PRODUCT DATA SHEET
Part Number:
Type
LED
Size
M8
Rating
12Vdc
1904x25xWEC
Description
LED Panel Mount Indicator with Leads
Dimensions in mm (Not to scale)
6
26
190 ± 10
7
⌀ 9.5
Red wire: +ve
Black wire: -ve
White
plastic
body
5mm
Partial Strip
SW10
M8 x 0.75
Part Number
1904x253WEC
1904x251WEC
1904x252WEC
1904x257WEC
Colour
Red
Green
Yellow
Blue
x = 0: Satin chrome bezel
Voltage
12Vdc
12Vdc
12Vdc
12Vdc
Typ. Current (mA)
x = 1: Black chrome bezel
Typ. Luminous Intensity (mcd)
80
32
32
60
x = 2: Matt chrome bezel
Notes:
1
2
3
4
5
6
7
8
9
10
11
12
13
Electrical & optical data are measured at an ambient temperature of 25ºC
The stated luminous intensity is for dc operation
Due to component tolerances, colour temperature variations may be observed
Storage temperature range: -25 ºC to +80ºC
Operating temperature range: -20 ºC to +60ºC
Sealed to IP67 above panel when the supplied gasket used
The plastic (polycarbonate) has limited chemical resistance
The plastic cartridge contains 3 wire exit holes - the rear of the product is not sealed
Lead wires are internally soldered
Lead wires: 7/0.2 (24 AWG) stranded copper, tinned annealed copper wire, PVC insulation
Marking: Part number, voltage rating, LED colour and date code
REACH SVHC compliant
This product contains free-machining brass and is RoHS compliant via exemption clause Annex iii 6 (c)
of EU Directive 2011/65/EU [Copper alloy containing lead up to 4% by weight]
Page 1 of 1
Issue 1: 20Feb20
CML Innovative Technologies Ltd • 69-70 Eastern Way • Bury St Edmunds • Suffolk • IP32 7AB • England
Tel: +44 (0) 1284 714700 • Fax: +44 (0) 1284 754406 • Email: bury@cml-it.com • www.cml-it.com
Registered Office: Eastern Way, Bury St Edmunds – Registration No. 265006 England
很抱歉,暂时无法提供与“19040253WEC”相匹配的价格&库存,您可以联系我们找货
