FCR684206R
FCR684206R
    CLIFF
    光纤 - 接收器 数字音频,光学 16Mbps 2.7V ~ 5.5V 10 mA
FCR684206R 数据手册
Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk FIBER OPTIC DATA LINK DATA SHEET MODEL NO. : FCR684206R DATE : 2017-03-24 VERSION : 1.1 DEVICE NO. : ORJ­6 (OPTICAL RECEIVER JACK) Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk Features  High PD sensitivity for red light  High speed up to 16 Mbps  Low power consumption and current dissipation  +3~+5V power source Descriptions FCR684206R is a new design connector including traditional RCA and Data Link inner opto-electric component. Not only does it receive electric digital signal but also light signal. The optic unit is operated at single +3~+5V and RCA input signal at ± 0.5 V. FCR684206R has a maximum operating speed of 16 Mbps. The optic unit has high performance at low dissipation current, steady light output and efficient light coupling. Applications  Amplifier  DVD Device Selection Guide Chip IC Material Si Operating Voltage LED λp(nm) (Vcc) 700 2.7~5.5 Dissipation Current(mA) Fiber Coupling Light Output (dBm) Typ. Min. Typ. Max. 6.5 -24 - -14.5 1 Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk Package Dimensions Notes: 1.All dimensions are in millimeters. 2.General Tolerance:±0.2mm Pin Function 1. Vout 4. Positive 2. GND 5.Negative 3. Vcc Absolute Maximum Ratings( Ta = 25℃) Parameter Supply Voltage Storage Temperature Operating Temperature Soldering Temperature * Soldering time  5 s / 2 times. Symbol Rating Unit Vcc Tstg Topr Tsol 5.5 -30 to 80 -20 to 70 260* V ℃ ℃ ℃ *Don't touch flux soldering and white Gas 2 Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk Electro-Optical Characteristics Parameter Operating Voltage(optic unit) Symbol Conditions MIN. TYP. MAX. Unit Vcc - 2.7 - 5.5 V (electrical unit) Peak Detective Wavelength 0.75 p - 1.25 - 700 - nm Transfer Speed NRZ signal 0.1 - 16 Mbps Receiving Distance Using APF 0.2 - 20 m 16Mbps NRZ Signal -20 - 20 ns Pulse Width Distortion tw Input Light power Pi *1 -24 - -14.5 dBm Dissipation Current Icc *2 - 6 10 mA High Level Output Voltage VOH 2.4 - - v Low Level Output Voltage VoL - - 0.4 v Rise Time tr *3 - - 25 ns Fall Time tf *3 - - 25 ns Low time High propagation delay tPLH *3 - - 100 ns High time Low propagation delay tPHL *3 - - 100 ns tj *3 - 1.5 15 ns Jitter time FCR684206R light receiving unit satisfies EIAJ CP-1201 digital audio interface standard. 3 Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk Reliability Test Items No. Item 1 Soldering Heat Test Condition 260℃±5℃ Test Hour/Cycle Samples Number (n) Failure (c) 5 sec./2times 22 n=22, c=0 2 High temp. & Hum. storage Ta=40℃, 90%RH 500 22 n=22, c=0 3 High temp. storage Ta=80℃ 500 22 n=22, c=0 Ta=-30℃ 500 22 n=22, c=0 20 22 n=22, c=0 500 22 n=22, c=0 Coupling force < 2 kg 0.4kg
FCR684206R 价格&库存
很抱歉,暂时无法提供与“FCR684206R”相匹配的价格&库存,您可以联系我们找货
