FCR684206T
FCR684206T
    CLIFF
    光纤 - 发射器 - 驱动器集成电路 655nm 16Mbps 2.7V ~ 5.5V 10 mA
FCR684206T 数据手册
Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk FIBER OPTIC DATA LINK DATA SHEET MODEL NO. :)&57 DATE : VERSION : DEVICE NO. :27- 237,&$/75$160,77(5-$&. 201-0- Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk Features  High speed signal transmission ( 16Mbps, NRZ signal )  Input TTL compatible  +3~+5V power source Descriptions )&57 is a new design connector including traditional RCA and Data Link inner opto-electric component. Not only doesLW transmit electric digital signal but alsoOLJKWVLJQDO  The optic unit is operated at single +3V~ +5V and RCA input signal at ± 0.5 V. The )&57as a maximum operating speed of 16 Mbps. The optic unit has high performance at low dissipation current, steady light output and efficient light coupling. Applications  DVD player Device Selection Guide Chip IC Material Operating Voltage LED λp(nm) (Vcc) Dissipation Current(mA) Fiber Coupling Light Output (dBm) IC Material Typ. Si 650 2.7~5.5 5.5 Si 1 650 2.7~5.5 Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk Package Dimensions Notes: 1.All dimensions are in millimeters. 2.General Tolerance:±0.2mm Pin Function 1. GND 4.Positive 2. Vcc 5.Negative 3. Vin Absolute Maximum Ratings( Ta = 25℃) Parameter Supply Voltage DC Input Voltage Power Dissipation Storage Temperature Operating Temperature Soldering Temperature Symbol Rating Unit Vcc Vin P Tstg Topr Tsol -0.5 to 7 -0.5 to Vcc+0.5 120 -30 to 80 -20 to 70 260* V V mW ℃ ℃ ℃ * Soldering time  5 s / 2 times.  2 Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk Parameter Operating Voltage(optic unit) Symbol Conditions MIN. TYP. MAX. Unit Vcc - 2.7 - 5.5 V (electrical unit) Peak Emission Wavelength 0.75 p - 1.25 640 - 670 nm Transmission Speed NRZ signal DC - 16 Mbps Transmission Distance Using APF 0.2 - 20 m 16Mbps NRZ Signal -25 - 25 ns Pulse Width Distortion tw Fiber Coupling Light Output Pf *1 -21 -17 -15 dBm Dissipation Current Icc *2 - 5 10 mA High Level Input Voltage VIH 2 - - v Low Level Input Voltage VIL - - 0.8 v Rise Time tr *3 - 30 40 ns Fall Time tf *3 - 20 30 ns Low time High propagation delay tPLH *3 - - 100 ns High time Low propagation delay tPHL *3 - - 100 ns Jitter (rise time) tr *3 - 1.5 15 ns Jitter (fall time) tf *3 - 1.5 15 ns )&57Oight transmitting unit satisfies EIAJ CP-1201 digital audio interface standard. 3 Cliff Electronic Components Ltd. 76 Holmethorpe Avenue, Holmethorpe Industrial Estate, Redhill, Surrey, RH1 2PF, England, UK Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk Reliability Test Items No. Item 1 Soldering Heat Test Condition 260℃±5℃ Test Hour/Cycle Samples Number (n) Failure (c) 5 sec./2times 22 n=22, c=0 2 High temp. & Hum. storage Ta=40℃, 90%RH 500 22 n=22, c=0 3 High temp. storage Ta=80℃ 500 22 n=22, c=0 Ta=-30℃ 500 22 n=22, c=0 20 22 n=22, c=0 500 22 n=22, c=0 22 n=22, c=0 4 Low Temp. storage 5 Temp. cycling -30℃ ~ 80℃ (30min) (5min) (30min) 6 High Temp. Operation life Ta=60℃, Vcc=5V ON 7 Repeated operation 500 times Coupling force < 2 kg 0.4kg
FCR684206T 价格&库存
很抱歉,暂时无法提供与“FCR684206T”相匹配的价格&库存,您可以联系我们找货
FCR684206T
    • 1+44.98200
    • 200+17.94960
    • 500+17.35560
    • 1000+17.05320
