Cliff Electronic Components Ltd.
76 Holmethorpe Avenue, Holmethorpe Industrial Estate,
Redhill, Surrey, RH1 2PF, England, UK
Tel: 01737-771375 Fax: 01737-766012 Website: www.cliffuk.co.uk
FIBER OPTIC DATA LINK
DATA SHEET
MODEL NO
FCR684208R
DATE
2016-09-02
VERSION
1.1
DEVICE NO.
ORJ8 (OPTICAL RECEIVER JACK)
CUSTOMER
DESIGNER
CHECKER
APPROVER
CLIFF
3
1
1 2
3
ISS.
AMEND
DATE
1
ISSUED
20/09/16
4
3
2
2
1
3
2 1
5
RoHS
ü
COMPLIANT
TOLERANCE
NO DEC. PLACE ±
1 DEC. PLACE ±
2 DEC. PLACE ±
HOLE Ø ±
ANGLES ±
UNLESS
OTHERWISE STATED
THE CONTENTS OF THIS DOCUMENT MUST NOT BE COPIED OR DISCLOSED
TO A 3rd PARTY WITHOUT WRITTEN PERMISSION OF CLIFF UK.
© 2016
DIMENSIONS IN MILLIMETERS UNLESS OTHERWISE STATED. WORK TO DIMENSIONS. REMOVE ALL BURRS. IF IN DOUBT ASK.
FINISH:
SEE TABLE
CLEAN
DRAWN:
T.J.O.
MATERIAL:
TITLE:
APPROVED: D.P.J.
ANGLE PROJECTION:
DO NOT SCALE
OPTICAL JACK RECEIVER ORJ-8
DRWG. No.
FCR684208R
FORM: A4DRWGH
Features
• High PD sensitivity for red light
• High speed up to 16 Mbps
• Low power consumption and current dissipation
• +3~+5V power source
Descriptions
The light receiving unit is a standard-package product with connector and opto-electric
component packaged with PD and I/V amplifier IC. The function of unit changes the light signal
into electric signal.
The unit is operated at +3~+5V and the input signal is TTL compatible. FCR684208R has
a maximum operating speed of 16 Mbps.
Applications
• Audio equipment
• Digital optical data link
• MD
• Sound card
Device Selection Guide
Chip
Operating
IC
Material
LED
λp(nm)
Voltage
(Vcc)
Si
650
2.7~5.5
Dissipation
Current(mA)
Fiber Coupling Light Output
(dBm)
Typ.
Min.
Typ.
Max.
6.5
-24
-14.5
Package Dimensions
Notes: 1.All dimensions are in millimeters.
2.General Tolerance:±0.2mm
3.Material:HTN (High Temperature Nylon)
4. Supplied with black shutter.
Pin Function
1. Vout
2. GND
3. Vcc
Absolute Maximum Ratings( Ta = 25℃
Parameter
Supply Voltage
Storage Temperature
Operating Temperature
Soldering Temperature
* Soldering time ≤ 5s / 2 times.
Symbol
Vcc
Tstg
Topr
Tsol
Rating
5.5
-30 to 80
-20 to 70
260*
*Don't touch flux soldering and white Gas
Unit
V
Electro-Optical Characteristics
Parameter
Symbol
Conditions
MIN.
TYP.
MAX.
Unit
Operating Voltage
Vcc
2.7
5.5
V
Peak Detective Wavelength
λp
650
nm
Transfer Speed
NRZ signal
0.1
16
Mbps
Receiving Distance
Using APF
0.2
m
16Mbps NRZ Signal
-20
ns
Pulse Width Distortion
∆tw
Input Light power
Pi
*1
-24
-14.5
dBm
Dissipation Current
Icc
*2
6
10
mA
High Level Output Voltage
VOH
2.4
v
Low Level Output Voltage
VoL
0.4
v
Rise Time
tr
*3
25
ns
Fall Time
tf
*3
25
ns
Low
time
High propagation delay
tPLH
*3
100
ns
High
time
Low propagation delay
tPHL
*3
100
ns
∆tj
*3
1.5
15
ns
Jitter time
FCR684208R light receiving unit satisfies EIAJ CP-1201 digital audio interface standard.
Reliability Test Items
No.
Item
1 Soldering Heat
Test Condition
260℃±5℃
Test
Hour/Cycle
Samples
Number (n)
Failure (c)
5 sec./2times
22
n=22, c=0
2
High temp. &
Hum. storage
Ta=40℃, 90%RH
500
22
n=22, c=0
3
High temp.
storage
Ta=80℃
500
22
n=22, c=0
4
Low Temp.
storage
Ta=-30℃
500
22
n=22, c=0
n=22, c=0
500
22
n=22, c=0
22
n=22, c=0
5 Temp. cycling
6
High Temp.
Operation life
Repeated
7
operation
-30℃ ~ 80℃
(30min) (5min) (30min)
Ta=60℃, Vcc=5V ON
Coupling force < 2 kg
500 times
0.4kg
很抱歉,暂时无法提供与“FCR684208R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+54.65019
- 10+46.45148
- 100+39.47486
- 250+37.36289
- 500+35.25092
- 1000+33.56609
