CLIFF
XRP RECESS PLATES
The Cliff range of XLR Recess plates enable the easy mounting of components into panels, using
standard Ø24mm XLR panel cutout. Plates can be front or rear mounted. Plate material is Nylon.
Plate mounted with 30A. Terminal Post
CP303010 - XRP3 with Black 30A. TP6 Terminal Post. 4mm cross hole. CSK Hole
CP303010X - XRP3 with Black 30A. TP6 Terminal Post. 4mm cross hole. Plain Hole
CP303011 - XRP3 with Red 30A. TP6 Terminal Post. 4mm cross hole. CSK Hole
CP303011X - XRP3 with Red 30A. TP6 Terminal Post. 4mm cross hole. Plain Hole
Plate mounted with 3.5mm Jack Socket
CP303075 - XRP3 with S6/BB 3.5mm Mono Jack Socket - CSK Hole
CP303075X - XRP3 with S6/BB 3.5mm Mono Jack Socket - Plain Hole
© CLIFF 04/2020 ISS.4
For further information, contact sales@cliffuk.co.uk
Cliff Electronic Components Limited,
76 Holmethorpe Avenue, Holmethorpe Ind. Estate,
Redhill, Surrey RH1 2PF U.K.
Tel: +44 (0)1737 771375 Fax: +44 (0)1737 766012
üRoHS
www.cliffuk.co.uk
CLIFF
XRP RECESS PLATES
Plate mounted with 6.35mm Stereo Jack Socket
CP303080 - XRP3 with S4/BBB 6.35mm Stereo Jack Socket - CSK Hole
CP303080X - XRP3 with S4/BBB 6.35mm Stereo Jack Socket - Plain Hole
Plate mounted with 3.5mm Vertical Stereo Jack Socket, PC Mount.
CP303100 - XRP3 with 3.5mm Vertical Stereo Jack Socket - PC Mounting, CSK Hole
CP303100X - XRP3 with 3.5mm Vertical Stereo Jack Socket - PC Mounting, Plain Hole
üRoHS
www.cliffuk.co.uk
很抱歉,暂时无法提供与“CP303011”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+43.24756
- 6+21.74687
- 15+20.59798
