CP30788M3
    CLIFF
    适配器连接器 HDMI,插座 至 HDMI,插座 面板安装,法兰
CP30788M3 数据手册
CLIFF DUALSLIM 8K HDMI FEMALE - FEMALE METAL FRAME FEEDTHROUGH CONNECTOR Can be front or rear mounted in the panel VARIANTS Part No. CP30788M CP30788MB CP30788M3 CP30788MB3 CP30788M440 CP30788MB440 CP30788MX1 CP30788MBX1 DUALSLIM 8K HDMI F-F Nickel frame, CSK holes DUALSLIM 8K HDMI F-F Black metal frame, CSK holes DUALSLIM 8K HDMI F-F Nickel frame, M3 holes DUALSLIM 8K HDMI F-F Black metal frame, M3 holes DUALSLIM 8K HDMI F-F Nickel frame, #4-40 holes DUALSLIM 8K HDMI F-F Black metal frame, #4-40 holes DUALSLIM 8K HDMI F-F Nickel frame, Ø3.2 PLAIN holes DUALSLIM 8K HDMI F-F Blk metal frame, Ø3.2 PLAIN holes Feedthrough Features Fits standard rectangular cutout. Front or rear mounting through the panel. Various hole mounting options. No soldering or punch termination. Use standard cable for each connector style. Low rear profile. General: Please note: Functionality is affected by cable quality, length and cable wiring configuration. 8K equipment and cables required to achieve 8K resolutions. © CLIFF 02/2023 ISS.1 Material: 1. Insert: ABS UL94 HB 2. SLIM Frame: Zinc Diecast, Ni or Black plated 3. Shell: Gold plated 4. Contacts: Gold Plated Specification: 1. Shielded HDMI 2.1 F-F 2. Voltage Rating: 40V ac 3. Current Rating: 0.5A max 4. Contact Resistance: 10mΩ max 5. Insulation Resistance: 100MΩ min 6. Dielectric Withstanding Voltage: 500V AC 7. Operating Temperature: -25°C to 85°C HDMI Specification 1. Version: Shielded HDMI 2.1 2. Supported Video resolution: 7680 x 4320 60Hz 3. HDR Support : Yes 4. HDCP Specification: 1.4; 2.2 5. Chroma Sub Sampling: 4:4:4 For further information, contact sales@cliffuk.co.uk Cliff Electronic Components Limited, 76 Holmethorpe Avenue, Holmethorpe Ind. Estate, Redhill, Surrey RH1 2PF U.K. Tel: +44 (0)1737 771375 Fax: +44 (0)1737 766012 RoHS www.cliffuk.co.uk
CP30788M3 价格&库存
很抱歉,暂时无法提供与“CP30788M3”相匹配的价格&库存,您可以联系我们找货
CP30788M3
  • 1+149.221951+19.36629
  • 10+126.7816710+16.45395
  • 25+118.8381525+15.42303
  • 50+113.1673150+14.68705
  • 100+107.76767100+13.98628
  • 250+101.02593250+13.11133
  • 500+96.20922500+12.48620
库存:24
