FCR684204T
FCR684204T
    CLIFF
    插件
    光纤 - 发射器 - 驱动器集成电路 655nm 16Mbps 2.7V ~ 5.5V 10 mA
FCR684204T 数据手册
Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk FIBER OPTIC DATA LINK DATA SHEET 02'(/12 : )&57 DATE : 2021/12/03 VERSION : DEVICE NO. : 27- 237,&$/75$160,77(5-$&. CUSTOMER DESIGNER 2 CHECKER APPROVER Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk Features  High speed signal transmission (16Mbps, NRZ signal )  Input TTL compatible  +3~+5V power source  Automatically detects the presence of a mini-plug in the jack and distinguishes an optical mini-plug from an electrical mini-plug Descriptions The light transmitting unit is a standard-package product with connector and opto-electric component packaged with LED and drive IC. The function of unit changes the electric signal into light signal and be transmitted by plastic fiber. The unit is operated at single+3V~ +5V and the input signal is TTL compatible. The FCR684204T has a maximum operating speed of 16 Mbps. The light signal is coupled into plastic fiber by connector. The unit has high performance at low dissipation current, steady light output and efficient light coupling. Applications  PC, Notebook  DVD player  TV  MD  Digital optical data link  Sound Card  Set-top box Device Selection Guide Chip IC Material Si Operating Voltage LED (Vcc) λ p(nm) 650 2.7~5.5V Dissipation Current(mA) Fiber Coupling Light Output (dBm) Typ. Min. Typ. Max. 4 -21 - -15 Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk Package Dimensions Notes: 1.All dimensions are in millimeters. 2.General Tolerance:±0.2mm 3. Pin 1 ~ 5 golden plating. Pin Function 1 ~ 5 : jack terminal (1,5 : detector ; 4: GND ; 2 : left channel ; 3 : right channel ) 6 ~ 9 : device terminal (6 : GND ; 7 : Vcc ; 8 : Vin ; 9 : internal connection) Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk Jack Terminal Configuration Optical circular plug ( satisfys EIAJ RC-5720B ) 3-pole small-sized concentric plug ( satisfy JIS C 6560 ) Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk Optical Mini-jack Connection Type of plug Output of terminal Output of terminal 5 1 2,3 Analog electricity L L Signal data input/output Digital optics L H Signal data output No plug H H - Absolute Maximum Ratings( Ta = 25℃) Parameter Symbol Rating Unit Supply Voltage DC Input Voltage Power Dissipation Storage Temperature Vcc Vin P Tstg -0.5 to 7 -0.5 to Vcc+0.5 120 -30 to 80 V V mW Operating Temperature Topr -20 to 70 ℃ Soldering Temperature Tsol 260* ℃ *Soldering time  5 s / 2times. *Don't touch flux soldering and white Gas ℃ Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk Electro-Optical Characteristics Parameter Symbol Conditions MIN. TYP. MAX. Unit Operating Voltage Vcc - 2.7 - 5.5 V Peak Emission Wavelength p - 640 - 670 nm 16 Mbps Transmission Speed NRZ signal DC Transmission Distance Using APF 0.2 - 20 m 16Mbps NRZ Signal -15 - 15 ns Pulse Width Distortion tw - Fiber Coupling Light Output Pf *1 -21 - -15 dBm Dissipation Current Icc *2 - 4 10 mA High Level Input Voltage VIH 2.0 - - v Low Level Input Voltage VIL - - 0.8 v Rise Time tr *3 - - 30 ns Fall Time tf *3 - - 30 ns Low High propagation delay time tPLH *3 - - 100 ns High Low propagation delay time tPHL *3 - - 100 ns tj *3 - 1.5 15 ns Jitter Mechanical Electro-Optical Characteristics (Jack) Parameter Symbol Conditions MIN. TYP. MAX. Unit Fp *a 3.9 - 34.3 N Contact resistance Rcon *b - - 30 mΩ Isolation resistance Riso D.C.500V, 1min 100 - - MΩ Insertion and withdrawal force *a Using JIS C6560 standard plug (φ 3.5) for test. *b It measures at 100 mA or less 1000 Hz at the condition of inserting JIS C6560 plug . FCR684204T light transmitting unit satisfies EIAJ CP-1201 digital audio interface standard. Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk Reliability Test Items No. Item 1 Soldering Heat Test Condition 260℃±5℃ Test Hour/Cycle Samples Number (n) Failure (c) 5 sec./2times 22 n=22, c=0 2 High temp. & Hum. storage Ta=40℃, 90%RH 500 22 n=22, c=0 3 High temp.storage Ta=80℃ 500 22 n=22, c=0 4 Low Temp.storage Ta=-30℃ 500 22 n=22, c=0 20 22 n=22, c=0 500 22 n=22, c=0 22 n=22, c=0 5 Temp. cycling -30℃ ~ 80℃ (30min) (5min) (30min) 6 High Temp. Operation life Ta=60℃, Vcc=5V ON 7 Repeated operation 500 times 8 Terminal Weight: 500 g Strength(tension) 30 sec./each terminal 22 n=22, c=0 9 Terminal Weight: 500 g Strength(bending) 2 times/each terminal 22 n=22, c=0 Coupling force < 3.5kg 0.4kg
FCR684204T 价格&库存
很抱歉,暂时无法提供与“FCR684204T”相匹配的价格&库存,您可以联系我们找货
FCR684204T
    • 1+41.50440
    • 200+16.56720
    • 500+16.01640
    • 1000+15.73560
